Check Stream URL never works.
fidmas
Post Fri May 06, 2016 10:39 pm
For example, http://streaming208.radionomy.com:80/Th ... sRadioShow audio stream plays just fine, but the [Check Stream URL] console button running in Firefox, spins for a while and reports the stream is no good.
Post Sat May 07, 2016 8:10 am
Re: Check Stream URL never works.
It works for me. make sure you select that it's an Audio online resource before hitting the check URL button.
fidmas
Post Sat May 07, 2016 1:11 pm
It's an Audio Live Stream and It's all correct. Firefox 34.0.5 on the 2GHz XP Pro box may have something to do with it. The 'CHECK' button spins for ~130 Seconds while Firefox uses 95% to 99% of the P4 CPU. Plays fine on the Sony Bravia.
Post Sun May 08, 2016 12:39 pm
As with all problems, you need to post a detailed log. It will show the ffmpeg command that checks the link and show what is happening.
fidmas
Post Sun May 08, 2016 1:22 pm
I'll turn 'debug' on later, but for now, does it help that ffmpeg never started while the [Check stream URL] was spinning? The normal log had no mention of the radionomy URL. Also, every time I attach a 5 minute debug log, people complain it's too big to read with Notepad. :-(
fidmas
Post Sun May 08, 2016 7:32 pm
As expected, attached is the detail log for a 4 minute period encompassing to time wile the [Check stream URL] button was spinning.
(327 Bytes) Downloaded 875 times
fidmas
Post Mon May 09, 2016 7:42 pm
I updated Firefox. No change. Tried an old Chrome. Same but didn't spin as long.
Post Sat May 21, 2016 1:41 pm
You uploaded wrong detail log..only 327 bytes
fidmas
Post Sat May 21, 2016 2:14 pm
Yes! I understand! I had prove that the the Serviio service never saw the console's request. The log I sent is ALL that happened while the [Check Stream URL] console button was 'spinning' in the Firefox browser. Get it?
Post Mon May 23, 2016 12:45 pm
fidmas wrote:Yes! I understand! I had prove that the the Serviio service never saw the console's request. The log I sent is ALL that happened while the [Check Stream URL] console button was 'spinning' in the Firefox browser. Get it?
No, you don't understand. That log is incomplete. Anyone that tries to help need additional detail from a debug log. That isn't sufficient.
fidmas
Post Mon May 23, 2016 1:13 pm
During the time the [Check Stream URL] spins, the Serviio service doesn't do a damn thing. The button icon spins. The Firefox container uses 99% of the CPU for 90 seconds and reports a failure. I included the log encompassing that time interval to prove it. Later, I'll zip up a complete 30 minute log to show that the service never gets asked to do anything. Please don't tell me again it's too big. One can examine the log all day long. The problem has to be in the console.
fidmas
Post Mon May 23, 2016 3:38 pm
OK. This is insane. Serviio started around 10:30. Stream checked and failed at 10:46. Again at 11:10. I don't see anything in the logs before I shut it down.
log.zip
(16.6 KiB) Downloaded 705 times
fidmas
Post Wed May 25, 2016 2:02 pm
I didn't like the previous logs I uploaded, so i deleted all log files, started serviio at 8:30, attempted to check the stream at 9:32, and stopped serviio around 9:45. I see nothing in the logs, but here they are.
log.zip
(12.32 KiB) Downloaded 697 times
Return to General discussion
