Server not found on wired connection
damobeach
Post Fri Jun 19, 2015 1:45 pm
Hi all,
I have a Panasonic GT30, connected to the internet via a Belkin 4-port hub ethernet-wired to a Virgin Super Hub2. I have a wired connection to my PC, running Serviio 1.5.2 off Lubuntu 3.13.0. I've tried numerous settings to try and get the tv to recognise Servio, but only get the 'server not found' message. The TV is recognised in the Serviio console, but with an amber light. I've tried to connect my PC directly to the tv and this works perfectly. Curiously, I've also got an Amazon Fire TV running Kodi, which connects to the Virgin Super Hub wirelessly. Kodi links to Serviio without problem. I suspect that the issue is to do with the IP / DNS settings, but can't figure out what it is. I have chosen the bound address for the console, which is 192.168.0.2 (eth0). I've posted my log file below. Any help would be gratefully received, thanks.
2015-06-19 14:40:43,935 INFO [MediaServer] ------------------------------------------------------------------------
2015-06-19 14:40:43,937 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-06-19 14:40:43,937 INFO [MediaServer] Petr Nejedly 2009-2015
2015-06-19 14:40:43,937 INFO [MediaServer] http://www.serviio.org
2015-06-19 14:40:43,937 INFO [MediaServer] Java 1.8.0_45-Oracle Corporation i386
2015-06-19 14:40:43,937 INFO [MediaServer] OS Linux 3.13.0-55-generic
2015-06-19 14:40:43,937 INFO [MediaServer] File encoding: UTF-8
2015-06-19 14:40:43,938 INFO [MediaServer] Headless mode enabled: true
2015-06-19 14:40:43,938 INFO [MediaServer] User: damo
2015-06-19 14:40:43,938 INFO [MediaServer] User home dir: /home/damo
2015-06-19 14:40:43,938 INFO [MediaServer] Temp dir: /tmp
2015-06-19 14:40:43,938 INFO [MediaServer] ------------------------------------------------------------------------
2015-06-19 14:40:44,295 INFO [WebServer] Socket buffer set to 65535 bytes
2015-06-19 14:40:44,297 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-06-19 14:40:44,467 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-06-19 14:40:44,472 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-06-19 14:40:44,528 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-06-19 14:40:44,555 INFO [DatabaseManager] Using DERBY database language
2015-06-19 14:40:46,593 INFO [MediaServer] ------------------------------------------------------------------------
2015-06-19 14:40:46,593 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-06-19 14:40:46,804 INFO [Device] Created UPnP Device with UUID: c41c5514-0d79-3774-967b-023b9e31d01f, bound address: 192.168.0.2
2015-06-19 14:40:48,199 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-06-19 14:40:48,457 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-06-19 14:40:48,492 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-06-19 14:40:48,499 INFO [ServiioConsole] Initializing Serviio Console
2015-06-19 14:40:48,503 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-06-19 14:40:48,507 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-06-19 14:40:48,513 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-06-19 14:40:48,528 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-06-19 14:40:48,540 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-06-19 14:40:48,542 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-06-19 14:40:48,545 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-06-19 14:40:48,548 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-06-19 14:40:48,558 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-06-19 14:40:48,560 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-06-19 14:40:48,561 INFO [ServiioConsole] Starting Serviio Console
2015-06-19 14:40:48,568 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-06-19 14:40:48,574 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-06-19 14:40:48,583 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-06-19 14:40:48,586 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-06-19 14:40:48,587 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-06-19 14:40:48,587 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-06-19 14:40:48,587 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-06-19 14:40:48,596 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-06-19 14:40:48,596 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-06-19 14:40:48,598 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-06-19 14:40:48,598 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-06-19 14:40:48,599 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-06-19 14:40:48,599 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-06-19 14:40:48,599 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-06-19 14:40:48,600 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-06-19 14:40:48,600 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-06-19 14:40:48,600 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-06-19 14:40:48,602 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-06-19 14:40:48,602 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-06-19 14:40:48,603 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-06-19 14:40:48,603 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-06-19 14:40:48,603 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-06-19 14:40:48,604 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-06-19 14:40:48,604 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-06-19 14:40:48,604 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-06-19 14:40:48,605 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-06-19 14:40:48,606 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-06-19 14:40:48,607 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-06-19 14:40:48,608 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-06-19 14:40:48,609 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-06-19 14:40:48,609 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-06-19 14:40:48,612 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-06-19 14:40:48,612 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-06-19 14:40:48,613 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-06-19 14:40:48,614 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-06-19 14:40:48,616 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-06-19 14:40:48,692 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-06-19 14:40:48,699 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-06-19 14:40:48,700 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-06-19 14:40:48,701 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-06-19 14:40:48,705 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-06-19 14:40:48,706 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-06-19 14:40:48,706 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-06-19 14:40:48,707 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-06-19 14:40:48,707 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-06-19 14:40:48,707 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-06-19 14:40:48,708 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-06-19 14:40:48,830 INFO [PluginCompilerThread] Looking for plugins at /home/damo/serviio-1.5.2/plugins
2015-06-19 14:40:48,836 INFO [PluginCompilerThread] Started looking for plugins
2015-06-19 14:40:48,847 INFO [UpdateChecker] Checking if a new version is available
2015-06-19 14:40:48,933 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "ffmpeg": error=2, No such file or directory
java.io.IOException: Cannot run program "ffmpeg": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:248)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 1 more
2015-06-19 14:40:48,944 ERROR [MediaServer] FFMPEG not found. Serviio will not work properly.
2015-06-19 14:40:48,959 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
... 1 more
2015-06-19 14:40:48,963 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
2015-06-19 14:40:49,018 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-06-19 14:40:49,174 INFO [Device] Updated bound IP address of Device with UUID: c41c5514-0d79-3774-967b-023b9e31d01f, bound address: 192.168.0.2
2015-06-19 14:40:49,181 INFO [WebServer] WebServer starting on port 8895
2015-06-19 14:40:49,243 INFO [EventDispatcher] Starting EventDispatcher
2015-06-19 14:40:49,246 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-06-19 14:40:49,245 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-06-19 14:40:49,253 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.2, timeout = 0
2015-06-19 14:40:49,290 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-06-19 14:40:49,292 INFO [RendererSearchSender] Searching for Renderer devices
2015-06-19 14:40:49,857 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-06-19 14:40:55,918 INFO [Messages] Loaded console message bundle for locale: en
2015-06-19 14:40:58,322 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-06-19 14:41:00,270 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-06-19 14:41:01,522 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2015-06-19 14:41:15,393 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-06-19 14:41:15,399 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
damobeach
Post Thu Jul 09, 2015 10:03 am
Re: Server not found on wired connection
Although there have been numerous views, I've had no replies. Is this because I haven't provided sufficient information? If it's because the topic is covered elsewhere, could someone please point me in the right direction. I've searched the forum and tried various things but without success. Please see my updated log file below.
Cheers
Damian
2015-07-09 10:46:16,982 INFO [ServiioConsole] Initializing Serviio Console
2015-07-09 10:46:16,987 INFO [MediaServer] ------------------------------------------------------------------------
2015-07-09 10:46:17,381 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-07-09 10:46:17,381 INFO [MediaServer] Petr Nejedly 2009-2015
2015-07-09 10:46:17,381 INFO [MediaServer] http://www.serviio.org
2015-07-09 10:46:17,381 INFO [MediaServer] Java 1.8.0_45-Oracle Corporation i386
2015-07-09 10:46:17,381 INFO [MediaServer] OS Linux 3.13.0-55-generic
2015-07-09 10:46:17,382 INFO [MediaServer] File encoding: UTF-8
2015-07-09 10:46:17,382 INFO [MediaServer] Headless mode enabled: true
2015-07-09 10:46:17,382 INFO [MediaServer] User: damo
2015-07-09 10:46:17,382 INFO [MediaServer] User home dir: /home/damo
2015-07-09 10:46:17,382 INFO [MediaServer] Temp dir: /tmp
2015-07-09 10:46:17,382 INFO [MediaServer] ------------------------------------------------------------------------
2015-07-09 10:46:17,404 INFO [ServiioConsole] Starting Serviio Console
2015-07-09 10:46:23,898 INFO [WebServer] Socket buffer set to 65535 bytes
2015-07-09 10:46:23,924 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-07-09 10:46:24,320 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-07-09 10:46:24,322 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-07-09 10:46:24,384 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-07-09 10:46:24,651 INFO [DatabaseManager] Using DERBY database language
2015-07-09 10:46:29,649 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-07-09 10:46:32,853 INFO [MediaServer] ------------------------------------------------------------------------
2015-07-09 10:46:32,854 INFO [MediaServer] License: FREE
2015-07-09 10:46:32,854 INFO [MediaServer] ------------------------------------------------------------------------
2015-07-09 10:46:32,912 INFO [Device] Created UPnP Device with UUID: 2c237e86-a07b-3d8d-b6d9-61a7e4fa993e, bound address: 192.168.0.12
2015-07-09 10:46:33,991 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-07-09 10:46:34,119 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-07-09 10:46:34,138 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-07-09 10:46:34,143 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-07-09 10:46:34,146 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-07-09 10:46:34,149 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-07-09 10:46:34,151 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-07-09 10:46:34,158 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-07-09 10:46:34,160 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-07-09 10:46:34,161 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-07-09 10:46:34,162 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-07-09 10:46:34,167 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-07-09 10:46:34,168 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-07-09 10:46:34,169 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-07-09 10:46:34,176 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-07-09 10:46:34,178 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-07-09 10:46:34,178 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-07-09 10:46:34,178 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-07-09 10:46:34,179 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-07-09 10:46:34,179 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-07-09 10:46:34,183 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-07-09 10:46:34,184 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-07-09 10:46:34,184 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-07-09 10:46:34,184 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-07-09 10:46:34,185 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-07-09 10:46:34,185 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-07-09 10:46:34,185 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-07-09 10:46:34,186 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-07-09 10:46:34,186 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-07-09 10:46:34,187 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-07-09 10:46:34,189 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-07-09 10:46:34,191 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-07-09 10:46:34,191 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-07-09 10:46:34,192 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-07-09 10:46:34,192 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-07-09 10:46:34,192 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-07-09 10:46:34,193 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-07-09 10:46:34,193 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-07-09 10:46:34,193 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-07-09 10:46:34,195 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-07-09 10:46:34,196 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-07-09 10:46:34,197 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-07-09 10:46:34,197 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-07-09 10:46:34,198 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-07-09 10:46:34,199 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-07-09 10:46:34,199 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-07-09 10:46:34,200 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-07-09 10:46:34,201 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-07-09 10:46:34,203 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-07-09 10:46:34,263 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-07-09 10:46:34,265 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-07-09 10:46:34,271 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-07-09 10:46:34,271 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-07-09 10:46:34,271 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-07-09 10:46:34,272 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-07-09 10:46:34,272 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-07-09 10:46:34,273 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-07-09 10:46:34,273 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-07-09 10:46:34,273 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-07-09 10:46:34,274 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-07-09 10:46:34,447 INFO [PluginCompilerThread] Looking for plugins at /home/damo/serviio-1.5.2/plugins
2015-07-09 10:46:34,450 INFO [PluginCompilerThread] Started looking for plugins
2015-07-09 10:46:34,463 INFO [UpdateChecker] Checking if a new version is available
2015-07-09 10:46:34,510 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "ffmpeg": error=2, No such file or directory
... 1 more
2015-07-09 10:46:34,514 ERROR [MediaServer] FFMPEG not found. Serviio will not work properly.
2015-07-09 10:46:34,519 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
... 1 more
2015-07-09 10:46:34,521 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
2015-07-09 10:46:34,565 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-07-09 10:46:34,662 INFO [Device] Updated bound IP address of Device with UUID: 2c237e86-a07b-3d8d-b6d9-61a7e4fa993e, bound address: 192.168.0.12
2015-07-09 10:46:34,665 INFO [WebServer] WebServer starting on port 8895
2015-07-09 10:46:34,711 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-07-09 10:46:34,711 INFO [EventDispatcher] Starting EventDispatcher
2015-07-09 10:46:34,721 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-07-09 10:46:34,792 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.12, timeout = 0
2015-07-09 10:46:34,808 INFO [RendererSearchSender] Searching for Renderer devices
2015-07-09 10:46:34,815 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-07-09 10:46:41,232 INFO [Messages] Loaded console message bundle for locale: en
2015-07-09 10:46:44,910 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-07-09 10:46:46,065 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-07-09 10:46:47,396 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2015-07-09 10:47:01,029 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-07-09 10:47:01,034 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
Post Thu Jul 09, 2015 12:29 pm
Your Serviio computer changes IP addresses between your two posts. The first was 192.168.0.2, and the second was 192.168.0.12. How are IP addresses assigned on your network? Is the Virgin hub a router doing the assignment? Or have you assigned static IPs?
Check your IP addresses carefully, including subnet mask and gateway addresses. Every device should be identical except for the IP address itself, and those have to be in the same subnet, i.e. for your network every IP address should start with 192.168.0.
The fact it worked with a direct connection makes me suspicious of the cable itself. I have found in the past that a cable could be wired incorrectly, but some things work through it. So it appears to be working but in reality it doesn't. Try a different cable from the TV to the Belkin switch, just to see what happens.
Finally, I've completely lost faith in Belkin computer network products. I've had routers and Wireless Access Points that just don't work right. A simple switch should be OK, but I simply don't trust them anymore. I have an almost new Belkin router that flat out would not provide DNS service to the network. And that's a vital role for a router. I've switched it to only be a access point, but I'll never buy Belkin again.
damobeach
Post Wed Jul 22, 2015 1:18 pm
[Resolved] Re: Server not found on wired connection
Hi, thanks for the reply. Apologies I've taken so long to get back. When I've checked through my network, it was because I'd connected the TV through a router incorrectly. I'd effectively created two different wired networks. I've now daisy-chained the router so everything is on the same network and my tv can see the server :)
Regards
Damian
Post Wed Jul 22, 2015 11:25 pm
Re: [Resolved] Re: Server not found on wired connection
damobeach wrote:Hi, thanks for the reply. Apologies I've taken so long to get back. When I've checked through my network, it was because I'd connected the TV through a router incorrectly. I'd effectively created two different wired networks. I've now daisy-chained the router so everything is on the same network and my tv can see the server :)
Regards
Damian
Yeah, that can happen. Glad you found it! :D
Return to Panasonic
