Sources of serviio
geniusit
Post Tue Dec 21, 2010 10:47 pm
Sources of serviio
Hi all, I want to thank you about this software, I installed it on my Qnap TS-419 and work great, I was looking for dlna server on qnap that read srt files too, in cyrillic too! It's amazing, anyway, I would like to ask, but the sources of serviio java are available or can't be modified? Another thing is I can change the language (in my samsung tv I have dir in english, I would like to change it) and can I change the name of server over the upnp network? Thanks in advance
Serviio 1.0.1 - Qnap TS-419P (8TB) - Samsung UE55C8000XP - Network cables Cat.7 for all House (no wifi)
Post Wed Dec 22, 2010 7:36 pm
Re: Sources of serviio
It's closed source, but you can decompile it and change the code for your own use. Language support is coming in 0.5. Server name you should be able to change in profiles.xml (although I never tried ;-) )
Return to General discussion
