Default password on Remote server !!
dolomats
Post Thu Jul 28, 2016 11:08 pm
Hi
I just finished installing Serviio on my remote server for personal use evrything went fine.
Until the login page it s asking me for a password !!!
Is there a default password ?
Or I m not allowed to host it on a public server ?
Post Fri Jul 29, 2016 8:44 am
Re: Default password on Remote server !!
If you mean in MediaBrowser, you need to set the password in the Console.
dolomats
Post Fri Jul 29, 2016 9:04 am
That's good it mean i can use it in my remote public server for a personal use.
but how can i change the password in the console please
Post Fri Jul 29, 2016 3:10 pm
In the console, select Remote section and enter the password there + click Save.
dolomats
Post Fri Jul 29, 2016 7:37 pm
I see.
But i forgot to mention that i m on CentOs only on Command line dont have have graphic destop installed on it so i wont be able to install the console !!!
Post Sat Jul 30, 2016 2:15 am
dolomats wrote:I see.
There's nothing to install for a console. It is now completely web based. Use any browser on your network and use the CentOS IP address in the browser:
http://IP-Address:23423/console
There's no password to the console, so you can access it from any computer on the network.
dolomats
Post Sat Jul 30, 2016 2:56 am
hey thanks for the help
when i go to the console now i get this message :
Not Found
The server has not found anything matching the request URI
You can get technical details here.
Please continue your visit at our home page.
dolomats
Post Tue Aug 02, 2016 8:41 pm
Thumb up !!!!
still stuck and need help please.
Post Tue Aug 02, 2016 11:48 pm
Looks like someone else will have to help now. I'm not familiar with Linux installations.
Post Wed Aug 03, 2016 2:49 am
What version of Serviio are you using:
  • If 1.6+ then access the console as per atc98092's post
  • If an earlier version, consider upgrading for a whole lot of reasons
  • If you cannot, then you need to install the old Console App (for the same version as your Serviio server) on a PC and then point it to the IP address of your Serviio machine. There were some instructions on this in the wiki but they have been remove (or at least I can't find them) - here is a well written reference from beckos for it (for a Synology NAS but same principle applies - I dont know that step 4 is required): https://forum.synology.com/enu/viewtopi ... 15#p143526
dolomats
Post Thu Aug 04, 2016 6:12 pm
I finnaly found a solution for my issue.
i had to download a separate script that is the console (no one told me that the console is separate :shock: was thinking it s built in)
So i downloaded the console and installed apache and php coz i dind't know that it's a required :cry: :oops:
And then i got it the precious CONSOLE that i used to set the password.
thanks guy's
Return to General discussion
