New to all this, help needed
rathsach
Post Sun Dec 26, 2010 11:38 am
Hi
Wife gave me a LG BD570 for x-mas. It works, but not as i want it to, maybe because i expect something that cannon be done.
It came with Nero MediaHome 4 but somehow i ended up using Serviio. Basically they can do the same thing.
Problem is playing dvd from files on a harddisk, eg. VIDEO_TS and AUDIO_TS structure with all the various files in those, ifo, vob etc.. I can start the vob files, but i can't change subtitles anywhere. Is that something the server should be capable of handling, or is it my player?
Regards
Rathsach
Post Sun Dec 26, 2010 11:45 am
Re: New to all this, help needed
The player. A server might be able to burn the subtitles in the video stream, but Serviio cannot do that.
rathsach
Post Sun Dec 26, 2010 12:35 pm
*sighs*
Thanks for the quick answer. Now i have no idea what to use the player for :D Wife has little to none UK skills, so subtitles is a must have.
Cheers & happy new year.
Post Sun Dec 26, 2010 1:07 pm
The player supports srt subs, if you get them you can use them (although not sure how it would work with the DVD files)
Return to General discussion
