A.P.P for Serviio 1.4.1 - Last Update (24/10/2013)
Thanks! Very usefull
Re: All Plugins Pack For Serviio 1.0.1 - Last Updated (14/11
Your welcome
Re: All Plugins Pack For Serviio 1.0.1 - Last Updated (19/11
WildSkies, can you exclude the NHL groovy from the pack, it requires for the user to enter their username/password
So if a user copies all the groovys in their plugin folder, this groovy keeps popping up with errors in the logs
Xmantium wrote:WildSkies, can you exclude the NHL groovy from the pack, it requires for the user to enter their username/password
Well all i did was download each groovy and zip them up so the NHL groovy has never been used and is the same way it was uploaded without any login info added so not sure why its throwning up errors but removed it anyway
Re: All Plugins Pack For Serviio 1.0.1 - Last Updated (17/12
Do any of the plugins need updating for version 1.1 I haven't noticed anything yet.
Plugins should be working fine for Serviio 1.1
Only difference is plugin developers can put version number for Serviio v1.1 otherwise Serviio defaults it to v1
Re: All Plugins Pack For Serviio 1.1 - Last Updated (21/12/1
hi!
i need a help...
sorry for my english
i had download this pack and now don`t know what to do with it. i have mac 10.6. there isn`t any folder with serviio plugins... i have to create it? and where, in library or somewhere else? i saw instruction only for linux and windows... may be i`m stupid.
and such question: can i watch in tv (philips) programs from sites like http://tvi.ua (http://tvi.ua/stream or http://tvi.ua/program/shalenyy_tyzhden_ ... __30112012)
but this programs is very good
better then other – i tried 3 before find this
thank you for help and attention, uliana
i need a help...
Re: All Plugins Pack For Serviio 1.1 - Last Updated (04/02/2
I dont have a mac so dont know first hand what to do. Im sure this is brought up on the serviio wiki and if that dosent help you please raise a support question in the relevant section.
Re: A.P.P for Serviio 1.2.1 - Last Update (31/03/2013)
I have enjoyed using Serviio for the past 8 months. Great job ! I usually catch up on the TV programs that I miss that are streamed online. I noticed that since this past weekend the CBS groovy is not working. All of the CBS programs in my library are not showing up anymore. Any chance of updating the CBS groovy? Also is there any possibility of adding a CBSNews groovy?
Anyway, thanks for providing this program and your support.
DrJay wrote:I have enjoyed using Serviio for the past 8 months. Great job ! I usually catch up on the TV programs that I miss that are streamed online. I noticed that since this past weekend the CBS groovy is not working. All of the CBS programs in my library are not showing up anymore. Any chance of updating the CBS groovy? Also is there any possibility of adding a CBSNews groovy?
I too have used serviio for a good period of time and among my favorite plugins Hulu and CBS have to be at the top. You guys do a great job getting obscure feeds to work can someone please fix the CBS plugin.
Re: A.P.P for Serviio 1.2.1 - Last Update (14/06/2013)
Hi @WildRushSykes,
Can you please update Stepashka.com (http://forum.serviio.org/viewtopic.php?f=20&t=5432) Web Resource plugin in APP?
I just updated Turbotv.in pluggin.
Will you be able to update the plugin from the latest updated version here ?
Just got back from a long needed break so sorry if the pack is way out of date but rest assured it will be updated fully soon
Re: A.P.P for Serviio 1.2.1 - Last Update (25/07/2013)
Hiya
Any chance of as opposed to download a zip file etc. You move your work to github.
That way, all that is needed it to run the command 'git pull'.
Hope you will give me suggestion some thought.
Thank for the work you do.
I will look into it. Ive never used github before but i like tampering with new stuff so i will give it a go
Re: A.P.P for Serviio 1.3 - Last Update (09/08/2013)
I updated the CBS plugin, after some changes in the CBS.com site.
The latest version is here:
viewtopic.php?f=20&t=5401&start=40#p69616
Just let you know in case you want to update the plugin pack.
Regards,
Leonardo
Regards,
Leonardo
@Leo, i already told WildSkies to update it over a month ago and he has done so
I find that many of the plugins in this pack are way out of date, in addition to duplicates with different dates, hence they cannot be expected to work. Consequently I do not support Problem reports for plugins loaded from this pack. The proper way to get and activate a plugin is to go to the plugins folder for that folder, open the first post, download the current version and follow the instructions.
jhb instead of bitching and moaning tell me which plugins are out of date and i will fix them
Or if you think you can do a better job i will let you take over maintaining this thread.
I think users who choose to use your compilation should be aware of the quality of the pack, and I don't think raising the issue qualifies as bitching. You chose to create it and you should accept the responsibility for keeping it current, just as I attempt to keep my plugins current. One starting point for you, as I think I have suggested before, is to maintain your list in alpha order (which would help users check their plugins against the log and help you to eliminate duplicates) and to add the plugin version number you are distributing (which would allow users to check the versions they are using from their log, against the latest versions from you). If you are not prepared to put in the effort to maintain a current pack which contributes these benefits then you should stop publishing it.
