Howto Use Playlists
I kind pointer on where to RTFM (with detail on where to look in the document) would be appreciated.
servant74 wrote:Using "Playlist Creator" worked. It needs windows to run, so I had to go find a winders machine. Then copy the generated playlist into one of the directories already know to serviio.
