HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Re: HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Thanks working on Sony Blu Ray Player
V9 posted with update for ilive IP.
Hi!,
The web resource has stopped working:
I cannot download either http://www.hahasport.com/c-1.html with wget (ERROR 404: Not Found) but the URL is working with my browser.
Is there any error with my configuration?
Thanks in advance, and sorry for my (awful) english
- Code:
2012-10-31 13:06:05,556 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (HaHaSport): http://www.hahasport.com/c-1.html
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.io.[b]FileNotFoundException: http://www.hahasport.com/c-1.html[/b]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1401)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.configuredInputStream(DefaultGroovyMethods.java:16692)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.newReader(DefaultGroovyMethods.java:16760)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15130)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15102)
at org.codehaus.groovy.runtime.dgm$375.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112)
at HaHaSport.extractItems(HaHaSport.groovy:116)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:636)
Happening to me now too. I can download it with my downloader utility but I don't know why the getText in the groovy has stopped working. Any suggestions appreciated.
Same here. No longer working.....
Any news here, doesnt work for me either anymore!
Version 10 posted.
jhb50 wrote:Version 10 posted.
Thank you very much!!!!! it's now working again
I have all the directories again however most of them are empty with the exception of one but the files wont play. Previously before the last update I was inundated with sport but now I dont see it anymore. Any ideas why?
The hahasport site is not working correctly. Try it in your browser.
Hi - newbie here, I'm using serviio 1.0.1 with v10 of this plugin. I think same problem as sarsonuk, I just see one feed item. Default settings so more than one feed item configured. Is this caused by the hahasport site (I'm using http://www.hahasport.com/c-10.html)? Looks fine in a browser, multiple feeds.
I'm using Christian's qpkg for x86 Qnap which has ffmpeg included. The ffmpeg path is hard-coded into the java option string.I see this error:
2012-11-17 17:07:23,752 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://213.163.71.196/pull?testkey=e62b ... 729c1b2421 swfUrl=http://files.leton.tv/player.swf pageUrl=files.leton.tv playpath=ffformulaa1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
... 2 more
... 2 more
Actually I'm getting a 404 curl'ing hahasport from the NAS but fine in a browser. Are they blocking user agents?
# curl -LI http://www.hahasport.com/c-10.html
HTTP/1.1 404 Not Found
Server: nginx/1.2.4
Date: Sat, 17 Nov 2012 17:30:12 GMT
Content-Type: text/html
Content-Length: 168
Connection: keep-alive
Vary: Accept-Encoding
Server: nginx/1.2.4
Content-Length: 168
I get the same curl response but
I have no problem displaying http://www.hahasport.com/c-10.html in the browser.
The problem is the next level down which displays no feeds.
Even so the plugin can get the list of feeds but when it ries to access the formula1 feed from leton it gets server not found.
Are you actually able to get the f1 stream playing in the browser?
Hi - yes it plays fine in the browser.
Actually I've actually had a second feed pop up so things are improving! There's still 10 feeds displayed though on the website at the moment (http://www.hahasport.com/c-10.html). Is the curl issue a red herring? I tried with a firefox user agent and it still gives a 404. They may be doing some sort of lower level blocking.
The plug-in does not access all the sources, only the common ones. Can you stream the first one in the list using your browser, which comes from leton? That is the one that the plugin should play.
UPDATE: I still cannot access it in my browser but the plugin is accessing leton feeds again, I'll leave it for now.
Hi - yes, I can always access the leton one in the browser (coincidentally that seems to be the best one).
Version 11 posted with updated leton url
Very cool, I'll give it a try.
Thanks!
Thanks!
