Samsung UI
alamata
Post Thu Jul 19, 2012 5:33 pm
Samsung UI
Hey,...
i have discover serviio in the past 2 hours,... ;)
first i would like to say thx for this soft,... ;)
...i have already one question,
" is there already an UI for the samsung tv,...?"
like per example le plex plugin for samsung tv available on the samsugn store,....
if not
i will be interressed to make one,...
what is the best way to begin,...
thx for your comprehension,...
Post Thu Jul 19, 2012 5:49 pm
Re: Samsung UI
I think someone wanted to create one, try to search the forum. Otherwise wait for 1.0 is out, it'll have an API that you could probably use.
alamata
Post Thu Jul 19, 2012 5:52 pm
Re: Samsung UI
thx for your rapid answer,... ;)
i will wait the 1.0 API ,...
thx for the information,... ;)
during this waiting i will browse the forum,...
thx
Wingsgb
Post Wed Aug 22, 2012 5:43 pm
Re: Samsung UI
I don't know if the above has ever been started but over the next month im going to have ago at looking into creating the Samsung app for a better user experience. The aim is to have the media content displayed more like the web browser feature in 1.0 so users can see a summery and title cover.
With out getting into too much detail I have one question.
Im going to want the app to have two login/connecting features for the different user types.
One is were its done through the web using the new api were serviio isn't on the local network.
The second option will be to connect via the network (upnp) as how serviio would normally work but by doing this will I be able to access the meta data like the web browser dose by having film descriptions ect
Post Wed Aug 22, 2012 6:43 pm
Re: Samsung UI
Descriptions etc are there, there are some things that are not available via DLNA such as video type [movie, episode, unknown] and online ids eg IMDb or TMDb but that is only needed if you want to query those databases for high resolution artwork without performing an additional search first.
Best bet is use a tool to examine responses.
stevegal
Post Tue Jan 08, 2013 10:54 pm
Re: Samsung UI
I'm slowly! Working on a ui for a 2011 samsung tv. It's progressing, and I'll open source the code on google code once I have something others can build on. The MAPLE browser on this model is a bit of a pain, but so far I can login and query fine via the rest api. I need to confirm playback (hopefully later this week), sort out how I want the ui to work with a remote, and add links into imdb etc for info. I know I started this ages ago, but progress is being made!
