HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
newborn
Post Tue Jan 08, 2013 7:25 pm
Re: HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
awesome!
erteerte1
Post Wed Jan 09, 2013 7:47 pm
Dear jhb! You're a genius. CPU is now at a very low level. Thank you.
erteerte1
Post Fri Jan 11, 2013 4:27 pm
I have the feeling that the plugin doesn't show now live events. Maybe the webformat has been changed again.
Post Fri Jan 11, 2013 8:16 pm
Right. Version 18 posted to support revised web format
erteerte1
Post Fri Jan 11, 2013 9:04 pm
Thank you again!
Post Fri Jan 11, 2013 11:52 pm
Posted Version 19 to correct a refresh timing error.
erteerte1
Post Sat Jan 12, 2013 7:00 pm
I think the problem is now the same as yesterday.
Post Sat Jan 12, 2013 7:47 pm
They are all working fine for me.
erteerte1
Post Sun Jan 13, 2013 1:21 am
Did you try with hahasport football? I have problem with it.
Post Sun Jan 13, 2013 3:33 am
Yes it worked fine.. check your debug log to make sure it says hahasport parsing with V19. Sometimes Serviio does not accept the update when you copy it into the plugin folder and you need to restart.
Post Sun Jan 13, 2013 3:45 am
Version 20 posted. Groovy tuned to run faster, coolsport source extracts updated.
erteerte1
Post Sun Jan 13, 2013 11:02 am
Thank you. It's perfect now.
Post Mon Jan 14, 2013 6:00 am
Version 21 posted with Liveall source change
Jeera911
Post Fri Jan 25, 2013 11:18 pm
Hi everyone, I am hoping someone can help me. I seem to be only having issue with hahasport feeds and this is what I get repeatedly in the log file.
2013-01-25 18:02:36,086 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.hahasport.com. Message: No plugin for web resource http://www.hahasport.com has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
Most obviously I have the .groovy plugin in the right directory and I have stopped and restarted the service and the server itself to no avail.
I gotta have my sports.. :-) Help.. :-)
Jeera911
Post Fri Jan 25, 2013 11:37 pm
Ok well if you put the webresource url as http://www.hahasport.com it does not work and I get the error message in log.
But when I changed the webresource as one of the sub ones like http://www.hahasport.com/c-4.html then it works!!
is this expected behavior??
Jeera911 wrote:Hi everyone, I am hoping someone can help me. I seem to be only having issue with hahasport feeds and this is what I get repeatedly in the log file.
Post Sat Jan 26, 2013 1:22 am
For now Use http://www.hahasport.com/
I will fix it in the next version.
bobsmo
Post Sun Jan 27, 2013 8:34 pm
For the life of me I can not get the estream param to work:
http://www.hahasport.com/c-8.html?refresh=30&estreams=9
only ever shows 1 but on the actual www.hahasport.com shows multiple feeds................
Post Sun Jan 27, 2013 10:28 pm
There are only 3 golf feed items, and the current plugin version only decodes the first one.
bobsmo
Post Mon Jan 28, 2013 12:52 pm
Can that be updated? I ask as last night there were 3 feeds for the U.S. PGA, and at least the first two were different (same channel, but different feeds)....
If not, so be it, still a great resouce.
Post Mon Feb 04, 2013 4:31 am
Version 22 posted with new source feeds and ips.
This is a major upgrade of the plugin and features a new quick refresh capability as described in the wiki at http://wiki.serviio.org/doku.php?id=quick_refresh.
This makes it practical to do refreshes frequently using the refresh parameter and keep the list of items up to date without the overhead of re-extracting the existing items. Refreshes that previously took many minutes are now done in one or two seconds.
Return to Available plugins
Users browsing this forum: Google [Bot] and 33 guests
