SOPCAST VIDEO WEB RESOURCE
vindalooman
Post Mon Jan 06, 2014 9:35 am
Re: SOPCAST VIDEO WEB RESOURCE
Hello
I am new on Serviio, but I managed having sopcast channels play on my Panasonic Viera
(I am using the Panasonic 2013 profilehttp://forum.serviio.org/viewtopic.php?f=13&t=12367 )
When I use the grooyv plugin and sopcast the video stream works correctly, while I get no audio.
Could it be something I have to change in the profile?
I can post any log you should need, even if I don't see anything strange in the serviio log
Thanks for your help
VindalooMan
Post Mon Jan 06, 2014 6:41 pm
Probably. Do an ffmpeg on the sopcast stream (ffmpeg -i http://localhost:8902) to find out what the streams are and then fix the panny profile appropriately, getting help from the panny thread.
vindalooman
Post Mon Jan 06, 2014 11:21 pm
Thanks I confirm it is 99% a problem related to the profile.
I just post here the workaround, maybe it can help someone.
Switching to this modified DirectTV profile (viewtopic.php?f=13&t=14745)
I can get video and audio.
I will continue in the Panasonic forum even if I am no video/audio expert so I just can give support with testing
VindalooMan
madbrain
Post Fri Jan 10, 2014 5:19 pm
Hello to all,
I am having a problem with my Samsung LE32D550 (D Series). Since I have updated to serviio 1.4 my sopcast channels keeps dropping every 2 minutes or so. I am using Samsung C/D profile on Windows 7. In the previous serviio version I did modified the lines in the Samsung C/D/E/ profile and it worked just fine with no drops. Any idea where and what to modify exactly for the serviio 1.4?
Thanks for your help and have a great day
madbrain
Post Wed Feb 05, 2014 6:11 pm
nobody? need help with that issue, THANK YOU!
Iveky
Post Wed Feb 05, 2014 6:16 pm
try use your modification on EF profile?
or copy whole profile (that worked) from 1.3.1 to 1.4 ?
madbrain
Post Sun Feb 23, 2014 12:49 pm
I manage to make it work, thanks for your support. *I edited the Samsung C/D Profile, by inserting those two lines under the first line in the OnlineTranscoding section:
<Matches container="mpegts" vCodec="h264"/> <!-- jhb50 fixes serviio h264.ts to h264.ts transcode bug -->
<Matches container="mpeg" vCodec="h264"/> <!-- optional -->
It was an easy job, don't know why it didn't work first time.
Thank you again, ya'll doing a great work here.
mitza4fun
Post Sun Mar 23, 2014 7:43 pm
Hi to all!
My sopcast HD stream drops every 30 seconds and pass to #3,#4..#7! I have a Samsung F6400..I have no clue what to do, can someone help me? Thanks a lot !
Iveky
Post Sun Mar 23, 2014 8:03 pm
nothing. samsung is very sensitive, and immediatelx drops.
mitza4fun
Post Sat Apr 05, 2014 4:48 pm
mitza4fun wrote:Hi to all!
I'm happy to say that i figuered it out how to solve this problem! Who is interesed to make it work without drops, PM! Or someone from staff, contact me to post this on first page!
Iveky
Post Mon Apr 07, 2014 1:34 pm
why not write that solution also here?
Post Tue Apr 08, 2014 4:14 pm
This was his response, but it makes no sense to me.
Hi! So, the problem it is not at your plugin! I think i tricked serviio a little!
So, i start stream normal with this link for example " sop://broker.sopcast.com:3912/122832 " normal definition, then(right click-properties-copy adress 127...)(paste on serviio, live stream) . When you play this stream on tv, it shows the message: " The file could be impossible to play" or something like that, press ok, and everything works.
Then, while this stream is playing, I play hd stream on sopcast. The sd stream stops at tv, and hd stream start at pc, at sopcast.
Then, i go to my tv, i press again on that old stream, appears that message, and hd stream works normally, without drops!
I hope you understand, my english is not very good.
lobillo
Post Sun Apr 13, 2014 12:57 pm
I've done all that you explain the changes and continue with the same problems. Someone can help me?
hird
Post Sun Apr 27, 2014 7:09 pm
Hi
I did everything as writen in the first post: put groovy file in the plug in folder; set the web resource tab, edit the profiles xml. On the TV I see Serviio Online Sopcast folder with 7 sopcast menu.
Still dropping the connection on the TV every 2 min or so - and have to manually restart.
I use Serviio 1.4 .1 and Samsung TV UE40ES6340 (E series)
Only difference to the first post is that using Serviio 1.4.1 version the profiles xml dows not have C/D/E profile (as indicated in the initial post) but E/F Samsung profile (and A, B, and C/D profiles).
I suppose this is the reason for the first line being different too:
instead of the indicated line:
the xml contains this:
<Matches container="mp4" aCodec="lpcm"/> (missing the part - vCodec="mpeg4")
Regardles, I copied the two lines jhb50 suggested after the first line. But still dropping connection.
Pleas help.
I didn't use previous versins of serviio - so I don't know if would have worked out with them
Iveky
Post Sun Apr 27, 2014 8:16 pm
forget it, I never got sopcast to work that way. samsung is very picky and immediately drop connection.
setup sopcast player on pc and stream dektop or better, lay down hdmi cable from pc to tv :)
hird
Post Tue Apr 29, 2014 6:50 pm
Iveky wrote:forget it, I never got sopcast to work that way. samsung is very picky and immediately drop connection.
My PC is in another room than the TV set too far for direct hdmi connection. But I would try desktop streaming, but I don't know how to set it up. I heard that it can be done through VLC player but I really couldn't figure it out
Could you tell me how to set up desktop streaming - here or in PM ?
Iveky
Post Tue Apr 29, 2014 8:42 pm
i am in separate rooms too. never tried desktop streaming but vlc should be right way.
i bought 15m hdmi cable, made a hole in wall and have no problems anymore.
Post Tue Apr 29, 2014 9:47 pm
Then why bother with Serviio at all just play everything on your PC using the TV as the Monitor.
The point of Serviio and the plugin is to use DLNA to stream to your TV.
See the Wiki for the steps to stream the desktop.
Both work fine.
Iveky
Post Wed Apr 30, 2014 6:09 am
i use serviio as dlna server...
if you stream desktop then you cant surf the net, using hdmi cable (they are cheap now) i have sopcast player in full screen on tv (second desktop) while wife surf the net on main desktop.
hird
Post Wed Apr 30, 2014 6:40 pm
Iveky wrote:i use serviio as dlna server...
When I chose TV the whole point was DLNA. I used cables beforethats just a different thing.
Return to Available plugins
Users browsing this forum: Baidu [Spider] and 3 guests
