iMac goes standby while streaming??
betilebra85
Post Mon Dec 13, 2021 4:47 pm
Hello everyone, I’m a new user of Serviio with pro features. On my iMac Pro I run both Plex and Serviio because I need 2 separate libraries. My iMac is programmed to go standby after 15 minutes it’s idle. I usually do the following:
Running Plex, and the computer is turning on automatically. I play a video till the end, iMac stays up until is finished then goes standby. With Serviio is almost the same, I search the device with my DLNA clients but the computer goes standby right after a minute streaming. Anyone have the same or can forward me to an existing topic about this issue? Thank you!Tweakbox Appvalley https://vlc.onl
irwinnick99
Post Wed Jan 26, 2022 2:53 am
Re: iMac goes standby while streaming??
betilebra85 wrote:Hello everyone, I’m a new user of Serviio with pro features. On my iMac Pro I run both Plex and Serviio because I need 2 separate libraries. My iMac is programmed to go standby after 15 minutes it’s idle. I usually do the following:
To fix this very problem, please go to System Preferences first. Then select Energy Saver, and make sure these two options are selected: "Prevent computer from sleeping automatically when the display is off" and "Wake for Wi-Fi network access". And the option "Put hard disks to sleep when possible" is off.
nathandev
Post Wed Mar 09, 2022 12:01 pm
Yes that's an accurate solution I have already done so.
Return to General discussion
