Compatible devices list
What is the DLNA device you use Serviio with?
Samsung TV
239
30%
Sony TV
100
12%
Panasonic TV
64
8%
Other TV
41
5%
WDTV Live
51
6%
LG BD-xxx
21
3%
XBox 360
51
6%
Playstation 3
82
10%
Other (specify in the forum please)
161
20%
Total votes : 810
David57
Post Wed Jun 16, 2010 3:43 am
Re: Compatible devices list
A Sony BDP-S370 with the new DLNA enabled FW.
Device is stated as PS3.
How did you get this to work? My Sony BDP-S470 (basically the same machine) sees the Serviio server, but (1) only lists it under photos and audio, not video, and (2) returns the message "there is no playable file" for every folder.
jonband
Post Sun Jun 27, 2010 4:41 am
Same here .... trying to play mkv files on my bdp-s470 using the following profile (as recommended in another thread):
<Profile id="9" name="Sony BDP-S470" extendsProfileId="1">
<Detection>
<X-AV-Client-Info>.*Blu-ray Disc Player.*</X-AV-Client-Info>
</Detection>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/divx">MATROSKA</MediaFormatProfile>
</MediaFormatProfiles>
Serviio server shows up under "pictures" and "music" but not video. I'm using Serviio v 0.4.1.
Any ideas?
arnoud
Post Thu Jul 08, 2010 7:34 pm
I am running serviio on the following hardware:
- Mac Pro (8-core 2008 model, 8GB RAM, 10.6.4, etc)
- Samsung UE46C7700 3D LED TV + wireless dongle
- Samsung HT-Z222 home theather set (for sound only)
I have disabled all transcoding in serviio console, and I am fully enjoying it!
The TV could be a bit more intelligent that it would remember that I do not want PCM audio from the TV to the HT-set (over SPDIF optical) but Dolby or DTS, but apart from that: great stuff!
nobodie14
Post Sat Jul 10, 2010 7:47 am
Works very well on a Philips 32PFL7605H/12.
Setup:
- Serviio running on Windows 2000 Advanced Server (2.4 Ghz processor, 2 Gb memory)
- Ethernet cable
- Philips 32PFL7605H/12
It is the TV set itself that's causing problems:
1. AVI: movies are not playable as is. I can't find the right combination to let Serviio stream the .avi as is to the TV Set. Serviio has now been set to transcode .avi to mpeg2. ffmpeg is consuming all processor resources.
2. AVI: srt subtitles are not recognized.
3. DVD: .ifo are not recognized. No menu, no language or subtitle selection possible. It is only possible to play .vob one after another.
4. Artwork: dvdcover.jpg, folder.jpg etc. are not recognized.
leftycurve
Post Mon Jul 19, 2010 10:35 pm
enigma9o7 wrote:Samsung BD-C5500 (Bluray Disc Player).
rickinco wrote:It works out of the box with my Samsung BD-C5500 Blu-ray player which means it should also work with the BD-C6500 as well. For having such a short shelf life this project is extremely polished, amazing work by one person! Thanks a lot. I hope I can contribute to your efforts in the future. The firmware on these devices is a moving target at this point, they are really new.
Britinva wrote:Ditto on Samsung BD-C5500 Bluray Disc Player....... should mean the C6500 and C6900 will be OK too
Just select the WiselinkPro profile and ensure you stop/start the Serviio server
Steve wrote:I'm using a Samsung BD-c5500 bluray player.
Videos are detected fine, but audio files are not detecting for me. The structure of the folders containing audio files is available to browse, but the content is not visible. Transcoding fails for very few videos.
Sometimes Serviio will go through a spat of disconnecting constantly, then becomes stable again. I don't know if it's related, but times I've noticed it have been after saving changes to the shared folder settings.
Another Samsung BD-C5500C Blu-Ray Player user here. I reported my issue with my Sony DSC-P200 Digital Camera .mp4 videos. Other than that I couldn't be more more pleased with streaming of other .mp4s, .avis, .mp3s and .jpgs. I've come across a couple .wmv files that wouldn't play.
In general it seems pretty reliable.
dodgyd
Post Tue Jul 20, 2010 12:21 pm
Hi, I'm new so be nice....
I installed serviio on recommendation from a friend as an alternative to Samsung's software to serve media to my samsung ps50c7000.
The TV supports mkv, but if I try and play one, the TV reports, "Not Supported File Format". I have tried the automatic render profile and the Samsung wiselink profile.
Instead I have to serve it via my PS3.
Anyone have any suggestions?
Post Tue Jul 20, 2010 12:23 pm
It should work if you select the Samsung C-series profile (don't forget to click Save button).
Belfaborac
Post Mon Jul 26, 2010 6:42 am
First and foremost, thank you so much for this excellent program! Simplicity itself to set up and it works great "out of the box". Like a few other people I use it to serve a Samsung BD-C5500 and I have had no problems whatsoever (although I haven't tested subtitles yet...).
Post Mon Aug 02, 2010 7:16 am
Serviio is compatible with Sony Bravia TV EX500 and Sony Blu-ray Disc Player BDP-S370, great!!
tomhoh
Post Wed Sep 08, 2010 2:11 am
Samsung LN52A750. Works great with the following changes to profiles. xml under Wiselink pro A series
<Profile id="5" name="Samsung WiselinkPro (A-series)" extendsProfileId="2">
<MediaFormatProfile mime-type="video/x-divx">AVI</MediaFormatProfile>
<Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="mp4" />
<Matches container="asf" />
Also if encoding videos from handbrake with ffmpeg only encode with the aac audio stream as encoding with 2 audio streams (aac and ac3) will result in no sound from serviio's ffmpeg transcoding.
Sony Bravia KDL-40HX701. Works great with the Wiselink pro A series profile listed above
tomhoh
Post Wed Sep 08, 2010 2:12 am
Sony Bravia KDL-40HX701. Works great with the following changes to profiles. xml under Wiselink pro A series
aldero99
Post Thu Sep 09, 2010 7:14 pm
I've collected the Sink info you requested .....
Hope it helps in developing Serviio further.
I have a Samsung ue32c6000 LED TV and below is the sink string
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_912;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,http-get:*:image/jpeg:*,http-get:*:audio/mpeg:*,http-get:*:video/x-msvideo:*,http-get:*:video/x-ms-asf:*,http-get:*:video/x-divx:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-mkv:*,http-get:*:video/mp4:*,http-get:*:video/x-avi:*,http-get:*:video/avi:*,http-get:*:video/x-flv:*,http-get:*:video/mpeg:*,http-get:*:video/3gpp:*
Greetings Alexander
prikkie
Post Tue Sep 21, 2010 11:14 am
Works with Samsung LE40C650 AND Mac. Pause works, FF works in audio.
jcbyte
Post Sun Sep 26, 2010 12:35 am
zip wrote:Hey guys,
it'd be cool if we could compile a list of devices that can connect to Serviio and work properly with it. Just reply to this topic with your observations.
I am using a Samsung HT-C6600 Blu Ray Home Theatre. I tried Samsung AllShare and Serviio works much better. Keep up the great work.
JC
drac
Post Tue Sep 28, 2010 7:34 pm
works fine with LE32C650, thanks for the subtitle support in 0.4.2!
movie metadata autodetection is sometimes hit-and-miss.
mjohnsonaz74
Post Mon Oct 04, 2010 4:08 am
I got it running on my Sony Blu-Ray player (BDP-S570) on Windows 7 64bit pretty easily. I will note that, according to the U.S. manual, you can only stream MPEG-2 (.mpg, .mpeg, .m2ts, and .mts) from a DLNA server and then only in standard definition. Also, according to the manual, DivX (.avi, and .asf) only work on Canadien models. This is strictly from the manual and I haven't tested these claims yet, but I'll be encoding my movies in MPEG-2 to avoid any streaming issues. For other movie types, you'll need to transcode.
Post Mon Oct 04, 2010 11:55 am
Look at the thread about the player here, I think it's possible to play other formats, you just need to change the profile to send mpeg2 mime type.
hyghnet
Post Fri Oct 08, 2010 7:05 am
works with LE40C679 and subtitle support, FF not work, sometimes movie metadata autodetection is miss.
c-o-m-m-a-n-d-e-r
Post Sat Oct 09, 2010 7:01 pm
iPad would be cool... :)
Chaos, panik, disorder ... My work here is done
n3mmr
Post Tue Oct 12, 2010 10:34 am
zip wrote:Hey guys,
The media player functionality on an Argon iNet 1 internet radio picks up serviio as a UpNP server, provided serviio is configured to autodetect profiles.
If Serviio could be cajoled into serving wav audio files, everything would be perfect.
Return to User experiences
