Web UI in Ajax (Mobile & desktop edition)
anerDev
Post Sun Oct 28, 2012 4:55 pm
Re: Web UI in Ajax (Mobile & desktop edition)
I download the console for mac and mod the file at Serviio-Console.app/Contents/Info.plist
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<plist version="1.0">
  <dict>
    <key>CFBundleName</key>
    <string>Serviio-Console</string>
    <key>CFBundleShortVersionString</key>
    <string>1.0.1</string>
    <key>CFBundleGetInfoString</key>
    <string>1.0.1 (c) 2009 - 2011 Petr Nejedly</string>
    <key>CFBundleAllowMixedLocalizations</key>
    <string>false</string>
    <key>CFBundleInfoDictionaryVersion</key>
    <string>6.0</string>
    <key>CFBundleExecutable</key>
    <string>JavaApplicationStub</string>
    <key>CFBundleDevelopmentRegion</key>
    <string>English</string>
    <key>CFBundlePackageType</key>
    <string>APPL</string>
    <key>CFBundleSignature</key>
    <string>????</string>
    <key>CFBundleIconFile</key>
    <string>serviio.icns</string>
    <key>Java</key>
    <dict>
      <key>MainClass</key>
      <string>org.serviio.console.ServiioConsole</string>
      <key>JVMVersion</key>
      <string>1.6+</string>
      <key>ClassPath</key>
      <array>
        <string>$JAVAROOT/jul-to-slf4j.jar</string>
        <string>$JAVAROOT/log4j.jar</string>
        <string>$JAVAROOT/org.restlet.ext.net.jar</string>
        <string>$JAVAROOT/org.restlet.ext.xstream.jar</string>
        <string>$JAVAROOT/org.restlet.jar</string>
        <string>$JAVAROOT/serviio-client.jar</string>
        <string>$JAVAROOT/serviio.jar</string>
        <string>$JAVAROOT/slf4j-api.jar</string>
        <string>$JAVAROOT/slf4j-log4j12.jar</string>
        <string>$JAVAROOT/xstream.jar</string>
        <string>$JAVAROOT/config</string>
      </array>
      <key>VMOptions</key>
      <string>-Xms5M -XX:+UseParNewGC -XX:MinHeapFreeRatio=5 -XX:MaxHeapFreeRatio=10</string>
      <key>Properties</key>
      <dict>
        <key>serviio.home</key>
        <string>$JAVAROOT</string>
        <key>java.net.preferIPv4Stack</key>
        <string>true</string>
      </dict>
    </dict>
[b]    <key>serviio.remoteHost</key>
    <string>192.168.1.9</string>[/b]
  </dict>
</plist>
I have launch the app but don't work ! Watch the screen shot and the log (attach file zip)
pc5dczc_file.zip
(45.01 KiB) Downloaded 1289 times
Post Sun Oct 28, 2012 5:02 pm
Thats not quite right, change it to:
  <dict>
    <key>Java</key>
    <dict>
      <array>
      </array>
      <dict>
      </dict>
    </dict>
  </dict>
</plist>
anerDev
Post Sun Oct 28, 2012 5:27 pm
*.* WOOORKK !!!
tnank u so much !!! Thank thank u thank u !!!
Another question:
- Why an user can't add manually the folder in a simple conf file ?
kairoh
Post Wed Nov 21, 2012 9:47 pm
Re: Web UI in Restful Ajax
Hi, sorry for the delay...
Here is the fix release for Serviio 1.0.1.
There are 2 editions : Win and Unix.
Available on the homepage or bitbucket project.
==== 1.0.1-b ====
* Fixed invalid accessGroupIds management (issue #20).
* Fixed free licence display.
* Fixed "Initializing status" color.
Have fun!
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
qoolbox
Post Thu Nov 22, 2012 12:46 pm
Thanks Kairoh, i test this immediatly on Thecus NAS :D
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
qoolbox
Post Thu Nov 22, 2012 1:29 pm
first test :
In Library > Shared Folder
Cannot " Add local " or " Add Path " :(
error message
Error: Cannot read property '1' of undefined.
When i use Chrome as Browser
Error: data.accessGroupIds is undefined.
When i use FireFox Browser
here the about :
http://www.tsuga.fr
Post Thu Nov 22, 2012 3:00 pm
Same problem than qoolbox ...
+ I notice that a serviio.log file was created under "C:\log\serviio.log", otherwise my serviio install directory is : C:\Program Files\Serviio\log, why is not the same path ?
C:\log\serviio.log:
2012-11-22 09:38:12,023 INFO  [RestletProxy] Starting WebUI
2012-11-22 09:38:12,027 INFO  [RestletProxy] Starting Serviio WebUI on port 8123
npuser
Post Fri Nov 23, 2012 12:42 am
@qoolbox I have not tested this myself but quick glance at your screenshots show you are at webui 1.01-a I am not sure if it's a wrong ver info in what supposed to be 1.01-b per change log. May be you somewhat still have the old build loaded instead of new build!!! Just thinking out loud.....
Npuser
qoolbox
Post Fri Nov 23, 2012 9:04 am
you right the Webui display well 1.01-a version...
but i well used
http://kairoh.bitbucket.org/serviio-webui/dist/serviio-webui-unix-1.0.1-b.tar.gz
May kairoh screw up, making the archives :roll:
anyway i will redo the thecus serviio module, to be sure i am not crazy
http://www.tsuga.fr
raulfg3
Post Sun Nov 25, 2012 7:54 am
qoolbox wrote:you right the Webui display well 1.01-a version...
but i well used
The same here, I use unix version, and version show 1.0.1.a regardless I install version b, and of course do not work ( do not permit to add folders)
qoolbox
Post Sun Nov 25, 2012 5:02 pm
I redid the Thecus Module, and i confirm :(
still in version "a"
http://www.tsuga.fr
raulfg3
Post Mon Nov 26, 2012 11:53 am
The link to version "b" has dissapear, only still live link to version"a":
kairoh
Post Wed Nov 28, 2012 9:51 pm
Yep i screwed up with 1.0.1-b version :oops:
Here is the fix release (1.0.1-c).
==== 1.0.1-c ====
* Added versionning of JS and CSS.
* Fixed version display.
qoolbox
Post Thu Nov 29, 2012 12:36 pm
Hi Kairoh,
thanks for this new version..
but still bugging to my side, i cant click OK button to select a directory (on library media selection)
and adding manually, add nothing :(
i got an error " Error: Cannot read property 'id' of undefined."
also in metadata tab slider are with a [ ? ]
hope you will fix this...
http://www.tsuga.fr
csholmq
Post Thu Nov 29, 2012 1:30 pm
Some feedback on the UI.
  • The design is a bit inconsistent in Safari. Would be better to allow for default buttons to render imho.
  • There's no "saving..." or "loading..." status. Difficult to know if the settings will stick.
  • Lacking descriptions. The original Serviio Console isn't very intuitive. You have the opportunity to evolve the GUI.
Otherwise it seems to work really well! ServiiDB doesn't seem terribly populated though.
Screen Shot 2012-11-29 at 14.23.37.png (19.13 KiB) Viewed 35381 times
Screen Shot 2012-11-29 at 14.23.25.png (15.14 KiB) Viewed 35381 times
kairoh
Post Thu Nov 29, 2012 7:45 pm
qoolbox wrote:i got an error " Error: Cannot read property 'id' of undefined."
I never got this... on any browser and with or without licence...
Have you try to clear your browser cache?
qoolbox
Post Fri Nov 30, 2012 10:38 am
just cleaned the cache, and also tested with IE instead of chrome or Firefox
Same :(
http://www.tsuga.fr
qoolbox
Post Fri Nov 30, 2012 10:45 am
same under Chrome
http://www.tsuga.fr
kairoh
Post Fri Nov 30, 2012 7:38 pm
what is your licence? is it expired?
Post Fri Nov 30, 2012 7:45 pm
I was getting the same error when I reformatted my computer the other day. I do not know if I had applied my license yet or not, but it was a complete reinstall of everything so the trial should have been good. I will check and see if I am still getting it tonight.
