change serviio port
leandro1979
Post Mon Dec 24, 2012 7:09 pm
change serviio port
Hi
how can i change serviio port default and how configure the mediabrowser redirect server
example
201.x.x.x:8081
how can change serviio configuration to change access mediabrowser
thanks
leandro
Post Tue Dec 25, 2012 10:31 am
Re: change serviio port
You can't change the local 23424 port, unless you wrap it in an Apache web server or similar. For remote access, you can forward port 8081 on the router to the local 23424 port on the Serviio machine.
leandro1979
Post Tue Dec 25, 2012 2:45 pm
Thanks for reply
jaybird23059
Post Sun Jun 19, 2016 12:29 pm
So, you can't change the port on serviio, but someone suggested forwarding to a different port on another machine. I can't figure out how to do that. Can someone point me to a link?
Return to General discussion
