Problem with windows 10
newby
Post Sun Dec 06, 2015 9:52 am
I have problems with windows 10 too.
I have post this message in a other folder too. this problem seems to grow.
I am a user since many years. after installation windows 10, serviio has a problem to send informations to samsung tv, and any other devices . i use android, apple, ps3 and samsung tv.
My configuration is: Windows 10 64bit Pro, GBit Lan, 3 Samsung TV, 2 x PS3, 4 Android Tablets, 1 Apple, Firewall and Virus Bitdefender Internet Security, 3 Showcenter, 2 Samsung Handys
all this devices are connect to serviio. i dont have any problems before.
my server has stored 100000 mp3 songs, and more as 8000 movies and round about 20000 photos.
the problem is, if i select movie by the name. in (A) i have 1000 movies. samsung bring me an error (cant reach server and so on)
if i select a name with 8 Movies, samsung tv show me the movies on screen.
in web-server (firefox) the section with (A), the screen fills very slow with the pictures (of movies).
Before i usw windows 10 it goes fast....
i have reinstall the serviio, virus scanner, firewall, and then i have reinstall windows 10. it was not better!!
at last, i have test plex.... it works okay. (butt it is no programm for me, only testing)
do anyone other have same problems? can it be... the firewall close any ports????
Post Sun Dec 06, 2015 11:00 pm
Re: Problem with windows 10
It's possible that there's a port issue, but I doubt it. When I updated my Serviio computer to Win 10 I decided to do a clean install, so there was nothing left from the previous configuration. I just ran the Serviio install and everything worked. I have not made any changes to the firewall. I just looked at my settings, and I see the firewall is enabled, and Serviio is not listed as an approved application. But if I go into the Advanced Settings, Serviio is listed as approved. :o
I don't have as many files as you do, so I don't know if you're running into some sort of limitation of DLNA or Serviio. I have 728 movie files, and other than a slight time lag to load I see them all under the Movies category (which shows all titles without the grouping by alphabet).
Post Mon Dec 07, 2015 12:37 am
I don't think this is a Serviio issue, or a Windows 10 one, but a Samsung one.... see viewtopic.php?f=3&t=3009. Samsung's have a limit of 1,000 items in a folder (do you really have 1,000 movies starting with "A" ??? - wow!)
As for other devices filling the screen slowly, does it still do this. It could be that Serviio was re-indexing the files in the library at the time (which it will do on a new version, new install - and give the size of your library this is going to take time).
newby
Post Mon Dec 07, 2015 6:55 pm
Okay,
I have tested with new installation.
Fill my database with some files. Max 200 items per letter. And it works.
If I search for the complete files, I run into an error. On every hardware. Android to.
It must be a problem how much items are in the database.
This is a real problem vor me. Other people have many more files in there servers.
Hmmm
Post Tue Dec 08, 2015 12:09 am
I don't have enough movies to reach over 200 per letter (wow is right!), but I do have playlists with over 200 entries. I don't have any issues to my knowledge. I'll have to double-check it on my Samsung TV.
I'm not sure I understand how you "search for the complete files". Are you referring to viewing the Movies category, which displays all titles? How many total titles are you talking about? Like I said, I have just over 700 movie titles, and have no problem displaying them all on any device, including the Roku players. I don't get any error messages. And this is from my main Serviio computer running Windows 10 Pro.
newby
Post Tue Dec 08, 2015 7:57 pm
i mean, i have start serviio and refresh the complete database. i go into serviio (TITLE) and then into (A) for all movies beginning with the letter (A).
Okay.... if i select names with (D), i have 1600 Movies inside. In German, all movies beginn with a (D) "Das Dschungelbuch" "Die goldene Gans" and so on.
I am in beta forum and send a logfile (Short File). In this file i have test a samsung tv, a android tablet. All with errors.
newby
Post Sat Dec 12, 2015 5:06 pm
All errors solved.
every device work okay.
Return to User experiences
