meta data issues
sparx
Post Wed Jul 22, 2015 7:29 am
meta data issues
I have been using swisscenter to date to generate my movie metadata (primarily the genre).
Today I discovered that serviio does not extract all the data?
I have assigned genre that does not show up in the serviio list of movies on my TV. I use more than one genre per movie. And in some cases it shows up in one of them, while the other genre is completely missing.
I have tried the rescan... no change
I also tried making a xbmc.nfo file manually and switch to this source in serviio, but serviio does not delete all the swisscenter stuff and display this one movie movie made manually.
How do I get this to work - like a metadata reset?
sparx
Post Thu Jul 23, 2015 10:24 am
Re: meta data issues
and to add more info.
in the genre category Problem
I have a movie, with attached xml from Swisscenter - but it is detected as an error?
yet another example added
The Girl With A Dragon Tattoo 2011.zip
(388 Bytes) Downloaded 841 times
Crimson Pirate ,The (1952).zip
(463 Bytes) Downloaded 849 times
Return to Panasonic
