Need help establishing profile for Philips 42PFL7406
norrgrd
Post Tue Oct 18, 2011 10:32 pm
Re: Need help establishing profile for Philips 42PFL7406
Yup!
<Profile id="21" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*PHILIPS.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="mp4" />
            <Matches container="mpegts" />
            <Matches container="mpegvideo" />
            <Matches container="asf" />
            <Matches container="ogg" />
            <Matches container="flv" />
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpeg" aCodec="aac" />
            <Matches container="mpeg" aCodec="mp3" />
            <Matches container="mpeg" aCodec="dca" />
is definitely the way to go!
Post Wed Oct 19, 2011 7:22 am
norrgrd wrote:is definitely the way to go!
Ok cool, let Zip to include this profile in the next release: posting.php?mode=quote&f=5&p=24603#pr24603
Did you test the external subtitle "srt" file feature?
Post Wed Oct 19, 2011 10:00 am
I'm a bit late to the discussion (so excuse me if it's been discussed) but is not transcoding everything to mpeg2 wrong?
Looking at the protocol info, the TV should support a range of video formats:
http-get:*:video/x-matroska:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-asf-plugin:*,
http-get:*:video/mpeg4:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-avi:*,
http-get:*:video/msvideo:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/h264:*,
http-get:*:video/x-ms-wmv:*
So something might be just a matter of changing mime-type..?
Post Wed Oct 19, 2011 10:06 am
You are right, I rushed after reading that...
norrgrd wrote:...The only thing I managed to play with the "Generic Profile" is .vob but there is no sound.
So
For AVI it seems ok with that
Now we have to test step-by-step all formats:
First MATROSKA "http-get:*:video/x-matroska:*"
We could try this:
    <Detection>
        <UPnPSearch>
        </UPnPSearch>
    </Detection>
        <MediaFormatProfile mime-type="video/x-matroska" name="">MATROSKA</MediaFormatProfile>
norrgrd
Post Mon Oct 24, 2011 5:48 pm
I am off for a while but will try ASAP.
supreme
Post Fri Oct 28, 2011 9:45 pm
I have a Philips 46PFL7605H/12 and now is working cool!!!! :D
The problem I was having about video with stop and go, with the Philips new firmware and the setup of the Netgear router, is solved, all now run fluently.
Firmware Philips: Q5551-0.140.46.0
Netgear Channel: 13
Netgear Mode: only G
I use Xilisoft Video Converter Ultimate to convert my video in Xvid-Mp3.
My Xilisoft Video Converter Ultimate 5.1.24 setup:
Codec: Xvid
Video Size: auto
Bitrate: 2500
Frame Rate: auto
Aspect Ratio: auto
Codec: Mp3
Bitrate: 128
S.Rate: 44100
Channels: 2
Audio Track: 1
[TV] Philips 46PFL7605H/12 [Wireless USB adapter] Philips PTA01 [Wireless Modem/Router] Netgear DG834GT
AndreasP
Post Sat Nov 12, 2011 4:37 pm
We could try this:......
Hi! I'm new to this and have just bought the Philips 47PFL7606.
I tried the above and avi and matroska works well.
I'm happy to help if there is something else you want to try.
A question: Why does the TV identifies as "NMR" in Device Name?
I hope the Philips TV will be implemented in the next version of this great program :roll:
Philips 47PFL7606T/12 | TViX HD M-6500A | VSX-808RDS
obstler42
Post Wed Dec 28, 2011 8:53 am
I recently acquired a Philips 7606K and it basically works very well with serviio: avi, mkv, mp4 play just fine as long as they don't contain DTS audio.
So the generic dlna profile needs to be extended for the following cases:
    avi/mkv/mp4 containing DTS audio -> transcode to mp3/ac3 audio (can it do audio transcoding only and remux with original video?)
    avi with mjpg video needs to be transcoded
    mov needs to be transcoded
I think this would be a good start for the recent 2011 Philips models with minimal transcoding (only unsupported formats).
any help with setting up these three points is appreciated ;)
Post Wed Dec 28, 2011 10:52 am
obstler42 wrote:I recently acquired a Philips 7606K and it basically works very well with serviio: avi, mkv, mp4 play just fine as long as they don't contain DTS audio.
These result are with "Generic" profile selected?
Could you check this and post result here?
viewtopic.php?f=5&t=19
obstler42
Post Wed Dec 28, 2011 11:19 am
Yes, this is with the generic profile.
I just checked the sink info with upnp spy and it is excatly the same as "Philips 37PFL7605H" on http://wiki.serviio.org/doku.php?id=devices_format_support , so I guess there's no need to post it again.
So those three problems mentioned previously should be a good start for a Philips TV 2011 profile. I will be able to test profile updates and provide further feedback on working/non-working files and issues.
BTW: is there a way to tell if serviio is transcoding or serving as-is videos on the device? Some other servers do stuff like adding (T) to the filename, or virtual folders for transcoding -- I'm not a big fan of transcoding videos and would like it to be used only as a last resort and am therefore always interested in knowing exactly what is happening to a file ;)
Post Wed Dec 28, 2011 2:08 pm
obstler42 wrote:So the generic dlna profile needs to be extended for the following cases:
you said mov needs to be transcoded, but not mp4.
mov/mp4 are similar containers, so there were probably a different in there video codec.
Could you provide "ffmpeg -i <filepath>" result with a mp4 that work and a mov file that doesn't work?
and what about flv, ogg, asf formats?
That should be something like this:
   <Profile id="20" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
         <!-- avi with mjpg video needs to be transcoded -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
            <Matches container="avi" vCodec="mjpeg"/>
         <!-- avi, mkv, mp4 play just fine as long as they don't contain DTS audio. -->
         <Video targetContainer="mpegts" targetACodec="ac3" >
            <Matches aCodec="dca" />
obstler42
Post Wed Dec 28, 2011 2:55 pm
Just checked the files, the MOVs that don't play also use the MJPEG codec. The other difference being that MOVs don't even show up on the TV, that's why I mentioned them without any codec info at first.
and you are right about flv, ogg, asf, of course, they need to be converted, too.
Regarding the DTS conversion you included: will that transcode the audio only (and leave the video portion as is)?
obstler42
Post Thu Dec 29, 2011 5:25 pm
I had some success with the following, adapted profile:
     <Detection>
       <UPnPSearch>
       </UPnPSearch>
     </Detection>
      <!-- unsupported codecs will be transcoded to mpegts with mpeg2video and ac3 audio -->
         <!-- digital camera video formats -->
       <!-- DTS audio needs to be transcoded -->
       <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="320" >
         <Matches container="avi" aCodec="dca" />
         <Matches container="mp4" aCodec="dca" />
The transcoded files play, however seeking does not work with these. When trying to seek the video just hangs, and I can't play any other video (no matter whether transcoded or not) for about two or three minutes.
transcoded MOV files now show up on the TV, however MJPEG AVIs (from a digital camera) don't even show up in the list of videos?
Previous
Return to Philips
