SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Cricfree changed its format again, so V7 is posted.
Re: SkySportsPlus - A Sports Stream WebResource
Version 8 posted to support new liveflash uri
which is the new url, please?
ok. got it!
anglia73 wrote:Version 4 works well useful update . Thanks for your work.
Ref ( empty directory from Sarson UK ), I have a sony KDL-32ex403 tv which does not like the sony tv 2009 profile that will show empty directory but I always use the Sony BD Player / SNP profile that works ok for, directory is populated with correct working mpeg2 files.
No idea why, not bright enough to find out , but it worked on my sons Sony n200 media play so i use that profile all the while on my tv and it got rid of my empty directory problem .
Regards
Fantastic work, had the same problem on Sony 2011 KDL40EX723 and now it works!
Hi. I have been struggling with this for the past half an hour and I can't seem to get anything within the folder. I am using the URL http://www.skysports.plus?refresh=120 - is this correct? If not what is the correct URL. I have other webservice working well (HaHaSports, etc).
Thanks in advance. BTW this is a great site / resource so thank you!
I think you will find the web site "cricfree.tv " that this plug in uses is off line
Regards
Regards
Sony KDL32EX403 Sony N200 Pentium 4 3.4ghz XP SP3
Version 9 posted to allow channels to list when schedule is unavailable.
Groovy is still unable to detect channels on myhdtv.com Help!!
Got it working on my Sony TV (with BD player profile) but can't get it working on my xbox, can see the channels but they wont play.
blokey wrote:Got it working on my Sony TV (with BD player profile) but can't get it working on my xbox, can see the channels but they wont play.
That's a profile issue that you should address in xbox support.
Hi
First of all I'd like to thank you for this awesome plug-in jhb50.
Only been using it for a week and it's great.
You may well be aware of this but in case you are not......
This morning I noticed that several of the usual streams were missing. I looked through the terminal output and noticed it was saying NOT FOUND in relation to http://cricfree.tv/update/skys2.php and the same for the other missing streams. The missing streams did work on the cricfree site.
A little more investigation showed that the missing streams were using hdmytv.com as the streaming service.
Playing around trying to get direct access to the hdmytv streams did not work for me. I got an 'invalid token' error.
Anyway just letting you know and giving feedback
Thanks again for the plug-in.
Edited to Add
It would be nice to get the channel name in the description / schedule text. (maybe as an option?)
Icons show on Samsung TV and PS3. Not on VLC and Android phone.
Edited to Add
Good feedback. Thanks.
I have asked for help aceessing myhdtv but so far no takers. When they use myhdtv as their source, that channel will be unavailable.
I'll add a channel abreviation to the start of each title with the next update. eg ss1 for skysports1 and ch1 for channel1
Ok Cheers
When I have a free night I'll take another look at hdmytv.com. But being optimistic I'd rate my chances close to zero. Never know though .
Version 10 posted with new yycast uri and added channel abreviations
Hi.. I added the web resource and am able to stream the video but there is no audio. I am able to get audio from other web streams. Is there an ongoing problem with this groovy?
Thans for this groovy by the way. I love watching cricket on skysports
Not all web streams are the same, these are hosted by multiple sources, some dont have audio.
To make sure the stream has audio, play the stream on your PC browser from http://cricfree.tv
Streams work fine on PC
I tried changing TV's profile but there was no difference. (I have a KDL-EX523.. which was released in early 2011. I tried 2009, 2010, 2011, 2011 US, 2012, 2012 US Profiles)
This is not a plug-in problem. You should post in the Sony forum using the info described in my sinature links in order to get the Sony profile fixed.
Updating profile doesnt help. Must be something else. I'll keep on researching and experimenting meanwhile.
Model is KDL46EX523.. bought here in US.
