add items to serviidb
Post Fri Feb 24, 2012 8:02 pm
I am ready to add items to serviidb. Xmantium has been busy adding plugins and feeds for UK. Below is the way that you add plugins and media resources. If you have any questions let me know.
To add a plugin you do the following:
1. click on add content in the navigation menu.
2. Click on plugin
3. Type in Plugin Name
4. browse to plugin and upload it.
5. Enter Revision info
6. Enter text or basic html in body
7. Since it is a new plugin you can cut and paste or type in the plugins field. (to the right you will see a small wheel animation, once the animation has stopped you can click on save).
8. Click on Save
Now when you add a new media Resource you can select the plugin under plugins.
Xmantium
Post Sat Feb 25, 2012 2:29 pm
Re: add items to serviidb
Can i make a new proposal. Plugin Catergories. So scrap the global Catergory. Users really add feeds based on the type of feed they want to add
Each plugin should have its own catergory for example
iPlayer --> TV
--> Radio
4oD --> Doumentary
--> Drama
-->Reality
ect
YouTube --> Standard feeds
--> Music Channels
--> Comedy Channels
ect
RSS video feeds can have its own catergories
Live video Feeds can also have it own catergories
Post Sun Feb 26, 2012 12:23 am
I have been thinking about this today. I think I am going to leave the global category the way it is. I can make it look like there are separate categories for each plugin. But still be able to pull up all in each category. Gives the most flexability
Sent from my DROIDX using Tapatalk
