Youtube doesn't work
Boncurek84
Post Sun Mar 20, 2016 6:16 am
I have a problem with setting up YT plugin corectly.
Firstly I installed Serviio 1.6
Then dowloaded Firefox plugin
Then I put YT.groovy file in plugin folder
Next I tried used Serviio icon on YT playlist> It became red and said YT plugin not installed:
Log file shows:
2016-03-19 17:49:09,932 INFO  [MediaServer] ------------------------------------------------------------------------
2016-03-19 17:49:09,933 INFO  [MediaServer] Serviio DLNA media streaming server v 1.6 (rev. 9a1458ed77db)
2016-03-19 17:49:09,933 INFO  [MediaServer] Petr Nejedly 2009-2015
2016-03-19 17:49:09,933 INFO  [MediaServer] http://www.serviio.org
2016-03-19 17:49:09,933 INFO  [MediaServer] Java 1.8.0_40-Oracle Corporation x86
2016-03-19 17:49:09,933 INFO  [MediaServer] OS Windows 8 6.2
2016-03-19 17:49:09,933 INFO  [MediaServer] File encoding: windows-1250
2016-03-19 17:49:09,933 INFO  [MediaServer] Headless mode enabled: true
2016-03-19 17:49:09,933 INFO  [MediaServer] User: KAROL-KOMPUTER$
2016-03-19 17:49:09,934 INFO  [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2016-03-19 17:49:09,934 INFO  [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2016-03-19 17:49:09,934 INFO  [MediaServer] ------------------------------------------------------------------------
2016-03-19 17:49:10,029 INFO  [WebServer] Socket buffer set to 65535 bytes
2016-03-19 17:49:10,029 INFO  [RestletServer] Starting Restlet server (/console) exposed on port 23423
2016-03-19 17:49:10,032 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2016-03-19 17:49:10,150 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2016-03-19 17:49:10,150 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2016-03-19 17:49:10,163 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-03-19 17:49:10,170 INFO  [DatabaseManager] Using DERBY database language
2016-03-19 17:49:21,531 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2016-03-19 17:49:29,041 INFO  [DBSchemaUpdateExecutor] Dropping search index
2016-03-19 17:49:29,043 INFO  [SearchManager] Starting up search engine
2016-03-19 17:49:29,269 INFO  [DBSchemaUpdateExecutor] Cleaning temporary cache
2016-03-19 17:49:29,329 INFO  [Device] Created UPnP Device with UUID: d14fca63-b55b-3a04-ac7c-b3bc11378a31, bound address: 192.168.1.206
2016-03-19 17:49:29,401 INFO  [DBSchemaUpdateExecutor] Cleaning persistent cache
2016-03-19 17:49:29,411 WARN  [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2016-03-19 17:49:29,487 INFO  [MediaServer] ------------------------------------------------------------------------
2016-03-19 17:49:29,487 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2016-03-19 17:49:29,623 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2016-03-19 17:49:29,671 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-03-19 17:49:29,676 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-03-19 17:49:29,678 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-03-19 17:49:29,678 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-03-19 17:49:29,679 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-03-19 17:49:29,679 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-03-19 17:49:29,681 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-03-19 17:49:29,682 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-03-19 17:49:29,682 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-03-19 17:49:29,682 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-03-19 17:49:29,683 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-03-19 17:49:29,683 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-03-19 17:49:29,684 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-03-19 17:49:29,685 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-03-19 17:49:29,685 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-03-19 17:49:29,685 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-03-19 17:49:29,686 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-03-19 17:49:29,686 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-03-19 17:49:29,686 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-03-19 17:49:29,686 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-03-19 17:49:29,687 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-03-19 17:49:29,687 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-03-19 17:49:29,688 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-03-19 17:49:29,688 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-03-19 17:49:29,688 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-03-19 17:49:29,688 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-03-19 17:49:29,688 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-03-19 17:49:29,688 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-03-19 17:49:29,689 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-03-19 17:49:29,689 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-03-19 17:49:29,689 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-03-19 17:49:29,689 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-03-19 17:49:29,690 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-03-19 17:49:29,690 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-03-19 17:49:29,690 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-03-19 17:49:29,690 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-03-19 17:49:29,690 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-03-19 17:49:29,690 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-03-19 17:49:29,691 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-03-19 17:49:29,691 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-03-19 17:49:29,691 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-03-19 17:49:29,691 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-03-19 17:49:29,692 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-03-19 17:49:29,692 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-03-19 17:49:29,692 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-03-19 17:49:29,692 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-03-19 17:49:29,693 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-03-19 17:49:29,693 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-03-19 17:49:29,693 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-03-19 17:49:29,693 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-03-19 17:49:29,706 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2016-03-19 17:49:29,707 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-03-19 17:49:29,707 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-03-19 17:49:29,707 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-03-19 17:49:29,708 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-03-19 17:49:29,708 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-03-19 17:49:29,708 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-03-19 17:49:29,708 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-03-19 17:49:29,708 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-03-19 17:49:29,709 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-03-19 17:49:29,709 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-03-19 17:49:29,719 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2016-03-19 17:49:29,719 INFO  [PluginCompilerThread] Started looking for plugins
2016-03-19 17:49:29,720 INFO  [UpdateChecker] Checking if a new version is available
2016-03-19 17:49:29,987 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2016-03-19 17:49:30,086 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-03-19 17:49:30,110 INFO  [WebServer] WebServer starting on port 8895
2016-03-19 17:49:30,132 INFO  [Device] Updated bound IP address of Device with UUID: d14fca63-b55b-3a04-ac7c-b3bc11378a31, bound address: 192.168.1.206
2016-03-19 17:49:30,135 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2016-03-19 17:49:30,135 INFO  [EventDispatcher] Starting EventDispatcher
2016-03-19 17:49:30,135 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-03-19 17:49:30,137 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2016-03-19 17:49:30,146 INFO  [RendererSearchSender] Searching for Renderer devices
2016-03-19 17:49:30,146 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Intel(R) 82579V Gigabit Network Connection) and address 192.168.1.206, timeout = 0
2016-03-19 17:49:30,217 INFO  [RendererManager] Stored a new renderer: uuid='9df6cab3-4da8-4944-8f8f-21eed4a82b6b', name = 'Unrecognized device', ipAddress='192.168.1.1', profile = '1', accessGroupId = '1'
2016-03-19 17:49:30,907 INFO  [RendererManager] Stored a new renderer: uuid='16932acf-a674-480b-9eb8-da36716cd904', name = 'Sony BDP-Sx70/SMP-N100 (2010)', ipAddress='192.168.1.202', profile = 'bdp2010', accessGroupId = '1'
2016-03-19 17:49:35,436 INFO  [RendererManager] Stored a new renderer: uuid='bbc16c92-7022-4f02-80ad-dc46213225cb', name = 'Unrecognized device', ipAddress='192.168.1.13', profile = '1', accessGroupId = '1'
2016-03-19 17:49:55,925 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2016-03-19 17:49:56,164 INFO  [FeedUpdaterWorker] Started looking for information about online resources
2016-03-19 17:49:56,164 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2016-03-19 17:49:56,194 INFO  [LocalLibraryManager] Starting automatic library scan
2016-03-19 17:49:56,196 INFO  [LibraryDeltaScanner] Starting the library delta scan
2016-03-19 17:49:56,196 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2016-03-19 17:52:09,883 WARN  [PluginCompilerThread] Plugin Youtube.groovy failed to compile: startup failed:
C:\Program Files\Serviio\plugins\Youtube.groovy: 33: unexpected token: ** @ line 33, column 23.
         final api_key = *** API KEY HERE ***
I know it's something wrong with API Key but I have no idea how to solve it.
Windows 10 user, Sony Blueray as a DLNA client.
Serviio 1.6/Sony Blueray as DLNA Client
Post Sun Mar 20, 2016 12:05 pm
Re: Youtube doesn't work
Where did you get the plugin? This one should work: viewtopic.php?f=20&t=3276
Boncurek84
Post Sun Mar 20, 2016 2:19 pm
Hello, ZIP
Thanks for you quick respond.
I downloaded the youtube plugin from serviio forum.
Firefox plugin from Mozilla Appstore.
Do I have to use my own YT API V3 or I could use yours?
Post Sun Mar 20, 2016 2:25 pm
When you get the plugin from the main topic on the link above it already includes an API key. Use it as it is.
Boncurek84
Post Mon Mar 21, 2016 10:43 am
I haven't solved that problem yet?
Do I need my own YT API v3 ID? I'm asking about it, because when I opened youtube.groovy in notepad I found a passage about it?
How I can obtain it ?
It will be useful to have step by step instruction.
Post Mon Mar 21, 2016 11:04 am
As I said, download the plugin from the main article linked above. It includes the key already. You have probably some old version of the plugin.
Boncurek84
Post Tue Mar 22, 2016 5:06 pm
I've done everthing what you told me, but the problem still occurs.
Post Tue Mar 22, 2016 7:15 pm
can you post here the plugin you're using?
Boncurek84
Post Wed Mar 23, 2016 10:18 am
Problem was fixed. Everything is working smoothly now.
By the way, I e-mailed to ServiioTube creator and we found the reason:
Malfunction of Vimeo Plugin, so I had to delate all plugins and reinstall YT.groovy.
After reinstaling I rebooted serviio using services.msc.
Thanks for great support.
Return to User experiences
