ServiiDroid (Android Console) - Get it on Google Play
Post Sun Feb 23, 2020 3:31 pm
Re: ServiiDroid (Android Console) - Get it on Google Play
co5mo wrote:any plans to add new indexed file notification? thanks
Hi, I did implement it at one point but it doesn't really work very well as you have to constantly poll the server. I can take a look to see if there might be a better way to do it with the latest API.
smithclarkson02
Post Wed Mar 18, 2020 2:55 am
Re: ServiiDroid Won't Open After Android O Update
Still working on Google Pixel Android O https://9appsapk.vin https://VidMateapp.vin https://vlc.vin/
Post Sat Jun 06, 2020 2:59 pm
Very overdue but 3.7 is now rolling out on Google Play. Please do let me know of if you have any feedback.
=== 3.7 ===
*Full support for Serviio 2.0/2.1
**Create and assign users to control access to media (Serviio Pro only)
**Display names and ignored folders/extensions for shared folders
*Now using Firebase as the backend to manage crash reports and analytics
*Minimum version of Android is now Android 4.1
*Updated SDK, build tools and libraries
xpaceseven
Post Fri Oct 16, 2020 6:59 pm
App worked great I could turn it on and off to the main TV to keep the kid off of it. Now it doesn't do anything. Please update app!
flisterfive
Post Fri Jan 15, 2021 10:47 am
Downloaded and launched. It immediately saw the v1.10 Serviio server on my LAN. Seems to do everything I need it to do (including a "refresh" when required). I've turned off the "Serviio updating" as v1.10 seems to do the job nicely for me.
Post Sun Apr 11, 2021 4:34 pm
Forget to post that a new update went live last week.
=== 3.7.1 ===
*Fixed crash when changing Metadata source
Uno
Post Sun May 15, 2022 1:56 pm
Thank you
SlimShaggy
Post Sat May 18, 2024 11:55 am
No longer available on Google Play
schabelf
Post Tue Aug 05, 2025 12:08 am
Is there someone out there who knows what happened to this app? Did the developer just abandon it or is it just not compatible with the latest versions of Android?
SlimShaggy
Post Tue Aug 05, 2025 6:40 am
I downloaded the APK and it works on Android 14.
Previous
