Tv6Play (Sweden)
FlamingLizard
Post Sat Oct 01, 2011 10:01 am
Tv6Play (Sweden)
And here comes a plugin for Tv6Play.
It is more or less identical as the one for tv3play, but I've kept them separate for now.
Tv6Play.groovy
(2.6 KiB) Downloaded 1754 times
Tomas
Samsung LE46B650
Serviio 0.6 on Win7x64 ultimate
Gimbal
Post Wed Oct 05, 2011 5:26 pm
Re: Tv6Play (Sweden)
Thanks. I like the thumbnails, is it possible to get that with svtplay?
Gimbal
Post Tue Oct 11, 2011 5:14 pm
Weirdest thing, I'm using this line "http://www.tv6play.se/rss/recent" but only a very small selection of the shows actually shows up in the TV browser. For instance I wanted to check out the new "2 1/2 Men" show. It's there if I use the above link in firefox, but not on the TV. There are several other shows missing as well. Is it something with the names of the shows that stops them from appearing, or what can it be?
FlamingLizard
Post Wed Oct 12, 2011 1:28 pm
Gimbal wrote:Weirdest thing, I'm using this line "http://www.tv6play.se/rss/recent" but only a very small selection of the shows actually shows up in the TV browser. For instance I wanted to check out the new "2 1/2 Men" show. It's there if I use the above link in firefox, but not on the TV. There are several other shows missing as well. Is it something with the names of the shows that stops them from appearing, or what can it be?
Hm, I guess it could be that that verification is required for some of the shows as seems to be the case for Tv3...
Could you please upload your serviio.log file so I can take a look?
Tomas
Samsung LE46B650
Gimbal
Post Wed Oct 12, 2011 6:14 pm
Of course, please look at http://web.comhem.se/gimbal/tmp/serviio.log
Seems to be some problem with a show at tv3...?
Post Wed Oct 12, 2011 9:37 pm
First of all try upgrading to Serviio 0.6.0.1
Gimbal
Post Thu Oct 13, 2011 5:22 pm
Ok, now running 0.6.0.1
But according to the log the program still loops at some error with the tv3 show.
So I removed the tv3 link (and the futile attempts at the erroneous tv3 show stopped) but the missing shows at tv6 is still missing.
FlamingLizard
Post Tue Oct 18, 2011 1:00 pm
A new version of this plugin will be forthcoming once I verify the fixes I made for the tv3-plugin are working. Have patience :)
Tomas
Samsung LE46B650
muszaj
Post Sat Mar 03, 2012 3:58 pm
Sorry, I didn't have patience! ;)
So I made some amendments fo FoH's TV3 modified plugin http://forum.serviio.org/viewtopic.php?f=20&t=3442&hilit=tv3+play&start=30#p37070.
Now the videos do play longer than 1 minute so it's sorted!
Tv6Play.groovy
(4.73 KiB) Downloaded 1259 times
Panasonic Viera D25
Return to Available plugins
