Youtube search?
WildRushSykes
Post Fri Sep 23, 2011 2:12 am
Youtube search?
I Dont know if its possible but is there a way to create a youtube plugin that allows you to search for videos on yotube instead of just select feeds? experimenting time :)
Post Fri Sep 23, 2011 10:44 am
Re: Youtube search?
Not in the TV's interface, but you could probably create a feed URL with a specific search string.
grolschie
Post Sun Sep 25, 2011 9:49 am
Re: Youtube search?
It could be possible. SharkHunter's GrooveShark plugin for PS3MS has a search feature. It has A to Z folders, with a folder at the top whose title is created on the fly by selecting one of the A to Z folders and then going back one level, selecting another, and so forth. Each time a folder is selected, the chosen letter is appended to the title of the folder at the top of the A to Z folder list. When the string is complete, the folder (whose name will then be search string) is selected to initiate the search. It's quite a clever solution really - although I am probably not describing it very well.
Post Sun Sep 25, 2011 2:47 pm
Re: Youtube search?
I know what you mean, but it's not something I want to implement in Serviio.
Return to Plugin requests
Users browsing this forum: Baidu [Spider] and 19 guests
