COOLSPORT - A SPORTS STREAM WEBRESOURCE
• Page 4 of 5 • 1, 2, 3, 4, 5
Same as any plugin. Read the wiki and the first post.
Re: COOLSPORT - A SPORTS STREAM WEBRESOURCE
sorry
I cant get it to work
what I have tried is on serviio console
source type web resource
this link http://www.coolsport.tv
when I check my folder there is nothing
I also tried this link
rtmp://cp96798.live.edgefcs.net/live/ playpath=ChelTV_Ch01_1000k@26291 swfUrl=http://player.tv-stream.to/player.swf live=1 pageUrl=http://www.lagerassassin.eu/Chelsea TV
on live stream while I was watching kiwisportz.tv
got green tick but nothing in folder
can you please tell me where im going wrong
thanks
thanks
Beta Tester
Beta Tester
The failure of the live stream is an ffmpeg bug. Post a debug log for the webresource while its refreshing.
Thanks jhb50
I hope this is right m8
if not can you tell me how to do it while it s refreshing please
Beta Tester
Beta Tester
follow the HowTo: Turn on detailed logging instructions in my signature. Restart Serviio, wait for Coolsport to parse then post the part of the log from "coolsport: Parsing with Coolsport V20" to the next line containing "Online resource ..... expired, will reload it"
sorry don't understand Coolsport to parse then post the part of the log
ive read the link, I changed the log4j to what it said to filter it out cause the files was to big
this is what I've done so far
Beta Tester
Beta Tester
I can't help you more than the instructions. There must be problem with your system.
Thanks jhb50
for trying to help me
can you please tell me what this means so I can try and do it Coolsport to parse then post the part of the log
what does coolsport to parse mean please ?
where can I find the part of log please ?
I do appreciate everything you have done for me and is doing for me
Thanks again
Thanks again
Beta Tester
Beta Tester
Read the log and you will find it
Sirius, dude your attaching the setting of the log, log is found here - C:\Program Files\Serviio\log\serviio.log
Strange tonight....working ok for Golf this afternoon, but now Stream 19 and Golf TV are no longer showing up....although working OK directly from a browser.
Even odder, they are also not showing up now (but again working OK directly from a brower) on HaHa and StopStream................
Version 21 posted with updated icons.
This stopped working for me on ps3 and my iPhone anyone else having problems?
V21 is working fine for me. What does your debug log show when you refresh it?
Hi. Any chance of taking a look at the format the Golf Channel and also Stream 19 (When golf is on....basically the same as Golf Channel) is streaming in? Seems not to be working correctly the past few days. I have to play it via the TV browser directly (Works oK then) but you can see the format is off....almost like a P&S 4:3 with side borders.....not sure if log will help or not.
Hello, after a few seconds, every stream stoped and vlc changed to another stream. I tested it with my serviio an my windows pc an my Serviio on my NSA 325. When i want look from my TV, the TV show "ungültige datei" (NSA 325 and Windows). When i look with the VLC player, the Player jump after a few seconds to another stream. Only by coolsports. When i look Skyplus, i can look without problems.
I use version 21.
I use version 21.
Coolsport has locked up their streams, so the plugin will currently not work.
Thats not good. I like coolsports. Because i can watch the German Bundesliga 1+2 and the champions league in german.
You could stream your fullscreen desktop.
If i watch via firefox 20, the sound from the stream breaks after a few second but if i play via the Internet Explorer, the stream is OK.
