Hulu (US only)
Spaceboy64
Post Wed Jun 19, 2013 3:22 am
Re: Hulu (US only)
Finally, using the URL http://www.hulu.com/feed/show/11241/episode 9
I was able to stream episode 9, plus other clips.
Using the SyFy plug-in, I could only get up to episode 8 as well, even though it is available on the web.
mondjef
Post Sun Jul 07, 2013 3:16 am
Re: Hulu (US only)
long time user of Serviio, but only played with the plugins a little bit. In the past I tried some of the plugins including Hulu and was able to get the feeds to work but have been trying for about two days now with no luck and hoping somebody can shed some light on the issue.
Details:
-Serviio (version 1.2.1) installed on linux (Gentoo) box
-Using tunlr to mask my Geocode as I am in Canada
-I can browse and play Hulu videos just fine from any other device in the house on my network
-Using latest Hulu (US only) plugin
-Plugin is recognized and loaded during Serviio Start up
-Add "http://www.hulu.com/feed/show/54/episodes" as an "Online RSS/Atom feed"
-I get this repeated for every episode it finds:
2013-07-06 23:12:06,313 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Family Guy - s11 | e4 - Yug Ylimaf: No video sources found, you are probably outside the US. Expression: (mediaItems.size() > 0
Have tried a handful of other shows as well and same story...any body that can help or shed some light on what to check would be appreciated. :(
ggentry
Post Thu Sep 19, 2013 1:59 am
Re: Hulu (US only)
Is anyone having issues with Hulu playing only the first 60-90 seconds of a show and then moving on to the next episode?
johndagolfer
Post Fri Sep 20, 2013 1:50 pm
Re: Hulu (US only)
Hi!
I just started using serviio yesterday and I cannot believe I didn't do this sooner! though I didn't have a DLNA device until last week, so I guess it didn't matter. HaHa.
I setup my CBS shows ok. But I am having problems with HULU. I am specifically trying to setup the following shows for my wife Next Top Model, Daily Show, Cobert. When I tried to setup the Daily show as an RSS, Atom, which is the only way I could get it to pull up in the online folder, and clicked a show from the 19th all I got was a still frame and not the entire show.
Could someone let me know what I need to do to get this working?
Thanks!
jim502
Post Sun Oct 13, 2013 2:12 pm
Re: Hulu (US only)
Does anyone have hulu working on a QNAP ARM HDD? I can run serviio and hulu well using my windows machines.
It's properly loaded. Crackle and cbs.com stream well. Hulu and abc do not stream at all. A message about no playable content appears.
Cbs.com and crackle are web resources. Hulu and abc are rss feeds. Does this identify the problem?
Is it a flash problem since it appears impossible to load flash on a QNAP ARM box? If someone knows how, please pass it along.
I have tried !.3.1 and 1.1. JRE 7 for ARM is installed, otherwise I couldn't have loaded Serviio and cbs.com wouldn't work.
Spaceboy64
Post Tue Nov 19, 2013 5:38 am
Re: Hulu (US only)
MikK wrote:@Spaceboy64
The url style I've been using is not like yours where you are using a search to gain access to an RSS feed.. What you need to do is use the shows id number.
Example for Lost in Space ::
http://www.hulu.com/feed/show/26/episodes
To get the 'show_id' just browse hulu for the show and go to its Episodes page ::
http://www.hulu.com/grid/lost-in-space? ... pe=episode
Now view the pages source in your browser and search for show_id":
This will give you the number... Just replace the number in the example above with the show you wish to stream.
This method of finding the show ID seems to have been thwarted by Hulu. The show ID is no longer displayed. Has anyone found a work-around? or is there a list somewhere?
Xmantium
Post Wed Nov 20, 2013 1:22 pm
Re: Hulu (US only)
Spaceboy64 wrote:This method of finding the show ID seems to have been thwarted by Hulu. The show ID is no longer displayed. Has anyone found a work-around? or is there a list somewhere?
http://www.serviidb.com/plugin-api-name/hulu-us-only
leo1981
Post Fri Nov 22, 2013 6:53 pm
Re: Hulu (US only)
Open the page of the show, example http://www.hulu.com/family-guy
View source code, look in the metadata at the beginning of the page:
http://ib3.huluim.com/show/54?region=US&size=600x400
The show number is 54.
Hulu.com may hide this method as well
Spaceboy64
Post Fri Nov 29, 2013 12:50 am
Re: Hulu (US only)
Thank you for that info! Very helpful.
Is there a way to use this with an iPad?
jwe000
Post Sun Dec 01, 2013 8:40 pm
Re: Hulu (US only)
I'm trying to use the Hulu US plugin (obviously) and can't see the media content in the file folder on my WD TV live. After putting in the RSS url in "online resources" the show directory shows up but the SMP says it can't find any media (even after waiting awhile). It looks like the feed (http://www.hulu.com/feed/show/2252/episodes) is expired from the log files? Any idea what's wrong?
ffmpeg version 0.8.9-4:0.8.9-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers built on Nov 9 2013 19:08:00 with gcc 4.6.3
SMP's firmware: 1.16.13
The detailed log file for an episode example says:
2013-12-01 15:58:52,394 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'Grey's Anatomy - s10 | e10 - Somebody That I Used to Know'
2013-12-01 15:58:52,396 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEcDbyb1aCbfdOcQdycyb8d3dMclcKasdH-bsM6l.-c0-5oJCuCvZFAm&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wvafkoRy2Ato6bGIm53ZZZ2u3vYlqGzxw0kLOSNMyzQV-b7zpNdsVCvXpEpa8y73xnsims5rxG6Yj7707xej75v2CVjlTayXivnqpDyxiW5a1zOMfTe6lsqas5ym9PiGI70YK8lTqK4-nMs57w596Riv_YGmyK120o23maGZF9Alwh38zdl3nuHWJ4lyKNK9khDRr7KId5TWRGlSzWLc3Mtbq23CcjR2ztc7RBdC1PTP&hgt_ver=331370278 playpath=mp4:hulu9/758/60302758/agave50521051_19546618_H264_650.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1
2013-12-01 15:58:52,397 DEBUG [ProcessExecutor] Starting ffmpeg -analyzeduration 10000000 -i rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEcDbyb1aCbfdOcQdycyb8d3dMclcKasdH-bsM6l.-c0-5oJCuCvZFAm&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wvafkoRy2Ato6bGIm53ZZZ2u3vYlqGzxw0kLOSNMyzQV-b7zpNdsVCvXpEpa8y73xnsims5rxG6Yj7707xej75v2CVjlTayXivnqpDyxiW5a1zOMfTe6lsqas5ym9PiGI70YK8lTqK4-nMs57w596Riv_YGmyK120o23maGZF9Alwh38zdl3nuHWJ4lyKNK9khDRr7KId5TWRGlSzWLc3Mtbq23CcjR2ztc7RBdC1PTP&hgt_ver=331370278 playpath=mp4:hulu9/758/60302758/agave50521051_19546618_H264_650.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1
2013-12-01 15:58:52,419 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2013-12-01 15:58:52,419 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Grey's Anatomy - s10 | e10 - Somebody That I Used to Know
2013-12-01 15:58:52,906 DEBUG [FeedItemUrlExtractor] Hulu (US only): Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmpe://cp39466.edgefcs.net/ondemand?auth=daEd6bhdodwcwdbaYcndMbYdHbhbSbuazbz-bsM6mm-c0-4oMEvFp0CAn&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wuJUWYlaRgcJXtViydXI-d8gf309H1_HZrYGV1cPCd0gRP8-V9CDRob_FRkLZ7Z5oc1wQfaJBt7_KKH_F8gamzG2g0CTL8TJQWVOu4tux1oWVPTTJQzhCCw9RLU_9rSsuDFdazsHmTikN98_uRw26THVZXk-pnE5aJwcXcStyxnE0oGd4tvZ4WXItdavSk-GTbfhHMTSxtEkW3KPtPTvob_oqSC1TaIxnAfVD8Zjs0V4&hgt_ver=331370278 app=ondemand?auth=daEd6bhdodwcwdbaYcndMbYdHbhbSbuazbz-bsM6mm-c0-4oMEvFp0CAn&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wuJUWYlaRgcJXtViydXI-d8gf309H1_HZrYGV1cPCd0gRP8-V9CDRob_FRkLZ7Z5oc1wQfaJBt7_KKH_F8gamzG2g0CTL8TJQWVOu4tux1oWVPTTJQzhCCw9RLU_9rSsuDFdazsHmTikN98_uRw26THVZXk-pnE5aJwcXcStyxnE0oGd4tvZ4WXItdavSk-GTbfhHMTSxtEkW3KPtPTvob_oqSC1TaIxnAfVD8Zjs0V4&hgt_ver=331370278 playpath=mp4:hulu9/758/60302758/agave50521051_19546618_H264_650.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1, expiresImmediately=true, cacheKey=hulu_60302758_MEDIUM, live=false, ]
2013-12-01 15:58:52,906 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEd6bhdodwcwdbaYcndMbYdHbhbSbuazbz-bsM6mm-c0-4oMEvFp0CAn&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wuJUWYlaRgcJXtViydXI-d8gf309H1_HZrYGV1cPCd0gRP8-V9CDRob_FRkLZ7Z5oc1wQfaJBt7_KKH_F8gamzG2g0CTL8TJQWVOu4tux1oWVPTTJQzhCCw9RLU_9rSsuDFdazsHmTikN98_uRw26THVZXk-pnE5aJwcXcStyxnE0oGd4tvZ4WXItdavSk-GTbfhHMTSxtEkW3KPtPTvob_oqSC1TaIxnAfVD8Zjs0V4&hgt_ver=331370278 playpath=mp4:hulu9/758/60302758/agave50521051_19546618_H264_650.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1
2013-12-01 15:58:52,906 DEBUG [ProcessExecutor] Starting ffmpeg -analyzeduration 10000000 -i rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEd6bhdodwcwdbaYcndMbYdHbhbSbuazbz-bsM6mm-c0-4oMEvFp0CAn&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wuJUWYlaRgcJXtViydXI-d8gf309H1_HZrYGV1cPCd0gRP8-V9CDRob_FRkLZ7Z5oc1wQfaJBt7_KKH_F8gamzG2g0CTL8TJQWVOu4tux1oWVPTTJQzhCCw9RLU_9rSsuDFdazsHmTikN98_uRw26THVZXk-pnE5aJwcXcStyxnE0oGd4tvZ4WXItdavSk-GTbfhHMTSxtEkW3KPtPTvob_oqSC1TaIxnAfVD8Zjs0V4&hgt_ver=331370278 playpath=mp4:hulu9/758/60302758/agave50521051_19546618_H264_650.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1
2013-12-01 15:58:52,928 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEd6bhdodwcwdbaYcndMbYdHbhbSbuazbz-bsM6mm-c0-4oMEvFp0CAn&aifp=sll02152008&slist=hulu9/758/60302758;.international=false&hgt=OZU7Pvs7j27-nhteNno7wuJUWYlaRgcJXtViydXI-d8gf309H1_HZrYGV1cPCd0gRP8-V9CDRob_FRkLZ7Z5oc1wQfaJBt7_KKH_F8gamzG2g0CTL8TJQWVOu4tux1oWVPTTJQzhCCw9RLU_9rSsuDFdazsHmTikN98_uRw26THVZXk-pnE5aJwcXcStyxnE0oGd4tvZ4WXItdavSk-GTbfhHMTSxtEkW3KPtPTvob_oqSC1TaIxnAfVD8Zjs0V4&hgt_ver=331370278 playpath=mp4:hulu9/758/60302758/agave50521051_19546618_H264_650.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
... 2 more
Spaceboy64
Post Tue Dec 03, 2013 4:12 am
Re: Hulu (US only)
I was trying to set this up for some friends who recently got an 80" Sharp Aquos TV.
After quite a bit a of work I got a Serviio signal to the TV on the WiFi. Serviio recognized the TV as a Sharp Aquos. The TV would list the shows I had entered into the Library, but could not play them. I got a message on the TV "Cannot play this file".
I found their internet speed was very slow, .95 bps or something like that. But even at that speed Netflix would show a picture and then buffer all the time.
What could the problem be here?
Post Thu Dec 05, 2013 2:58 pm
Re: Hulu (US only)
jwe000 wrote:Hi,
FFmpeg is old, and possibly also without librtmp support. Check the wiki on tips how to build it from source.
funguide
Post Sun Dec 08, 2013 11:10 pm
Re: Hulu (US only)
Spaceboy64 wrote:I was trying to set this up for some friends who recently got an 80" Sharp Aquos TV.
I am having the same problem with my 60" sharp tv. I was trying to watch this show:
%%http://www.hulu.com/feed/show/15419/episode
There are videos there but I only saw episodes 5,8,9 on the feed- so there are some episodes missing in the feed but none of the videos play. I got the same error message on the TV "Cannot play this file".
Spaceboy64
Post Mon Dec 09, 2013 1:27 am
Re: Hulu (US only)
It was my understanding that Serviio would transcode the video into something that the TV or media player could play. Am I wrong?
If the computer is too slow, or the internet connection is too slow, does it prevent playing?
Is it possible that the Sharp Aquos profile is not doing the right transcoding or something?
Spaceboy64
Post Mon Dec 09, 2013 1:32 am
Re: Hulu (US only)
When I copy that to my browser it shows clips
The proper url is http://www.hulu.com/feed/show/15419/episodes
You forgot the s in episodes. Leaving "episodes" off will show all videos related to the show.
Also, probably reiterating here, shows that require Hulu Plus will only play the first 60 seconds or so and then go on to the next video.
jk50
Post Mon Dec 16, 2013 6:08 pm
Re: Hulu (US only)
I've been having intermittent failures with the Daily Show ( http://www.hulu.com/feed/show/902/episodes ) for a couple of weeks now.
Hulu seems to be shifting back and forth between two different formats on the feed. Other shows work fine even when the Daily Show doesn't.
This is what the feed looks like when it works:
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/" xmlns:atom="http://www.w3.org/2005/Atom" xmlns:dcterms="http://purl.org/dc/terms/" xmlns:activity="http://activitystrea.ms/spec/1.0/" xmlns:thr="http://purl.org/syndication/thread/1.0" xmlns:hulu="http://hulu.com/feed">
  <channel>
    <atom:link type="application/rss+xml" href="http://www.hulu.com/feed/show/902/episodes" rel="self"/>
    <title>Hulu - Episodes for The Daily Show with Jon Stewart</title>
    <link>http://www.hulu.com/feed</link>
    <description>Hulu - Episodes for The Daily Show with Jon Stewart</description>
    <pubDate>Fri, 06 Dec 2013 12:13:51 -0000</pubDate>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e32 - Thu, Dec 5, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/568377#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/568377#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/568377#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib2.huluim.com/video/60310113?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Jon welcomes Jorge Ramos, journalist and anchor of &quot;America with Jorge Ramos,&quot; to the show.</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Fri, 06 Dec 2013 06:27:27 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=2VvfdZDXkpkornWDLWcl3g" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib2.huluim.com/video/60310113?size=720x405&amp;img=1.png" width="720"/>
      <media:credit>Comedy Central</media:credit>
      <dcterms:valid>start=2013-12-06T09:00:00Z; end=2014-01-03T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Thu Dec 05 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e31 - Wed, Dec 4, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/567577#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/567577#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/567577#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib2.huluim.com/video/60309169?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Documentary filmmaker Jehane Noujaim talks about her latest film &quot;The Square.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Thu, 05 Dec 2013 06:34:18 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=0R3oL69ReIsejpygQ90p8g" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib2.huluim.com/video/60309169?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-12-05T09:00:00Z; end=2014-01-02T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Wed Dec 04 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e30 - Tue, Dec 3, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/567092#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/567092#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/567092#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib1.huluim.com/video/60308576?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Actor Jared Leto visits The Daily Show and discusses his new movie &quot;Dallas Buyers Club.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Wed, 04 Dec 2013 07:19:06 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=_fyM3rI4EcH6eqzQv-mBiQ" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib1.huluim.com/video/60308576?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-12-04T09:00:00Z; end=2014-01-01T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Tue Dec 03 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e29 - Mon, Dec 2, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/566447#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/566447#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/566447#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60307894?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Sir Ian McKellen stops by to talk about his new movie &quot;The Hobbit: The Desolation of Smaug.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Tue, 03 Dec 2013 05:23:31 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=4kJXjV2xiwYSoqenxYN_-Q" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib3.huluim.com/video/60307894?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-12-03T09:00:00Z; end=2013-12-31T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Mon Dec 02 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e28 - Thu, Nov 21, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/562683#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/562683#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/562683#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60303406?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Jon welcomes Jennifer Lawrence to the show to discuss her latest movie &quot;The Hunger Games: Catching Fire.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Fri, 22 Nov 2013 06:05:30 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=vacAUCbwAsfLq6sQ9oEcvA" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib3.huluim.com/video/60303406?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-22T09:00:00Z; end=2013-12-20T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Thu Nov 21 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e27 - Wed, Nov 20, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/562083#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/562083#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/562083#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib4.huluim.com/video/60302827?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Tom Brokaw visits The Daily Show to talk about the NBC News special &quot;Where Were You?&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Thu, 21 Nov 2013 06:00:31 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=9pQlxd2JvbHHL8eljVpsrA" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib4.huluim.com/video/60302827?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-21T09:00:00Z; end=2013-12-19T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Wed Nov 20 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e26 - Tue, Nov 19, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/561207#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/561207#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/561207#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib4.huluim.com/video/60302243?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Bill Cosby sits down with Jon and discusses his new comedy special &quot;Far From Finished.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Wed, 20 Nov 2013 05:31:18 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=c9c-I42oldF4v7FGuJsVZA" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib4.huluim.com/video/60302243?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-20T09:00:00Z; end=2013-12-18T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Tue Nov 19 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e25 - Mon, Nov 18, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/560700#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/560700#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/560700#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60301550?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Actress Elizabeth Olsen stops by to talk about her new movie &quot;Oldboy.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Tue, 19 Nov 2013 05:10:09 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=-P0856MyS5ppQdWSmbicLg" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib3.huluim.com/video/60301550?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-19T09:00:00Z; end=2013-12-17T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Mon Nov 18 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e24 - Thu, Nov 14, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/559458#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/559458#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/559458#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib4.huluim.com/video/60300151?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Geoffrey Rush sits down with Jon to discuss his new movie &quot;The Book Thief.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Fri, 15 Nov 2013 06:50:27 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=xgF36dgc_MgLAfZOcliHZg" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib4.huluim.com/video/60300151?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-15T09:00:00Z; end=2013-12-13T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Thu Nov 14 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e23 - Wed, Nov 13, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/558786#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/558786#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/558786#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60299410?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Comedians Keegan Michael Key &amp; Jordan Peele stop by to talk about their television show &quot;Key &amp; Peele.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Thu, 14 Nov 2013 05:19:29 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=c5E36LSgnHmh2yMUBwtqQw" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib3.huluim.com/video/60299410?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-14T09:00:00Z; end=2013-12-12T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Wed Nov 13 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e22 - Tue, Nov 12, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/558255#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/558255#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/558255#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib2.huluim.com/video/60298753?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Joe Scarborough visits The Daily Show to discuss his new book &quot;The Right Path: From Ike to Reagan, How Republicans Once Mastered Politics--and Can Again.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Wed, 13 Nov 2013 05:05:27 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=hWmaMdpZG8w-_EqWXPtWjA" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib2.huluim.com/video/60298753?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-13T09:00:00Z; end=2013-12-11T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Tue Nov 12 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e21 - Mon, Nov 11, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/557565#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/557565#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/557565#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib1.huluim.com/video/60297812?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Author Doris Kearns Goodwin talks about her latest book &quot;The Bully Pulpit: Theodore Roosevelt, William Howard Taft, and the Golden Age of Journalism.&quot;</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Tue, 12 Nov 2013 05:23:16 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=nu9B3vHHB1X-PaSvExnsOg" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib1.huluim.com/video/60297812?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-12T09:00:00Z; end=2013-12-10T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Mon Nov 11 00:00:00 UTC 2013</dcterms:available>
    </item>
    <item>
      <title>The Daily Show with Jon Stewart - s19 | e20 - Thu, Nov 7, 2013</title>
      <guid isPermaLink="true">http://www.hulu.com/watch/556042#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</guid>
      <link>http://www.hulu.com/watch/556042#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</link>
      <description>
        <![CDATA[<a href="http://www.hulu.com/watch/556042#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60295038?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Jon welcomes Patrick Stewart to the show to discuss the plays &quot;No Man's Land&quot; and &quot;Waiting for Godot.&quot;</p><p>Expires in about 12 hours on Fri Dec 06 23:59:59 UTC 2013</p><p>Closed captions available.</p>]]>
      </description>
      <pubDate>Fri, 08 Nov 2013 07:04:07 -0000</pubDate>
      <figure>
        <iframe scrolling="0" height="288" webkitAllowFullScreen="true" src="http://www.hulu.com/embed.html?eid=6F2V8WWYXdcVh3IfQxS8Rg" mozallowfullscreen="true" allowfullscreen="true" frameborder="0" width="512"/>
      </figure>
      <media:thumbnail height="405" url="http://ib3.huluim.com/video/60295038?size=720x405&amp;img=1.png" width="720"/>
      <dcterms:valid>start=2013-11-08T09:00:00Z; end=2013-12-06T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
      <dcterms:available>Thu Nov 07 00:00:00 UTC 2013</dcterms:available>
    </item>
  </channel>
</rss>
This is what it looks like when it's not working:
<feed xmlns:activity="http://activitystrea.ms/spec/1.0/" xmlns:media="http://search.yahoo.com/mrss/" xmlns="http://www.w3.org/2005/Atom" xmlns:dcterms="http://purl.org/dc/terms/" xmlns:thr="http://purl.org/syndication/thread/1.0" xmlns:hulu="http://hulu.com/feed">
  <link href="http://www.hulu.com/feed"/>
  <link href="http://www.hulu.com/feed/show/902/episodes" rel="self"/>
  <updated>2013-12-16T06:23:28Z</updated>
  <id>http://www.hulu.com/feed/show/902/episodes</id>
  <entry>
    <title>The Daily Show with Jon Stewart - s19 | e36 - Thu, Dec 12, 2013</title>
    <link href="http://www.hulu.com/watch/571999#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/571999#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-13T05:40:12Z</published>
    <updated>2013-12-13T05:40:12Z</updated>
    <summary>Actress Evangeline Lilly discusses her new movie "The Hobbit: The Desolation of Smaug."</summary>
    <content type="xhtml">
      <![CDATA[<a href="http://www.hulu.com/watch/571999#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60314338?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Actress Evangeline Lilly discusses her new movie &quot;The Hobbit: The Desolation of Smaug.&quot;</p><p>Closed captions available.</p>]]>
    </content>
    <author>
      <name>Comedy Central</name>
    </author>
    <media:thumbnail height="405" url="http://ib3.huluim.com/video/60314338?size=720x405&amp;img=1.png" width="720"/>
    <dcterms:valid>start=2013-12-13T09:00:00Z; end=2014-01-10T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
    <dcterms:available>Thu Dec 12 00:00:00 UTC 2013</dcterms:available>
  </entry>
  <entry>
    <title>The Daily Show with Jon Stewart - s19 | e35 - Wed, Dec 11, 2013</title>
    <link href="http://www.hulu.com/watch/571257#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/571257#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-12T06:08:28Z</published>
    <updated>2013-12-12T06:08:28Z</updated>
    <summary>Author Reza Aslan visits The Daily Show and talks about his latest book "Zealot: The Life and Times of Jesus of Nazareth."</summary>
      <![CDATA[<a href="http://www.hulu.com/watch/571257#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib2.huluim.com/video/60313673?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Author Reza Aslan visits The Daily Show and talks about his latest book &quot;Zealot: The Life and Times of Jesus of Nazareth.&quot;</p><p>Closed captions available.</p>]]>
    </content>
    <author>
    </author>
    <media:thumbnail height="405" url="http://ib2.huluim.com/video/60313673?size=720x405&amp;img=1.png" width="720"/>
    <dcterms:valid>start=2013-12-12T09:00:00Z; end=2014-01-09T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
    <dcterms:available>Wed Dec 11 00:00:00 UTC 2013</dcterms:available>
  </entry>
  <entry>
    <title>The Daily Show with Jon Stewart - s19 | e34 - Tue, Dec 10, 2013</title>
    <link href="http://www.hulu.com/watch/570602#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/570602#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-11T05:31:36Z</published>
    <updated>2013-12-11T05:31:36Z</updated>
    <summary>Amy Adams sits down with Jon to discuss her new movie "American Hustle."</summary>
      <![CDATA[<a href="http://www.hulu.com/watch/570602#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib2.huluim.com/video/60313025?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Amy Adams sits down with Jon to discuss her new movie &quot;American Hustle.&quot;</p><p>Closed captions available.</p>]]>
    </content>
    <author>
    </author>
    <media:thumbnail height="405" url="http://ib2.huluim.com/video/60313025?size=720x405&∓img=1.png" width="720"/>
    <dcterms:valid>start=2013-12-11T09:00:00Z; end=2014-01-08T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
    <dcterms:available>Tue Dec 10 00:00:00 UTC 2013</dcterms:available>
  </entry>
  <entry>
    <title>The Daily Show with Jon Stewart - s19 | e33 - Mon, Dec 9, 2013</title>
    <link href="http://www.hulu.com/watch/569756#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/569756#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-10T05:53:29Z</published>
    <updated>2013-12-10T05:53:29Z</updated>
    <summary>Former diplomat from Pakistan, Husain Haqqani, stops by to discuss his new book "Magnificent Delusions: Pakistan, the United States, and an Epic History of Misunderstanding."</summary>
      <![CDATA[<a href="http://www.hulu.com/watch/569756#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib2.huluim.com/video/60312273?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Former diplomat from Pakistan, Husain Haqqani, stops by to discuss his new book &quot;Magnificent Delusions: Pakistan, the United States, and an Epic History of Misunderstanding.&quot;</p><p>Closed captions available.</p>]]>
    </content>
    <author>
    </author>
    <media:thumbnail height="405" url="http://ib2.huluim.com/video/60312273?size=720x405&amp;img=1.png" width="720"/>
    <dcterms:valid>start=2013-12-10T09:00:00Z; end=2014-01-07T23:59:59Z; scheme=W3C-DTF</dcterms:valid>
    <dcterms:available>Mon Dec 09 00:00:00 UTC 2013</dcterms:available>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/568377#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/568377#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-06T06:27:27Z</published>
    <updated>2013-12-06T06:27:27Z</updated>
    <summary>Jon welcomes Jorge Ramos, journalist and anchor of "America with Jorge Ramos," to the show.</summary>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/567577#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/567577#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-05T06:34:18Z</published>
    <updated>2013-12-05T06:34:18Z</updated>
    <summary>Documentary filmmaker Jehane Noujaim talks about her latest film "The Square."</summary>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/567092#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/567092#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-04T07:19:06Z</published>
    <updated>2013-12-04T07:19:06Z</updated>
    <summary>Actor Jared Leto visits The Daily Show and discusses his new movie "Dallas Buyers Club."</summary>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/566447#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/566447#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-12-03T05:23:31Z</published>
    <updated>2013-12-03T05:23:31Z</updated>
    <summary>Sir Ian McKellen stops by to talk about his new movie "The Hobbit: The Desolation of Smaug."</summary>
    </content>
    <author>
    </author>
    <media:thumbnail height="405" url="http://ib3.huluim.com/video/60307894?size=720x405&∓img=1.png" width="720"/>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/562683#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/562683#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-11-22T06:05:30Z</published>
    <updated>2013-11-22T06:05:30Z</updated>
    <summary>Jon welcomes Jennifer Lawrence to the show to discuss her latest movie "The Hunger Games: Catching Fire."</summary>
      <![CDATA[<a href="http://www.hulu.com/watch/562683#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60303406?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" bquot;America with Jorge Ramos,com/watch/567577#http%3A%2F%2Fwwwiframe scrolling= allowfullscreen= border=Thu Nov 14 00com/embed /
    ord00html?eid=_fyM3rI4EcH6eqzQv-mBiQ10//wwwhttpp/huluActor Jared Leto visits The Daily Show and discusses his new movie link href=∓720er="0" /></a><p>Jon welcomes Jennifer Lawrence to the show to discuss her latest movie &qu height=pngCDATA59Z; scheme=W3C-DTFimg=1/titleWed, 13 Nov 2013 05
        p∓Thu Dec 05 00huluimot;The Hunger Games: Catching Fire.&quot;</p><p>Closed captions available.</p>]]>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/562083#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/562083#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-11-21T06:00:31Z</published>
    <updated>2013-11-21T06:00:31Z</updated>
    <summary>Tom Brokaw visits The Daily Show to talk about the NBC News special "Where Were You?"</summary>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/561207#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/561207#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-11-20T05:31:18Z</published>
    <updated>2013-11-20T05:31:18Z</updated>
    <summary>Bill Cosby sits down with Jon and discusses his new comedy special "Far From Finished."</summary>
      <![CDATA[<a href="http://www.hulu.com/watch/561207#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib4.huluim.com/video/60302243?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Bill Cosby sits down with Jon and discusses his new comedy special &quot;Far From Finished.&quot;</p><p>Expires in 2 days on Wed Dec 18 23:59:59 UTC 2013</p><p>Closed captions available.</p>]]>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    <link href="http://www.hulu.com/watch/560700#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"/>
    <id>http://www.hulu.com/watch/560700#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes</id>
    <published>2013-11-19T05:10:09Z</published>
    <updated>2013-11-19T05:10:09Z</updated>
    <summary>Actress Elizabeth Olsen stops by to talk about her new movie "Oldboy."</summary>
      <![CDATA[<a href="http://www.hulu.com/watch/560700#http%3A%2F%2Fwww.hulu.com%2Ffeed%2Fshow%2F902%2Fepisodes"><img src="http://ib3.huluim.com/video/60301550?size=720x405&img=1.png" align="right" hspace="10" vspace="10" width="720" height="405" border="0" /></a><p>Actress Elizabeth Olsen stops by to talk about her new movie &quot;Oldboy.&quot;</p><p>Expires in 1 day on Tue Dec 17 23:59:59 UTC 2013</p><p>Closed captions available.</p>]]>
    </content>
    <author>
    </author>
  </entry>
</feed>
/contentcom%2Ffeed%2Fshow%2F902%2Fepisodes00Z; end=2013-12-18T23/published
funguide
Post Sun Dec 22, 2013 7:24 am
Re: Hulu (US only)
This seems to be a transcoding issue. Probably the video type for transcoding in the sharp profile is wrong. Someone in the CBS plugin forum said there were some video profiles missing in the sharp profile, but I tried that and it didn't fix the issue. If someone figures it out let us know.
jabrown0604
Post Wed Dec 25, 2013 4:28 pm
Re: Hulu (US only)
I am having the same issue as jk50. http://www.hulu.com/feed/show/81/episodes Psych will sometimes change its format in the rss. When viewed in firefox, you will will have the pictures associated with the video when it is working. When it is not working the pictures will not be there and it will be just links. Is there a way to ignore this error and still grab the video link?
jk50 wrote:I've been having intermittent failures with the Daily Show ( http://www.hulu.com/feed/show/902/episodes ) for a couple of weeks now.
  <channel>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
    <item>
      <description>
      </description>
      <figure>
      </figure>
    </item>
  </channel>
</rss>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
  <entry>
    </content>
    <author>
    </author>
  </entry>
</feed>
“Those who have succeeded at anything and don’t mention luck are kidding themselves.”
Server-Mac Mini / OS-WHS 2011 SP1 / TV/HTS-Sharp Aquos/Samsung HT-C6600
Spaceboy64
Post Thu Dec 26, 2013 11:42 pm
Re: Hulu (US only)
How do I install the Groovy plugin on a Mac? Where do I put it?
Thanks!
funguide
Post Fri Jan 03, 2014 6:44 am
Re: Hulu (US only)
What does the below error mean? It seems that files from 'rtmpe' such as from hulu and cw plugin are not playing. I get the error cannot playback file.
HandShake: Type mismatch: client sent 6, server answered 9
RTMP_ReadPacket, failed to read RTMP packet body. len: 4620685
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEaNclcod8c_cHaRdzc7bxdbczcSbsc3aT-bsXLLd-c0-5pGDvFn0Dzp&aifp=sll02152008&slist=hulu22/221/60299221;.international=false&hgt=OZU7Pvs7j27-nhteNno7wj0MsMyMJhdntL8ZdIwtexZ5WZ2x4TdHADnIcJWGAHzqxlDHyBXBAvWUR9WVsdhYm22ELr5vIIz0-7CYn2b7X0xOtbj9MsvRvU2GiK-9EvYHVSDIWgLrTcKlAg3iYptAMYrMmkDiMrfjic4gteNH4-rdG-TKynwDD7xiuBYjlR7ih367jN38UIphy3kZSRvuxT8AaKguYOwYnR_NPJEAmbazFqAmGKlUyJCNqTaO0Tj1&hgt_ver=331370278 playpath=mp4:hulu22/221/60299221/agave50517527_19323429_H264_1000.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Unknown error
2014-01-03 00:31:59,330 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-1000000010002474-18-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-1000000010002474-18-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:132)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Return to Available plugins
