Servio Hang when streaming HEVC
Nexist418
Post Mon Apr 19, 2021 9:51 pm
Re: Servio Hang when streaming HEVC
atc98092 wrote:The way it "looks" is controlled by the player, not Serviio. When it was burned in, then Serviio had control. So you're most likely stuck with the way it looks, unless you can find some settings in your player to change the appearance. Roku does have some caption controls, but I'm not certain if it can make it look the way you'd prefer. If you're using RMP as your player, your caption settings are under the main Roku Settings menu, not within RMP itself.
Also, my system has an i7 3.0Ghz 4 Core with 16G of RAM, is that really something that should be getting bogged down while transcoding?
Post Mon Apr 19, 2021 11:29 pm
I certainly wouldn't think so. That should be a great transcoding machine. I've never tried transcoding H.265 to anything else, so no idea what sort of power it actually requires. But I'm pretty sure burning subtitles takes a lot of power.
Previous
