Toshiba BDX2250
rtm
Post Fri Feb 03, 2012 7:54 pm
Toshiba BDX2250
I need a little help I'm trying to create a profile I believe I'm doing this correctly.
http://certification.dlna.org/certs/REG61278371.pdf - that is the player
this is what I've done so far just removing the "eu" ones but I'm sort of lost any help would be appreciated.
http-get:*:audio/l16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:audio/mpegurl:*,
http-get:*:audio/mp3:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/mpeg3:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-avi:*,
http-get:*:video/mpeg:*,
http-get:*:video/avi:*,
http-get:*:video/mp4:*,
http-get:*:video/x-matroska:*,
http-get:*:video/3gpp:*,
http-get:*:video/x-msvideo:*
Post Fri Feb 03, 2012 7:57 pm
Re: Toshiba BDX2250
edited sink information is not helpful please can you paste the unedited sink infomration.
rtm
Post Fri Feb 03, 2012 8:01 pm
Re: Toshiba BDX2250
Cerberus wrote:edited sink information is not helpful please can you paste the unedited sink infomration.
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
But I got this out of the DLNA device support thread in this forum as my blu-ray player does not show up in Device spy.
Post Fri Feb 03, 2012 8:03 pm
Re: Toshiba BDX2250
then what did you mean by this comment ? :?
have you tried selecting the toshiba Regza profile with your device ??
rtm
Post Fri Feb 03, 2012 8:06 pm
Re: Toshiba BDX2250
Cerberus wrote:then what did you mean by this comment ? :?
Yes It gives me an error about MPEG PAL and says unsupported on the player.
Post Fri Feb 03, 2012 8:07 pm
Re: Toshiba BDX2250
are you in the states?
rtm
Post Fri Feb 03, 2012 8:08 pm
Re: Toshiba BDX2250
I apologize I was talking about mpeg eu
rtm
Post Fri Feb 03, 2012 8:13 pm
Re: Toshiba BDX2250
Yes I am in the states :D
rtm
Post Fri Feb 03, 2012 8:16 pm
Re: Toshiba BDX2250
Sorry for so many posts the error i get is "MPEG_PS_PAL*0:File Not Supported!"
Post Fri Feb 03, 2012 8:17 pm
Re: Toshiba BDX2250
explains alot :roll: :P
try this
<Profile id="25" name="Toshiba BDP" extendsProfileId="1">
   <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="aac" >
           <Matches container="mp4" />
           <Matches container="asf" />
           <Matches container="avi" />
           <Matches container="ogg" />
           <Matches container="flv" />
           <Matches container="3gp" />
           <Matches container="flac" />
           <Matches container="adts" />
        </Audio>
add that to you profiles.xml file and then restart serviio. Do your files now play?
rtm
Post Fri Feb 03, 2012 8:35 pm
Re: Toshiba BDX2250
I right clicked > show packaged contents > contents > resources > java > config > profiles.xml
Now I am getting an error that it's not running.
I'm thinking it might be something like this thats going on viewtopic.php?f=12&t=3449
I'm editing it in dash code, I added it after sony bravia 2009. I'm not 100% sure of what I'm doing.
This is what my profiles.xml looks like http://rus2.net/profiles.xml I renamed it to 22 from 25 when it wasn't working.
thanks a bunch for helping my retarded self
Post Fri Feb 03, 2012 8:57 pm
Re: Toshiba BDX2250
please confirm your using 0.6.2 of serviio or this profile file will not work.
profiles.xml
(58.87 KiB) Downloaded 1386 times
rtm
Post Fri Feb 03, 2012 9:03 pm
Re: Toshiba BDX2250
Cerberus wrote:please confirm your using 0.6.2 of serviio or this profile file will not work.
profiles.xml
Yes I am 0.6.2 and I just added your profiles.xml and it worked perfectly. THANKS A BUNCH! :D What had I don't wrong?
Post Fri Feb 03, 2012 9:04 pm
Re: Toshiba BDX2250
profiles.xml
*cough* typo on my part :( sorry.
Post Fri Feb 03, 2012 9:06 pm
Re: Toshiba BDX2250
does it now play your files ??
rtm
Post Fri Feb 03, 2012 9:07 pm
Re: Toshiba BDX2250
Oh haha I was looking and comparing it to the others profiles in their trying to figure out what was wrong I even put it in Microsoft Word and spell check incase it was a simple misspelling wow. Thanks I'm so happy now
rtm
Post Fri Feb 03, 2012 9:08 pm
Re: Toshiba BDX2250
Cerberus wrote:does it now play your files ??
I'm working on that haha
rtm
Post Fri Feb 03, 2012 9:11 pm
Re: Toshiba BDX2250
YESSSS it does it works thanks a bajillion!
Post Fri Feb 03, 2012 9:13 pm
Re: Toshiba BDX2250
test it hard for me over next few days and report back if it works on everything ZIP will add it as standard in next release. :)
rtm
Post Fri Feb 03, 2012 9:23 pm
Re: Toshiba BDX2250
Sure thing I think its the same software almost all the Toshiba BDP are based on so it will work for many people.
What should I set "Number of CPU cores to use" to if it has 2 cores but 4 virtual.
http://ark.intel.com/products/43544/Int ... e-2_53-GHz)
Return to Toshiba
