Error on plugin!!
ritzzen
Post Sat Feb 11, 2012 7:49 am
Error on plugin!!
Hi ,
I wrote a plugin to extract the image feed. But its failing with following error. Please help me to fix this. I am not very familiar with plugin code, just picked up existing one and tried to modify them. Appreciate any help.
Error log says
2012-02-11 02:18:59,959 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 138)
2012-02-11 02:18:59,960 DEBUG [OnlineLibraryManager] Resource http://feeds.feedburner.com/Pixses not in cache yet, loading it
2012-02-11 02:18:59,960 DEBUG [FeedParser] Parsing feed 'http://feeds.feedburner.com/Pixses'
2012-02-11 02:19:01,005 DEBUG [FeedParser] Found matching url extractor (PixsesURLextract) for resource http://feeds.feedburner.com/Pixses
2012-02-11 02:19:01,006 DEBUG [FeedItemUrlExtractor] PixsesURLextract: Starting extraction of url for item: NRI Beauty Preeti Desai Sizzles on Screen
2012-02-11 02:19:02,005 DEBUG [FeedItemUrlExtractor] PixsesURLextract: Extract URL: http://www.pixses.com/nri-beauty-preeti ... creen.html
2012-02-11 02:19:02,017 DEBUG [FeedItemUrlExtractor] PixsesURLextract: Finished extraction of url: ContentURLContainer [fileType=IMAGE, contentUrl=http://www.pixses.com/wp-content/uploads/preeti_desai_07.jpg, live=false, expiresImmediately=false, ]
2012-02-11 02:19:02,017 DEBUG [FeedParser] Cannot add feed entry of feed PIXSES | Hot Picture Special Collection because of invalid metadata. Message: Unknown online item image container.
And here is my plugin code
import org.serviio.library.metadata.*
import org.serviio.library.online.*
import org.serviio.util.*
/** Pixses.com content URL extractor plugin.
 * Based on Youtube.groovy by Petr Nejedly
 * @author Erwin Bovendeur
class PixsesURLextract extends FeedItemUrlExtractor {
   final VALID_FEED_URL = '^http://feeds.feedburner.com/Pixses*'
   String getExtractorName() {
      return getClass().getName();
   boolean extractorMatches(URL feedUrl) {
      return feedUrl ==~ VALID_FEED_URL;
   ContentURLContainer extractUrl(Map links, PreferredQuality requestedQuality) {
      def linkUrl = links.alternate != null ? links.alternate : links.default
                String pageHtml = linkUrl.getText()
                def seqVarMatcher = pageHtml =~ 'http://www.pixses.com/wp-content/uploads.+jpg'
                assert seqVarMatcher != null
                def contentUrl = seqVarMatcher[0]
      log("Extract URL: " + linkUrl)
      return new ContentURLContainer(fileType: MediaFileType.IMAGE, contentUrl: contentUrl)
   /* Groovy test method */
   static void main(args) {
      PixsesURLextract extractor = new PixsesURLextract()
      assert extractor.extractorMatches( new URL("http://feeds.feedburner.com/Pixses"))
      Map links = ['default': new URL("http://www.pixses.com/nri-beauty-preeti-desai-sizzles-on-screen.html")]
      ContentURLContainer result = extractor.extractUrl(links, PreferredQuality.MEDIUM)
      println "Result: $result"
Ritz
Post Sat Feb 11, 2012 1:01 pm
Re: Error on plugin!!
Plugin seems good, no ideas
ritzzen
Post Sat Feb 11, 2012 1:23 pm
Is there a different method to handle image feeds? I was thinking since i followed the plugin code from a video feed, so it is getting this kind of error for image feed.
'because of invalid metadata. Message: Unknown online item image container."
Post Sat Feb 11, 2012 1:34 pm
ritzzen wrote:'because of invalid metadata. Message: Unknown online item image container."
Yes, this is the error source...don't know why ... will ask to ZIP.
Post Sat Feb 11, 2012 2:28 pm
Oops, it's a bug which won't allow images properly processed when coming from plugins. I raised a ticket: https://bitbucket.org/xnejp03/serviio/i ... rt-plugins
ritzzen
Post Sat Feb 11, 2012 3:16 pm
So it mean this fix would be available in the next release right?
Ritz
Post Sat Feb 11, 2012 3:49 pm
yes
ritzzen
Post Sat Feb 11, 2012 8:38 pm
Looks like there is another bug, not very sure about it, but thats what it looks to me, if serviio finds thumburl as feed(thumburl encoded as "enclosure url="), it does not use plugin. what i mean to say that once serviio finds a feed and if we want to override it by using a plugin, it does not accept the plugin.
Let me know your say on it.
Thank
Ritz
Post Sun Feb 12, 2012 1:50 am
ritzzen wrote:Looks like there is another bug, not very sure about it, but thats what it looks to me, if serviio finds thumburl as feed(thumburl encoded as "enclosure url="), it does not use plugin. what i mean to say that once serviio finds a feed and if we want to override it by using a plugin, it does not accept the plugin.
Thank
Ritz
looking at the code it should run plugin if the matches() method returns true
Return to Plugin development
