Display image (on a url)
nfgb
Post Wed Oct 23, 2013 11:23 pm
What is the easiest way of displaying an image available on a url on serviio? The image is regularly updated.
Is it possible without a plugin?
If not is there any generic plugin for this? or at least an available plugin with a similar purpose.
Post Thu Oct 24, 2013 7:35 am
Re: Display image (on a url)
Not tested, but I suppose you can write a m3u8 playlist with image url, then add the playlist file on serviio library...
nfgb
Post Thu Oct 24, 2013 11:13 pm
Unfortunately it does't work. I'm getting the following message on the log "item"..."cannot be resolved to an entity in the Serviio library, will try again later". I guess it must be file that exists on the shared folder.
But you gave me another idea. Is should possible to add a local rss feed to display images. What is the structure for an image rss feed?
Post Sat Oct 26, 2013 11:44 pm
There is a playlist plugin which should help with the m3u file
Return to Plugin requests
