Re: HDTRAILERS VIDEO WEBRESOURCE
Xmantium wrote:NX3 wrote:How can you tell if the trailer is from apple ?
Theres usually an Apple watermark on the bottom right
Ahh thankyou
2012-08-14 19:05:27,203 DEBUG [ProcessExecutor] Starting ffmpeg -user-agent QuickTime -i http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov
2012-08-14 19:05:27,236 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2012-08-14 19:05:27,237 DEBUG [FeedItemUrlExtractor] HDTrailers: Starting extraction of url for item: [8]Tai Chi 0
2012-08-14 19:05:27,459 DEBUG [FeedItemUrlExtractor] HDTrailers: Getting item: [8]Tai Chi 0
2012-08-14 19:05:27,460 DEBUG [FeedItemUrlExtractor] HDTrailers: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov, thumbnailUrl=http://www.hd-trailers.net/thumbnail/tai-chi-0-1344617115-poster.jpg, expiresImmediately=true, cacheKey=http://www.hd-trailers.net/movie/tai-chi-0/_720, live=false, userAgent=QuickTime]
2012-08-14 19:05:27,460 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov
2012-08-14 19:05:27,461 DEBUG [ProcessExecutor] Starting ffmpeg -user-agent QuickTime -i http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov
2012-08-14 19:05:27,495 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
... 2 more
built on Jan 7 2012 18:21:29 with gcc 4.6.1
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid --enable-ssse3
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Unrecognized option 'user-agent'
Failed to set value 'QuickTime' for option 'user-agent'
C:\Users\John>ffmpeg -user-agent QuickTime -i http://trailers.apple.com/movies/i
ffmpeg version N-41860-g6fd0b55 Copyright (c) 2000-2012 the FFmpeg developers
built on Jun 23 2012 19:49:05 with gcc 4.6.2
g-config
libavutil 51. 61.100 / 51. 61.100
libavcodec 54. 29.100 / 54. 29.100
libavformat 54. 11.100 / 54. 11.100
libavdevice 54. 0.100 / 54. 0.100
libavfilter 2. 82.100 / 2. 82.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://trailers.apple.com/movies/indepe
ndent/taichi0/taichi-tlr1_h720p.mov':
major_brand : qt
minor_version : 537199360
compatible_brands: qt
creation_time : 2012-08-10 16:16:03
comment : Encoded and delivered by apple.com/trailers/
copyright : © 2012 All Rights Reserved
title : Tai Chi 0
timecode : 01:00:00:00
Duration: 00:01:09.81, start: 0.000000, bitrate: 5393 kb/s
Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x544,
5253 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 5994 tbc
handler_name : Apple Alias Data Handler
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 134
kb/s
Stream #0:2(eng): Data: none (tmcd / 0x64636D74)
2013-01-17 12:19:02,171 DEBUG [OnlineLibraryManager] Resource http://www.hd-trailers.net/?res=720 not in cache yet, loading it
2013-01-17 12:19:02,171 DEBUG [WebResourceParser] Parsing web resource 'http://www.hd-trailers.net/?res=720'
2013-01-17 12:19:02,171 DEBUG [WebResourceParser] Found matching url extractor (HDTrailers) for resource http://www.hd-trailers.net/?res=720
2013-01-17 12:19:02,171 DEBUG [FeedItemUrlExtractor] HDTrailers: Starting parsing resource: http://www.hd-trailers.net/?res=720
2013-01-17 12:19:02,171 DEBUG [FeedItemUrlExtractor] HDTrailers: Parsing with HDTrailers V8- Only works with Serviio V1.0+
2013-01-17 12:19:02,171 DEBUG [FeedItemUrlExtractor] HDTrailers: HDTrailer type not found or start value too high
2013-01-17 12:19:02,171 WARN [WebResourceParser] Plugin returned null container
2013-01-17 12:19:02,171 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-01-17 12:19:02,171 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at org.serviio.library.online.OnlineLibraryManager.getEarliestItemExpiryDate(OnlineLibraryManager.java:313)
at org.serviio.library.online.OnlineLibraryManager.storeResourceExpiryDate(OnlineLibraryManager.java:358)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
2013-01-27 14:52:29,455 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://www.hd-trailers.net/yahoo-redir.php?id=c89586ac-eb70-3014-b379-9deee9072fa7&resolution=480. It might not play.
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:409)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:89)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:127)
... 2 more
2013-01-27 14:52:31,099 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://www.hd-trailers.net/yahoo-redir.php?id=2de34cea-2b7e-35ef-85b2-fd2b42c164a4&resolution=480. It might not play.
... 2 more
2013-01-27 14:52:32,585 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://www.hd-trailers.net/yahoo-redir.php?id=21a8e8bf-195f-35bf-b291-694ef55ff93d&resolution=480. It might not play.
... 2 moreUsers browsing this forum: No registered users and 44 guests
