Tv3Play (Sweden)
FlamingLizard
Post Thu Sep 29, 2011 8:27 pm
Tv3Play (Sweden)
Here's a plugin for Tv3Play, it seems it works for Tv6Play as well, but I have not confirmed that yet.
http://www.tv3play.se/rss/recent
http://www.tv3play.se/rss/mostviewed
http://www.tv3play.se/rss/highestrated
Updated 2011-10-01: New version with thumbnails and some optimizations.
Updated 2011-10-18: New version, finally got it working using swfVfy and managed to solve the parsing for the AdamLive show.
Tv3Play.groovy
(3.17 KiB) Downloaded 2567 times
Last edited by FlamingLizard on Tue Oct 18, 2011 12:27 pm, edited 3 times in total.
Tomas
Samsung LE46B650
Serviio 0.6 on Win7x64 ultimate
sulfobus
Post Fri Sep 30, 2011 9:13 am
Re: Tv3Play (Sweden)
Great, you're on a roll :)
FlamingLizard
Post Fri Sep 30, 2011 10:53 am
sulfobus wrote:Great, you're on a roll :)
Well, the tricky part was learning groovy and to get the basics of this streaming stuff as I haven't done anything with either earlier :P
Tomas
Samsung LE46B650
Gimbal
Post Fri Sep 30, 2011 6:05 pm
Thanks, seems to be working. Keep 'em coming!
FlamingLizard
Post Sat Oct 01, 2011 9:48 am
See updated first post for new version.
Tomas
Samsung LE46B650
dualc
Post Thu Oct 06, 2011 9:20 am
Hi ...
my log is full of this...
[FeedUpdaterThread] Failed to retrieve feed item information for rtmp://cp90686.edgefcs.net/ondemand/fla ... /Efterlys$
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
... 1 more
I have compile the ffmpeg with rtp support but serviio tels me at upstart hes not use it..
/M
BlurayPlayer: Samsung BD-C5500
TV: Samsung LE40B535
Janne
Post Thu Oct 06, 2011 7:54 pm
Well, same here...
I can't get the TV3 or TV6 plugin to work, I get empty folder on the TV and the log is full this, even when I'm down to one single TV3 feed:
2011-10-06 21:46:16,088 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/sweden/tv3/AdamLive/Season1/Program/adamlive_122_111004.mp4. It might not play.
   ... 1 more
Making 5 full log files per hour... :?
Any ideas?
(BTW. big thanks for the SVT plugin, works wonderfully and I use it almost every day! :D)
dualc
Post Fri Oct 07, 2011 6:16 am
Janne wrote:Well, same here...
   ... 1 more
Any ideas?
Cool u have a working SVT plugin, .. i dont. :) cant see anything.. :/
FlamingLizard
Post Fri Oct 07, 2011 12:19 pm
dualc wrote:Hi ...
... 1 more
/M
Hm, I don't know... Could it possibly be an issue with dlna-profile? Anyone else got any idea?
Tomas
Samsung LE46B650
Post Sun Oct 09, 2011 2:48 pm
run ffmpeg -i for the rtmp url, like
ffmpeg -i "rtmp://............"
and post the result
Janne
Post Sun Oct 09, 2011 3:16 pm
Ok, tried that but it didn't seem to work:
ffmpeg version 0.8.git, Copyright (c) 2000-2011 the FFmpeg developers
  built on Aug 14 2011 22:07:26 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
HandShake: client signature does not match!
HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
rtmp server sent error
rtmp server requested close
rtmp://mtgfs.fplive.net/mtg/mp4:flash/sweden/tv3/AdamLive/Season1/Program/adamlive_122_111004.mp4: Operation not permitted
Some type of authorisation is needed to get to the stream...
If that's the problem, how can some people have it working?
Post Sun Oct 09, 2011 3:24 pm
not sure, is it possible that some streams use rtmp and some http URLs for the files?
FlamingLizard
Post Mon Oct 10, 2011 6:59 am
zip wrote:not sure, is it possible that some streams use rtmp and some http URLs for the files?
All I have come across use rtmp, but it may be that some require verification, I haven't had any time to dig deeper into this yet.
Tomas
Samsung LE46B650
muszaj
Post Thu Oct 13, 2011 7:16 pm
Hej! Thanks for this plugin.
I have an issue unfortunately:
The programs load fine, play fine, but every TV3 play program stops after 1 minute. :(
Please help me with this, I may be doing something wrong.
I use Panasonic Viera with Samsung C/D profile (B produces the same, Panasonic profile doesn't play the files at all)
Thanks in advance!
(TV6 has the same issue )
ortner
Post Sun Oct 16, 2011 9:13 pm
I have a problem playing the content. I can see the thumbnails and all but when I try to play it I get a "Format not supported" on my samsung D series TV.
When I start to play it i get this in my serviio log:
2011-10-16 23:02:18,967 DEBUG [WebServer] I/O error: Broken pipe
2011-10-16 23:02:19,080 DEBUG [WebServer] Incoming connection from /192.168.0.12:37242
2011-10-16 23:02:19,080 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000030002/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-10-16 23:02:19,080 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2011-10-16 23:02:19,081 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.12, Profile=Samsung TV / player (C/D-series)'
2011-10-16 23:02:19,081 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000030002 and type 'MEDIA_ITEM' received
2011-10-16 23:02:19,081 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000030002 (online)
2011-10-16 23:02:19,081 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 3)
2011-10-16 23:02:19,082 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
2011-10-16 23:02:19,082 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000030002, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D-series)
2011-10-16 23:02:19,082 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file rtmp://cp90686.edgefcs.net/ondemand/flash/sweden/tv3/Extra/Season7/Program/extraextra_703
2011-10-16 23:02:19,082 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtmp://cp90686.edgefcs.net/ondemand/flash/sweden/tv3/Extra/Season7/Program/extraextra_703: MPEG_TS_SD_EU_ISO
2011-10-16 23:02:19,082 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtmp://cp90686.edgefcs.net/ondemand/flash/sweden/tv3/Extra/Season7/Program/extraextra_703: MPEG_TS_SD_NA_ISO
2011-10-16 23:02:19,083 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtmp://cp90686.edgefcs.net/ondemand/flash/sweden/tv3/Extra/Season7/Program/extraextra_703: MPEG_TS_SD_KO_ISO
2011-10-16 23:02:19,083 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-10-16 23:02:19,083 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sun, 16 Oct 2011 21:02:19 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
and if I do a "ffmpeg -i" I get this:
./ffmpeg -i rtmp://cp90686.edgefcs.net/ondemand/flash/sweden/tv3/Extra/Season7/Program/extraextra_703.mp4
Closing connection: NetStream.Play.StreamNotFound
rtmp://cp90686.edgefcs.net/ondemand/flash/sweden/tv3/Extra/Season7/Program/extraextra_703.mp4: Operation not permitted
I don't know if this is related to this https://bitbucket.org/xnejp03/serviio/issue/425/samsung-d-series-tv-will-not-play-online#comment-710251. But I have tried to add that bit of code to the C/D profile with no succes.
*EDIT*
Partially solved, it was a profile problem. I followed jhb50's profile, found here. Now I can see the first minute, then it changes to the next episode in the feed.
Any ideas?
FlamingLizard
Post Tue Oct 18, 2011 12:33 pm
Ok, so I've finally made a new version which uses swfVfy.
This might help with the skips to next show after 1 minute.
The new version should solve the issues with the AdamLive-show cluttering the log with error messages. For some reason they were using different formats for some(only found AdamLive so far, but might be others) shows...
Newest version can be found here:
viewtopic.php?p=22717#p22717
Tomas
Samsung LE46B650
Post Tue Oct 18, 2011 12:37 pm
well done, mate.
ortner
Post Tue Oct 18, 2011 1:09 pm
Awesome, will try it when I get home!
Sent from my GT-I9100 using Tapatalk
ortner
Post Tue Oct 18, 2011 4:39 pm
I can confirm that the new plugin works with my Samsung D series TV.
Tusen tack FlamingLizard!
muszaj
Post Tue Oct 18, 2011 6:35 pm
Bravo bravo! 1 minute issue solved! :)
Panasonic Viera D25
Return to Available plugins
