Username/Password
jnickel
Post Fri Apr 29, 2016 7:27 pm
Username/Password
Any possibility of having multiple username/passwords to access the Mediabrowser?
I would prefer to have multiple users instead of giving everyone the same password.
Jim
unixwise
Post Thu May 12, 2016 4:46 am
Re: Username/Password
on top of username/password, I'd love to see if a role base security model could be added, cheers
suykast
Post Tue May 17, 2016 3:43 am
And a log who is logged in and watch/listen what, that would be also great because i'm streaming on my wan port and linux/windows or synology doesnt what our whos connected
A LDAP is a option
Post Tue May 17, 2016 12:16 pm
I believe all three of these have been requested before. These are documented at https://bitbucket.org/xnejp03/serviio/issues/ and you can search for our particular request. There's currently 154 open issues. Some are bugs, and others are enhancement requests such as this.
If you can't find a request that matches what you're requesting, submitting a request there makes it easier for Zip to keep track of them.
Juarlyn
Post Thu Jul 07, 2016 1:02 am
tc98092 Hi , If you can perfectly take full monitoring of users and passwords for ingrasar add to the server, only need to use the best network pfsense Administrator Tool.
With pfsense will be to create a captive portal to assign username and password and avoid multi connections etc. Pfsense is a world of possibilities for aministracion your network .
Post Thu Jul 07, 2016 12:41 pm
Juarlyn wrote:tc98092 Hi , If you can perfectly take full monitoring of users and passwords for ingrasar add to the server, only need to use the best network pfsense Administrator Tool.
My apologies, but I can't quite follow what you wrote. I believe you are referring to a 3rd party tool for controlling login. I'm not a developer for Serviio, just a user like yourself. Hopefully Zip will see your post and understand the reference you are making.
Juarlyn
Post Fri Jul 08, 2016 12:33 am
I feel much not able to explain well because use translation and is very difficult for me, pfsense is a erramienda independent, here I leave a link for pfsense. https://m.youtube.com/watch?v=B6Hjxd1Af-s. :)
Return to Feature requests
