Support for Philips 42FPL7655
okkiwan
Post Wed Jul 20, 2011 4:20 pm
Dear all,
Could you please let me know if it's possible to get Serviio working on that TV model? I can see the shared files but the TV does not support the format. As suggested by 'zip', here's the information you could need. Thanks in advance.
GetProtocolInfo results
http-get*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,
http-get*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,
http-get*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get*:audio/x-ms-asf:*,
http-get*:audio/wav:*,
http-get*:audio/x-ms-wma:*,
http-get*:audio/vnd.dlna.adts:*,
http-get*:audio/mp4:*,
http-get*:video/x-matroska:*,
http-get*:video/x-ms-asf:*,
http-get*:video/x-ms-asf-plugin:*,
http-get*:video/mpeg4:*,
http-get*:video/avi:*,
http-get*:video/x-ms-avi:*,
http-get*:video/msvideo:*,
http-get*:video/x-msvideo:*,
http-get*:video/h264:*,
http-get*:video/x-ms-wmv:*
DLNA Test Certificate
Please see file attached.
REG08350541.pdf
(98.28 KiB) Downloaded 995 times
Post Wed Jul 20, 2011 6:44 pm
Re: Support for Philips 42FPL7655
Thanks,
Could you with INTEL TOOL provide Xml Device Description?
or
Could you enable detailed logging file (see signature) and post the log file? (to clean the log file, rename or delete log file and restart serviio service)
You could start with Generic Profile, inform file that work (MPEG_PS (vob), MPEG_TS, etc), and inform file that failed and we try to create a specific profile.
Post Wed Jul 20, 2011 6:49 pm
After that, if with Generic profile its failed, try this:
viewtopic.php?f=5&t=2231&p=14911&hilit=Philips#p12870
okkiwan
Post Wed Jul 20, 2011 10:12 pm
Illico wrote:Thanks,
or
Please find the XML Device Description attached below.
Best regards,
Sergio
nmrDescription.xml
(2.26 KiB) Downloaded 1274 times
okkiwan
Post Wed Jul 20, 2011 11:10 pm
Illico wrote:After that, if with Generic profile its failed, try this:
Generic profile failed indeed, so I tried what is suggested on the thread and it seems to be working. I will perform additional tests to see if everything's working just fine (although no FF, RFF, but the first tests worked fine). Thank you!
Return to Philips
