Tvheadend (a TV streaming server)
pgaubatz
Post Mon Nov 24, 2014 10:54 am
I just wanted to announce that I've implemented a Serviio plugin for Tvheadend (https://tvheadend.org) that allows for making Tvheadend's channel list available as live streams in Serviio.
In other words: you can now watch live TV with any DLNA client!
The plugin is available on github: https://github.com/pgaubatz/serviio-tvheadend-plugin
Cheers,
Patrick
Bettman
Post Mon Mar 30, 2015 6:14 am
Re: Tvheadend (a TV streaming server)
Danke Patrick
jmr008
Post Tue Apr 14, 2015 1:55 pm
Hi Patrick,
my installation doesn’t work.
The plugin TvheadendChannels is listed in the console.
I added the web resource http://192.168.1.17:9981/
The log announced:
2015-04-14 15:50:53,141 WARN [FeedUpdaterWorker] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://192.168.1.17:9981 has been found.
An other plugin, YouTube works fine.
Can you help me?
Cheers,
Jürgen
Maba
Post Wed May 06, 2015 9:23 pm
I'm trying to get serviio working with the xbox 360 for streaming tvheadend channels... This seems to work fine in xbmc but on the xbox the channel list is populated but when I try to connect , it throws an error which indicated that the connection is dropped, local media is streaming fine, online media seems to be a problem, has anyone tried this on the xbox and succeeded ?
armstma1
Post Wed Jul 01, 2015 4:40 pm
Serviio has never worked on a 360, its caused by the 360 having a short timeout and it basically gives up before the stream has started.
Outline
Post Mon Jul 27, 2015 9:29 pm
Hallo zusammen,
ich bekomme das TVHeadend Plugin einfach nicht richtig eingebunden :(
System : Synology DSM 5.2 / Technisat Skystar USB HD / Serviio 1.4.1.2 / Tvheadend 3.4.27 / Java SE Embedded 8
(Konsole über Windows 7 - Serviio 1.4.1.2)
Was ich bisher gemacht habe :
1. In dem "Serviio Konsolenrechner" das Plugin in den Pluginordner kopiert
2. Zugriffsrechte im TVheadend eingestellt (User : * / PW : * / 192.168.1.0/24 / Alles angewählt)
3. Onlineservice zu meinem Server (http://192.168.1.137:9981) eingegeben und auch in den Anzeigeeinstellungen Online Aktiviert.
Auf meinem LG620S wird zwar der Serviio angezeigt (auch der mittels Konsole eingestellte Aufnahme Ordner) nur unter Videos/Online ist nichts zu sehen. Also weiter gings :
4. Mittels Root das Plugin in den Ordner : /var/public/serviio/plugins und /volume1/@appstore/Serviio/plugins kopiert
In dem Log von Serviio finde ich nichts brauchbares, welches auf einen Fehler hinweisen könnte :( Was habe ich übersehen? Wie gesagt, TVHeadend und Serviio an sich laufen einwandfrei. Nur leider wird irgendwie das Plugin für die Senderauswahl nicht erkannt :(
-------> If this only a English Supported Forum, i´ll try to explain it later :)
Danke für eine Antwort und Gruß
Jens
beinaendi
Post Sun Dec 27, 2015 4:41 pm
I just tried the same as Outline and it didn't work out. Maybe Patrick could give us some advice?
What Outline wrote in German is that he did all Patrick wrote in his tutorial but the plugin doesn't work. Same here.
Many thanks for your help!
beinaendi
Post Mon Dec 28, 2015 7:44 pm
Hi Outline,
the plugin's now working here on a Synology RS815+ with Tvheadend 4.1.1233 and Serviio 1.5.2-0027. If you need help, anytime... even in German ;-)
Cheers,
beinaendi
Unr3al2
Post Mon Jun 13, 2016 7:35 am
Hey,
Works plugin you tvheadend on serviio version 1.6.1?
Regards,
Unr3al2
robert90
Post Sun Jul 17, 2016 12:12 pm
For me, the plugin does not work unfortunately.
I can not add the URL http://NAS:9981 as a Web resource.
The following error are displayed: The stream URL is not valid or is not currently available
No error appears in the log.
Access to http://NAS: 9981/api/serverinfo is possible without ask for username/password.
Can someone help me?
Return to Available plugins
