Secure Web Access
loeffelpan
Post Sun Mar 13, 2016 2:15 pm
Secure Web Access
Just thought about getting Serviio Pro for my Windows NAS-Server.
But i'm not sure because of the Internet-Access.
I tested forwarding Port 23423 in my router and got that working for me.
But I was wondering that remote access to http://<ip>:23423/console is unrestricted?
Therefore anyone knowing my DNS-Name or IP can access Serviio's console to change config or start and stop the Server!
Serious? Please change console to another port or make it accessable by password like mediabrowser.
Additionally I need SSL-Support for Remote Access.
Post Sun Mar 13, 2016 11:24 pm
Re: Secure Web Access
HTTPS support coming next version. You will need a grunty server to do this (particularly if also transcoding), so it will depend on the specs of your NAS.
AFAIK there are no plans to add a password or user-selectable port to the console. The console is designed to run within a secure environment (your LAN). If you want to extend the console to the internet, then you should look at an external program to provide security - eg. a reverse-proxy which can then provide password support and allow you to use a different port.
Post Mon Mar 14, 2016 10:28 am
Usually you won't open the console port (23423) on your router... why would you need to do that?
loeffelpan
Post Mon Mar 14, 2016 8:31 pm
Oooooh! :cry:
Blind man posting stupid things.
I just noticed, that console is on 23423 and mediabrowser is on 23424.
Of course i didn't want to forward console Port, just mediabrowser for Internet access.
Thanks for aswering stupid questions and giving SSL support with next release.
*close*
stephendhill
Post Wed Aug 31, 2016 8:29 am
The idea that your LAN is secure is a fallacy these days. Most people have lots of devices running on their LAN that they have no control over and never will. The IoT will only make this situation worse.
Avid Serviio user
Pure Flow One | Samsung LE40B650 | Samsung UE40F6320 | Sony PS3 | Ubuntu 14.04
Return to Feature requests
