Movies play fine on the LAN but not at all on the WAN
rrrssssss
Post Fri Jan 29, 2016 4:35 pm
Hello Serviio forum,
I have been using Serviio for years and I love it. But I am having trouble getting the media browser to play movie files (mostly .ts) when outside of my LAN on my iPad (using the Internet) but these same movies will play fine locally (inside my LAN), using Firefox locally on my desktop computer (LAN) and I use Safari on my iPad when playing movies using the Internet (WAN). The movies will not play on my iPad using the Internet or by putting my iPad in wifi mode in my LAN. Eather way, WAN or LAN, they won't play on my iPad (Safari) . Should I try a different browser in my iPad when playing movies on the WAN or LAN?
There is a slash mark going through the play arrow located in the center of the video screen when I try to play a movie on my iPad (Safari) using either the WAN (Internet) or the LAN (locally).
My other media files play fine on the WAN or LAN such as images and music.
Best regards,
Roy
UPDATE
They won't play on Firefox either using the iPad.
Post Fri Jan 29, 2016 5:32 pm
Re: Movies play fine on the LAN but not at all on the WAN
Many home Internet connections are asynchronous, which means they don't upload as fast as download. I have 50 Mbps down, but only 5 Mbps up. My 5 actually tests out about 4.3, which is normal. Even with 5, I have issues when trying to playback an HD video when quality is set to original. It also depends on the Internet connection you have when away from home. When I travel, many hotels limit each guest's connection speed that make it difficult to stream video.
Pictures and music use far less bandwidth, so that's likely why they work fine. When you are connected to your LAN, you have the same speed in both directions.
Run a speedtest (www.speedtest.net) and see what you have for upload speed.
rrrssssss
Post Fri Jan 29, 2016 6:16 pm
Hello again Serviio forum,
I never did solve my original problem but I found a workaround. On my iPad I installed Photon (web browser) with Adobe Flash support and now my .ts movies play fine after I set the bandwith to low from Photon. So it looks like I needed flash support on my iPad. Am I right?
All the best,
Roy
PS - I use Verizon's cell phone towers for my Internet access which has a download speed of about 12 mbps download and about 5 mbps upload.
Rosales_Network
I have 75 up and 75 down and it works great on a android.
I am having difficulties using it on an iPhone 4s.
It does not work well with an IOS device Wan or on lan. I am using safari on the apple devices to access my media remotely
Post Sat Jan 30, 2016 2:25 am
Apple devices do not support Flash. You need an alternate browser.
Rosales_Network
Post Sat Jan 30, 2016 3:20 am
I have used this before on my ipad 2 32GB Wifi only, flash seemed to work ok.
can this support it?
Puffin Web Browser
https://itunes.apple.com/us/app/puffin- ... 37654?mt=8
rrrssssss
Post Sat Jan 30, 2016 2:00 pm
UPDATE
After upgrading to Serviio 6.0 I can now use the media browser on my Apple devices (Safara or Firefox) without using Adobe Flash but instead HTML 5 does the trick. HTML 5 lets you stream videos such as .mpg or .ts , .avi, etc. without the need for Flash. The older versions of Seviio such as 4.x did not support HTML5 but the latest version does.
So now my problem is solved thanks to the new HTML5 implementation. I no longer need Flash.
Roy
Rosales_Network
Post Sat Jan 30, 2016 4:26 pm
can you provide the download link for Serviio 6.0
I would like to test it from my end.
rrrssssss
Post Sat Jan 30, 2016 6:51 pm
http://serviio.org/download
I hope this is what you wanted.
Roy
UPDATE
I stated the wrong version of Serviio. I meant to say version 1.6, not 6.0.
I apologize for that.
Rosales_Network
Post Sat Jan 30, 2016 9:51 pm
Oh Ok I understand I will download that version and test it.
Rosales_Network
Post Wed Feb 10, 2016 2:18 am
I download the Serviio 1.6 version and I am seeing some lag in Media Browser it does not responds to touch commands.
I try to select a video and it hangs.
Device:
Iphone 4s
Video:
. mp4
Return to User experiences
Users browsing this forum: Baidu [Spider] and 17 guests
