A.P.P for Serviio 1.4.1 - Last Update (24/10/2013)
How often do you check to see if there is a plugin pack update?
Daily
37
19%
Weekly
77
39%
Monthly
63
32%
Never
20
10%
Total votes : 197
Post Wed Aug 14, 2013 4:43 pm
Re: A.P.P for Serviio 1.3 - Last Update (09/08/2013)
If the developers would keep the plugins on my site updated, i could have this zip file created automatically when some one downloads it.
amunoz_tico
Post Sat Sep 07, 2013 4:51 am
Dear friends...
How can I install those plug-in on Synology?
Best Regards!
Samsung PN60E7000, UN46C7000, BD-C6900, BD-D5500, BD-E5700 ¬ Sony PS3, Wii ¬ LG BD670 ¬ Pioneer VSX-820-K ¬ Bose Acoustimass 15 ¬ Synology DS413j ¬ Cisco EA4500 ¬ Monster HDP2400
duongz
Post Thu Dec 19, 2013 12:00 am
Re: A.P.P for Serviio 1.3.1 - Last Update (24/10/2013)
hi, i've tried every version of serviio, used the plugins, added the urls under online web resources, but when I go to my ps3 under "videos" and "online" it says no tracks/nothing is there, i've also tried to find local files on my computer but to no avail. any help? thanks.
Marksuk
Post Thu Dec 19, 2013 5:04 pm
duongz wrote:hi, i've tried every version of serviio, used the plugins, added the urls under online web resources, but when I go to my ps3 under "videos" and "online" it says no tracks/nothing is there, i've also tried to find local files on my computer but to no avail. any help? thanks.
Very few of the links work nowadays.
Try adding this as it works (19/12/2013) add it as a live stream.
http://91.202.1.17:7777/udp/239.10.13.1:20620
georgian
Post Tue Dec 31, 2013 1:50 pm
for the life of me i cant get the plugins to work
i did as it says in the description all the .groovy files are in the plugin folders but it wont show up in the online folder
i am on the latest version of serviio using win7 64bit version..... :roll: :roll: :roll: :roll: :roll:
georgian
Post Tue Dec 31, 2013 1:56 pm
here is a screenshot of this
p.s. the sopcast 'plugin' well its not actually a plugin i manually added the sopcast method
as u can see it cant see ANY of the plugins that r in the plugins directory
Marksuk
Post Tue Dec 31, 2013 6:11 pm
I dont bother with the mainly outdated plug-ins and only add recent Live streams. I test most of them in VLC.
georgian
Post Tue Dec 31, 2013 6:45 pm
any1 wanna help me about here? :)
Marksuk
Post Tue Dec 31, 2013 7:49 pm
georgian wrote:any1 wanna help me about here? :)
Download this file and import it into Serviio in online sources.
Link deleted.
Your online sources list will then populate with many channels after a little while.
georgian
Post Tue Dec 31, 2013 8:25 pm
:o :o :o wow it actually worked
THANK U
so for future reference,what seemed to be the problem?
Marksuk
Post Tue Dec 31, 2013 9:30 pm
A lot of the streams on this forum are out of date and do not work, these in the back up file will slowly disappear over time.
Some might not work according to where in the world you are. Most do work, some are better than others.
Marksuk
Post Tue Dec 31, 2013 9:35 pm
Copy some streams across from here
http://www.vlc.eu.pn/
and try your luck :)
georgian
Post Tue Dec 31, 2013 9:50 pm
all of them are SD? i dont see no HD there :)
zhilinskiy
Post Sun Aug 24, 2014 5:36 pm
one year has passed.
where the new version?
WildRushSykes
Post Sat Oct 25, 2014 7:31 pm
Wow a year has passed :shock: Sorry for the lack of updates guys and gals I will be doing regular updates as per usual from now on :D Things in my life got all screwy but things are back to normal now so buisness as usual.
guavi
Post Tue Feb 03, 2015 9:41 pm
Re: A.P.P for Serviio 1.4.1 - Last Update (24/10/2013)
Hello friends.
My TV "50K370 Hisense TV 50"does not allow me to see any plugin.
What should I do? I have all the plugins into the folder.
a7mag3ddon
Post Fri Feb 27, 2015 6:36 pm
I have been trying for a while to get these plug ins / packs to work but nothing so far, are plugins no good on serviio?
Post Fri Feb 27, 2015 9:05 pm
Just installing the plug-in does nothing in Serviio. They are strictly for enabling online streaming sources. After the plug-ins are placed in the plug-in folder, you need to configure the online source in the console under the Library/Online Sources tab. How to do this is described in the forum sub-group for each plug-in.
a7mag3ddon
Post Fri Feb 27, 2015 9:48 pm
Oh. I see. But I read on here that serviio detects the plugins and configs itself to the stream
stefana888
Post Wed Jul 15, 2015 7:05 pm
I think this thread shouldn't be sticky anymore. It is outdated and its plugin collection is not maintained which confuses new Serviio users since the plugins are not working.
Return to Available plugins
