The CW - cwtv.com [LAST UPDATED: Oct-12-2012]
xs2inattar
Post Fri Jun 29, 2012 4:56 pm
Watch full episodes of shows from channel: The CW - http://www.cwtv.com/
Download and install the plugin
Add URLs as video web-resource
Sample URLs
Supernatural: http://www.cwtv.com/cw-video/supernatural/
The Vampire Diaries: http://www.cwtv.com/cw-video/the-vampire-diaries/
America's Next Top Model: http://www.cwtv.com/cw-video/americas-next-top-model/
More shows on: http://www.cwtv.com/cw-video/
CW.groovy
V1: June 29, 2012 - Initial Release
V2: October 12, 2012 -
(6.05 KiB) Downloaded 1564 times
Xmantium
Post Fri Jun 29, 2012 11:10 pm
Re: The CW - cwtv.com
Is this US only?
Could do with catching up with Supernatural :twisted:
xs2inattar
Post Sat Jun 30, 2012 2:37 am
Xmantium wrote:Is this US only?
I cannot confirm if the videos will work outside of US or not. Plz test it out and update the thread.
Xmantium
Post Thu Jul 05, 2012 12:29 am
Confirmed - does not work in the UK :cry:
glenb
Post Tue Jul 24, 2012 11:15 pm
not working in 1.0 version
Post Tue Jul 24, 2012 11:59 pm
Only for US viewers
glenb
Post Wed Jul 25, 2012 12:47 am
worked fine in .62, am in US
Post Wed Jul 25, 2012 2:24 am
I'm not in the US so cannot check it, but you said the same about ilive and it works fine, so you might want to fix your ilive problem and then check cw again.
xs2inattar
Post Thu Jul 26, 2012 2:40 am
I just checked this out. The stream urls are being extracted correctly and are loaded fine in serviio but fails when trying to play with ffmpeg issue. ffmpeg works fine when used munually but is failing when ffmpeg is called from within serviio.
Reported this in help and support; seems to be a 1.0 problem but lets see what zip figures out after reviewing the logs.
xs2inattar
Post Thu Jul 26, 2012 3:10 am
After running a few tests i have found out that I think serviio 1.0 uses different user/rights for the transacoding tmp folder than 0.62. So if the transcoding tmp folder was created by Serviio 0.62, 1.0 will not be able to access that hence ffmpeg fails.
Follow the following steps.
1. Stop Serviio
2. Delete the transcoding tmp folder
3. Start Serviio
The folder will be re-created with appropriate rights and stream will start working.
UK2LV
Post Fri Oct 05, 2012 1:28 am
Is this plugin still working for others? I can't seem to get it to work. I get the message 'there is no playable file.'
CigDangle
Post Thu Oct 11, 2012 6:12 pm
I am having the same issue. No files are showing...
Please help!
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
xs2inattar
Post Fri Oct 12, 2012 3:09 pm
CigDangle wrote:I am having the same issue. No files are showing...
Please help!
Please test it out and let me know if it works ???
UK2LV
Post Fri Oct 12, 2012 3:54 pm
Re: The CW - cwtv.com [LAST UPDATED: Oct-12-2012]
I'm still getting the 'there is no playable file' message with the updated plug-in. I did restart the computer after installing the plug-in. Anyone else tried it yet? Thank you.
xs2inattar
Post Fri Oct 12, 2012 4:58 pm
UK2LV wrote:I'm still getting the 'there is no playable file' message with the updated plug-in. I did restart the computer after installing the plug-in. Anyone else tried it yet? Thank you.
Try now, and please let me know if it worked or not.
UK2LV
Post Fri Oct 12, 2012 5:08 pm
It's working! Thank you very much for fixing it and sharing your talent! :D
khurram23
Post Mon Jun 08, 2015 9:41 pm
Any update to this? The current version is not working.
Thanks!
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
Return to Available plugins
