ITV Player (UK only) - Web Resource
Xmantium
Post Thu Jan 10, 2013 8:24 pm
Re: ITV Player (UK only) - Web Resource
I've added over 100 ITV programmes at http://www.serviidb.com/plugin-api-name ... er-uk-only
You can use the 3rd party apps in my signature to add them automatically to your Serviio library :D
Xmantium
Post Sat Jan 26, 2013 5:43 pm
Noticed a few errors in logs, any ideas whats causing it, using v3
2013-01-26 17:34:48,791 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ITVPlayer (UK only)): assert episodeMatcher.size() == 1
       |              0      false
       java.util.regex.Matcher[pattern=(?s)about="(.*?)".*?content="(.*?)".*?field-season-number.*?(\d+).*?field-episode-number.*?(\d+) region=0,156019 lastmatch=]
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: Assertion failed:
       |              0      false
   at org.codehaus.groovy.runtime.InvokerHelper.assertFailed(InvokerHelper.java:386)
   at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.assertFailed(ScriptBytecodeAdapter.java:658)
   at ITVPlayerExtractor.extractItems(ITVPlayer.groovy:117)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
   at java.util.concurrent.FutureTask.run(FutureTask.java:166)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
   at java.lang.Thread.run(Thread.java:722)
2013-01-26 17:35:49,213 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
       |              0      false
       |              0      false
2013-01-26 17:36:49,675 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
       |              0      false
       |              0      false
2013-01-26 17:37:50,088 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
       |              0      false
       |              0      false
Edit: Found the cause, ITV removed all episodes of Britains Best Bakery - https://www.itv.com/itvplayer/britain-s-best-bakery :(
Ended up with tonnes of logs with same error. Can this plugin be amended to say "No episodes found"
65ravenblack
Post Thu Feb 28, 2013 1:55 am
I've just discovered the world of streaming and am loving it.
Is there any way to access the ITV Player streams from Australia?
Any info and help greatly appreciated.
Cheers,
Aaron
newborn
Post Fri Mar 22, 2013 5:58 pm
Is this plugin still working for anyone else?
I'm getting the following on Episodes of 'Corra' :)
2013-03-21 20:36:36,195 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEbpaWa6d8c2dvcua2a2anamdqakckcTbncYbvaVd0b2bJa3aIbXdicSaibmb5aHaL-brs29C-eS-9xu1KDnlzuxr&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/1200/2F/1-0694-8084-001/1-0694-8084-001_coronation-street-(series-54)-2013_tx180313_itv1200_16x9-reg.mp4 swfvfy=true. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
   ... 2 more
Hopefully not down to my personal profile.xml changes <<
Xmantium
Post Fri Mar 22, 2013 7:40 pm
Do you mean Coronation Street?
Tested it, working fine for me. Use the valid URLs from here - http://www.serviidb.com/plugin-api-name ... er-uk-only
newborn
Post Sat Mar 23, 2013 12:47 am
Xmantium wrote:Do you mean Coronation Street?
Yes mate, I did indeed.. OK thats interesting.. looks like the profile changes I made might have been too significant, all good though.. I'll just have to extend my testing plan. This is the first source my changes have broke though.. I wonder whats special about this source.. I look forward to figuring it out! Cheers for ears... newborn
As for the url https://www.itv.com/itvplayer/coronation-street/ so just an extra / which I imagine serviio will parse anyway.
Xmantium
Post Sun Dec 01, 2013 9:18 pm
Can anyone help me on this one, im desperately trying to get Im A Celebrity - Get Me Out Of Here to work on my ARM QNAP, it works perfectly fine on Windows and Intel QNAP
ServiioLink - Image
More than likely my ffmpeg is not configered well with librtmp but it is. csholmq has kindly shared his QNAP compiled build which works on his plugins
My ffmpeg is the following
[~] # /share/HDA_DATA/.qpkg/Serviio/opt/bin/ffmpeg
ffmpeg version 2.1-Qnap_csholmq Copyright (c) 2000-2013 the FFmpeg developers
  built on Nov  4 2013 21:32:38 with gcc 4.2.3 (GCC)
  configuration: --arch=arm --disable-armv6 --disable-armv6t2 --disable-neon --disable-vfp --prefix=/opt --extra-libs=-ldl --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --enable-libshine --enable-libfdk-aac --extra-version=Qnap_csholmq
  libavutil      52. 48.100 / 52. 48.100
  libavcodec     55. 39.100 / 55. 39.100
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
I get the following errors
2013-12-01 21:03:46,103 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEa5acdWbNaxabbpdXbIc0a5b8b3dTcFb2cHaAdtd_d0c7bybNbPd5bXcpcadHb7cZ-bsM6qX-eS-bxo4KBwjyrxq&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/1200/50/1-7103-0110-001/1-7103-0110-001_i-m-a-celebrity----get-me-out-of-here--(series-13)_tx251113_itv1200_16x9-reg.mp4 swfvfy=true. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
   ... 2 more
2013-12-01 21:03:48,973 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEd5c4cTdIaDaCcLbna_cRcYa_dha.aOdGbGaHcic2dYbRasb.bBdkcJasaGa7crdX-bsM6q0-eS-bzs3HDrjErEr&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/1200/6D/1-7103-0109-001/1-7103-0109-001_i-m-a-celebrity----get-me-out-of-here--(series-13)_tx241113_itv1200_16x9-reg.mp4 swfvfy=true. It might not play.
Post Thu Dec 05, 2013 2:56 pm
When this happens, try to get ffmpeg -i "url" for the url in the log.
Ideally do this using the QNAP ffmpeg
Xmantium
Post Sun Dec 08, 2013 1:41 pm
Hi zip, ran the commands in Putty on my QNAP
[~] # /share/HDA_DATA/.qpkg/Serviio/opt/bin/ffmpeg -i "rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEbydibOd0btcYdTagb8bybjbAbta0d6cJdxbOcLdgcjbCcFaGb1blaza.cfacdCdb-bsPhmC-eS-8Au2CDpkEtws&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/1200/07/1-7103-0103-001/1-7103-0103-001_i-m-a-celebrity----get-me-out-of-here--(series-13)_tx171113_itv1200_16x9-reg.mp4 swfvfy=true"
HandShake: Type mismatch: client sent 6, server answered 9
Segmentation fault
Post Mon Dec 09, 2013 12:42 pm
Looks like the librtmp is not up-to-date (before 2.4)
Xmantium
Post Tue Dec 10, 2013 4:54 pm
zip wrote:Looks like the librtmp is not up-to-date (before 2.4)
Thanks Zip, ive informed csholmq and he packaged a fresh new ffmpeg for me and all Qnap ARM users that now works! :D
Fix was to get librtmp from git://git.ffmpeg.org/rtmpdump, for some reason http://rtmpdump.mplayerhq.hu/download/ only host upto v2.3
Cazgas
Post Thu Dec 19, 2013 2:51 pm
Hi
Totally new to Serviio, I have loaded the ITV Player Groovy file into the plugins folder and have put "https://www.itv.com/itvplayer/the-americans" in as a web resource, but I don't see anything, am i being stupid?
Any help appreciated.
Caz
Xmantium
Post Thu Dec 19, 2013 11:23 pm
Cazgas wrote:Totally new to Serviio, I have loaded the ITV Player Groovy file into the plugins folder and have put "https://www.itv.com/itvplayer/the-americans" in as a web resource, but I don't see anything, am i being stupid?
The reason is ITV Player not hosting any more episodes, if you go in the page its days
The programme you're looking for can't be found, this may be because:
The programme is not available
The programme has expired and is no longer available
We don't have permission to show certain films or programmes
Please browse the full list of programmes for other selections
Cazgas
Post Fri Dec 20, 2013 5:56 am
Hi
Thanks for the quick reply. I have since managed to get Jeremy Kyle working, only as a test. Is there any way possible to go to the index of ITV Player and then choose or is it a case of putting the url for each program?
Xmantium
Post Tue Dec 24, 2013 7:39 am
Cazgas wrote:Is there any way possible to go to the index of ITV Player and then choose or is it a case of putting the url for each program?
https://www.itv.com/itvplayer/categorie ... r/catch-up
norm
Post Thu Feb 05, 2015 8:50 pm
Hi All
Is it just me or is this plugin broken since the upgrade to Serviio 1.5?
2015-02-03 20:39:51,815 WARN  [WebResourceParser] Plugin ITVPlayer (UK only) returned no value for resource item 'null'
2015-02-03 20:39:53,026 WARN  [FeedItemUrlExtractor] Soap POST failed with status code 1002
Post Mon Feb 09, 2015 11:43 pm
Updated the plugin, try now
norm
Post Tue Feb 10, 2015 7:21 am
Hi Zip,
Thanks for this. I can confirm that all seems to be working well now. Thanks
norm
Post Sat Nov 21, 2015 4:53 pm
Unfortunately it looks like this plugin is not working any more. ITV seems to have transformed ITV Player in to ITV Hub which requires a login to watch video streams. So I don't know if this is the end for this plugin but it was good whilst it lasted. Thanks
Xmantium
Post Sun Jun 12, 2016 9:09 pm
Shame they changed the website, really liked this plugin.
Any chance foe another look into?
Previous
Return to Available plugins
