web app and serviio integration
sync_dev
Post Fri Jan 25, 2013 10:55 am
hi,
i installed serviio streaming server.
Now i have a web application and i need to reproduce some videos located on my serviio server.
Is it possible?
Can i embed just the serviio video player in my html page? How can i do it?
Thanks!
Post Fri Jan 25, 2013 2:49 pm
Re: web app and serviio integration
If you have Pro edition, you can use the CDS API, it'll come back with a URL to the file. You can then point to that URL with a (Flash) player
sync_dev
Post Wed Jan 30, 2013 3:05 pm
can i use it with free trial edition?
what is the correct url to call for login to api?
thanks
Post Wed Jan 30, 2013 4:56 pm
Yes you can. Check out the CDS API documentation
