Transcoding too 4:3, but only when hard coding subtitles
bsod
Post Wed Aug 13, 2014 6:30 pm
I am trying to play back an AVI file which is being transcoded to mpeg2 as my ST60 doesn't support .avi.
I want to play it with subtitles.
Placing a .srt file next to the .avi file with the exact same name and there are no subtitles, aspect ratio is 16:9.
Set in the console "Enabled Burned-in subtitles" - Only when needed = No subtitles, aspect ratio is 16:9.
Set in the console "Enabled Burned-in subtitles" - Always = Subtitles appear. BUT for some reason the aspect ratio is squashed to 4:3.
I have tested on two devices with he 2013 profile. My phone set up with this profile shows the same results.
I tried to get a log, but it isn't logging anything after I test playing the file. Here's the last log entry. (Could this error be because I tried the Panny profile on my phone)? - I since played the file on the television and there has been no log entry since.- and before you ask. Yes I have debugging set.
2014-08-13 19:20:56,531 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 400 error
org.serviio.upnp.protocol.http.transport.InvalidResourceRequestException: Invalid incoming request: /resource/3200/MEDIA_ITEM/MPEG_PS_PAL-0
   at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:69)
   at org.serviio.upnp.protocol.http.transport.AbstractProtocolHandler.getRequestedResourceDescription(AbstractProtocolHandler.java:36)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:65)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:196)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 3
   at org.serviio.upnp.protocol.http.transport.RequestedResourceDescriptor.<init>(RequestedResourceDescriptor.java:66)
   ... 8 more
Here is my mediainfo for the file.
Complete name                            : E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 349 MiB
Duration                                 : 46mn 8s
Overall bit rate                         : 1 059 Kbps
Writing application                      : transcode-1.0.7
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 2
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Muxing mode                              : Packed bitstream
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 46mn 8s
Bit rate                                 : 919 Kbps
Width                                    : 624 pixels
Height                                   : 352 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.167
Stream size                              : 303 MiB (87%)
Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 46mn 8s
Bit rate                                 : 32.0 Kbps
Stream size                              : 41.9 MiB (12%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.60 video frame)
Writing library                          : LAME3.98.2ULAME3.98.
#Edit. I restarted the computer and now get this log:
2014-08-13 19:39:54,928 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:22602: POST /serviceControl HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.67:8895,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",X-PANASONIC-Registration: VklFUkEgU1Q2MCBTZXJpZXMAAAAAAAAAAAA=,X-PANASONIC-DMP-Profile: MPEG_PS_PAL JPEG_SM PV_DIVX_DIV3 PV_DIVX_DIV4 PV_DIVX_DIVX PV_DIVX_DX50 PV_DRM_DIVX_DIV3 PV_DRM_DIVX_DIV4 PV_DRM_DIVX_DIVX PV_DRM_DIVX_DX50,Content-Length: 807]]
2014-08-13 19:39:54,929 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:39:54,929 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.70
2014-08-13 19:39:54,932 DEBUG [ContentDirectory] Browse() called for renderer Panasonic VIErA (profile viera2013) with parameters: objectID = V_F^FOL_R3$F1394$F1406$F1482, browseFlag = BrowseDirectChildren, filter = dc:title,dc:date,res,res@protocolInfo,res@size,res@duration,res@resolution,res@dlna:ifoFileURI,res@pv:subtitleFileType,res@pv:subtitleFileUri,upnp:albumArtURI,upnp:album,upnp:artist,res@pxn:ResumePoint,res@pxn:ChapterList,item@pxn:ContentSourceType,item@pxn:LiveView,item@pxn:LiveViewUpdateID, startIndex = 0, count = 20, sortCriteria =
2014-08-13 19:39:54,932 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 1482 [Any]
2014-08-13 19:39:54,936 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1482 (from=0, count=20) [Any]
2014-08-13 19:39:54,947 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:54,951 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:54,951 DEBUG [GenreDAOImpl] Reading a Genre (id = 10)
2014-08-13 19:39:54,954 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:39:54,955 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3200 and profile Panasonic Viera (2013)
2014-08-13 19:39:54,956 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:54,957 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:54,957 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:54,958 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:39:54,958 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:39:54,958 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3334)
2014-08-13 19:39:54,959 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:54,959 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:54,959 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 1482 (filter: ALL) [Any]
2014-08-13 19:39:54,960 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2014-08-13 19:39:54,965 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-08-13 19:39:55,287 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:25040: GET /resource/3200/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.67:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2014-08-13 19:39:55,287 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:39:55,288 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:55,288 DEBUG [ResourceDeliveryProcessor] Request for resource 3200 and type 'MEDIA_ITEM' received
2014-08-13 19:39:55,288 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:39:55,288 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:39:55,294 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:39:55,294 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3200, format MPEG_PS_PAL and profile Panasonic Viera (2013)
2014-08-13 19:39:55,294 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:55,294 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:55,295 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi
2014-08-13 19:39:55,295 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:55,295 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:55,295 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:39:55,295 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:39:55,295 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:39:55,296 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:39:55,296 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:39:55,296 DEBUG [VideoDeliveryEngine] Delivering item '3200' for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:55,296 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:55,296 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:55,297 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:55,297 DEBUG [VideoDeliveryEngine] Delivering file 'doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi' using transcoding
2014-08-13 19:39:55,297 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:55,298 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:55,298 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:55,299 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi
2014-08-13 19:39:55,299 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 4 -i E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi -y -threads 4 -c:v mpeg2video -pix_fmt yuv420p -qscale:v 1 -vf pad=626:352:1:0:black,setdar=4:3,subtitles=filename="E\\:/TV/Doc Martin/Doc Martin Season 4/doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt":original_size=624x352:charenc=UTF-8 -r 25 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f vob C:\Windows\TEMP\Serviio\transcoding-temp-3200-viera2013-ORIGINAL-6dd1ea294fccfc89626a7bb52d9b051e.stf
2014-08-13 19:39:55,309 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:43824: GET /resource/3334/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.67:8895,transferMode.dlna.org: Interactive]]
2014-08-13 19:39:55,309 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:39:55,309 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:55,310 DEBUG [ResourceDeliveryProcessor] Request for resource 3334 and type 'COVER_IMAGE' received
2014-08-13 19:39:55,310 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3334)
2014-08-13 19:39:55,310 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3334
2014-08-13 19:39:55,310 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (HD) with id 3334
2014-08-13 19:39:55,310 DEBUG [GETMethodProcessor] Stream entity has length: 7247
2014-08-13 19:39:55,310 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 7247,Date: Wed, 13 Aug 2014 18:39:55 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-13 19:39:56,301 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-08-13 19:39:56,302 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:56,303 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:56,303 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:39:56,303 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:39:56,303 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3200) as read
2014-08-13 19:39:56,315 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-13 19:39:56,315 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-08-13 19:39:56,315 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-08-13 19:39:56,315 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 13 Aug 2014 18:39:56 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-2768/2768,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-13 19:39:56,379 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-08-13 19:39:56,556 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:38215: GET /resource/3200/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.67:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2014-08-13 19:39:56,556 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:39:56,556 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:56,556 DEBUG [ResourceDeliveryProcessor] Request for resource 3200 and type 'MEDIA_ITEM' received
2014-08-13 19:39:56,556 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:39:56,556 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:39:56,557 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:39:56,558 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3200, format MPEG_PS_PAL and profile Panasonic Viera (2013)
2014-08-13 19:39:56,558 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:56,558 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:56,559 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:56,559 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi
2014-08-13 19:39:56,559 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:56,560 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:39:56,560 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:39:56,560 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:39:56,560 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:39:56,560 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:39:56,560 DEBUG [VideoDeliveryEngine] Delivering item '3200' for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:56,560 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:56,561 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:56,561 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:56,561 DEBUG [VideoDeliveryEngine] Delivering file 'doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi' using transcoding
2014-08-13 19:39:56,562 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:39:56,565 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-08-13 19:39:56,567 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:39:56,567 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:39:56,567 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:39:56,567 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:39:56,567 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3200) as read
2014-08-13 19:39:56,568 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-13 19:39:56,568 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-08-13 19:39:56,568 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-08-13 19:39:56,568 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 13 Aug 2014 18:39:56 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-2768/2768,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-13 19:40:03,582 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-08-13 19:40:05,131 DEBUG [SearchManager] Committing search index
2014-08-13 19:40:06,086 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:13572: GET /resource/3200/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.67:8895,TimeSeekRange.dlna.org: npt=00:05:42.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2014-08-13 19:40:06,086 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:40:06,087 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:40:06,087 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:06,087 DEBUG [ResourceDeliveryProcessor] Request for resource 3200 and type 'MEDIA_ITEM' received
2014-08-13 19:40:06,087 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:40:06,087 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:40:06,087 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:40:06,088 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3200, format MPEG_PS_PAL and profile Panasonic Viera (2013)
2014-08-13 19:40:06,088 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:06,088 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:06,088 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi
2014-08-13 19:40:06,089 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:06,089 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:40:06,089 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:40:06,089 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:40:06,089 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:40:06,089 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:40:06,089 DEBUG [VideoDeliveryEngine] Delivering item '3200' for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:06,089 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:06,090 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:06,090 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:06,090 DEBUG [VideoDeliveryEngine] Delivering file 'doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi' using transcoding
2014-08-13 19:40:06,091 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:06,092 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-08-13 19:40:06,092 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:06,093 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:06,093 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:40:06,093 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:40:06,093 DEBUG [GETMethodProcessor] Delivering bytes 32980604 - 50000000000 from transcoded file, based on time range 342.0 - 2768.0
2014-08-13 19:40:06,093 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-08-13 19:40:06,093 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-08-13 19:40:06,093 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Wed, 13 Aug 2014 18:40:06 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=342-2768/2768,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-13 19:40:17,168 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-08-13 19:40:17,168 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-08-13 19:40:19,380 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2014-08-13 19:40:28,841 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:35485: GET /resource/3200/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.67:8895,TimeSeekRange.dlna.org: npt=00:00:00.000-,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2014-08-13 19:40:28,841 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:40:28,842 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:40:28,842 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:28,842 DEBUG [ResourceDeliveryProcessor] Request for resource 3200 and type 'MEDIA_ITEM' received
2014-08-13 19:40:28,842 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:40:28,842 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:40:28,842 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:40:28,843 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3200, format MPEG_PS_PAL and profile Panasonic Viera (2013)
2014-08-13 19:40:28,843 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:28,843 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:28,844 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:28,844 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi
2014-08-13 19:40:28,844 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:28,844 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:40:28,844 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:40:28,844 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3200 (local)
2014-08-13 19:40:28,845 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3200)
2014-08-13 19:40:28,845 DEBUG [VideoDAOImpl] Reading a Video (id = 3200)
2014-08-13 19:40:28,845 DEBUG [VideoDeliveryEngine] Delivering item '3200' for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:28,845 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:28,846 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:28,846 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:28,846 DEBUG [VideoDeliveryEngine] Delivering file 'doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi' using transcoding
2014-08-13 19:40:28,847 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:28,847 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:28,849 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-08-13 19:40:28,849 DEBUG [MediaItemDAOImpl] Getting file of media item 3200
2014-08-13 19:40:28,849 DEBUG [SubtitlesService] Found external subtitle file: E:\TV\Doc Martin\Doc Martin Season 4\doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.srt
2014-08-13 19:40:28,850 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_PAL
2014-08-13 19:40:28,850 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file doc_martin.4x02.uneasy_lies_the_head.hdtv_xvid-fov.avi: MPEG_PS_NTSC
2014-08-13 19:40:28,850 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3200) as read
2014-08-13 19:40:28,850 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-13 19:40:28,850 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-08-13 19:40:28,850 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-08-13 19:40:28,850 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 13 Aug 2014 18:40:28 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-2768/2768,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-13 19:40:28,922 DEBUG [ServiioHttpService] Incoming request from /192.168.1.70:61357: GET /resource/3334/COVER_IMAGE HTTP/1.1, headers = [User-Agent: Panasonic MIL DLNA CP UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.67:8895,transferMode.dlna.org: Interactive]]
2014-08-13 19:40:28,922 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.70
2014-08-13 19:40:28,923 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.70, Profile=Panasonic Viera (2013)'
2014-08-13 19:40:28,923 DEBUG [ResourceDeliveryProcessor] Request for resource 3334 and type 'COVER_IMAGE' received
2014-08-13 19:40:28,923 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3334)
2014-08-13 19:40:28,923 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3334
2014-08-13 19:40:28,923 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (HD) with id 3334
2014-08-13 19:40:28,923 DEBUG [GETMethodProcessor] Stream entity has length: 7247
2014-08-13 19:40:28,924 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 7247,Date: Wed, 13 Aug 2014 18:40:28 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-13 19:40:35,131 DEBUG [SearchManager] Committing search index
Post Thu Aug 14, 2014 11:58 am
Re: Transcoding too 4:3, but only when hard coding subtitles
When you view the file with subtitles, does it appear with side bars (squashed in from the side). If so, try pressing the Aspect button on your remote to expand the view to fill the screen (set to something like "4:3 Full" mode). Your TV should remember this setting after doing it this once. See here for some more info: viewtopic.php?f=13&t=17263#p93070.
<Edit> Also, I had some reports of ST60 that supported AVI's containing XVid - seems to be country related - you can test if this is the case by using the Panasonic 2012 profile. If the file plays, then XVid is supported natively (which is always better than transcoding, and if its like my TV, will also likely support srt subtitles natively). Try it and let me know - if it works I'll guide you how to change the 2013 profile to accomodate.
bsod
Post Thu Aug 14, 2014 1:45 pm
DenyAll wrote:When you view the file with subtitles, does it appear with side bars (squashed in from the side). If so, try pressing the Aspect button on your remote to expand the view to fill the screen (set to something like "4:3 Full" mode). Your TV should remember this setting after doing it this once. See here for some more info: viewtopic.php?f=13&t=17263#p93070.
You sir, are a legend. Thankyou
Yes on both counts. I didn't think it was a problem with the television interpreting the signal incorrectly, but you are right, changing the aspect works. My ST60 has the options Aspect 1 (4:3), Aspect 2 (16:9) and Original (non up-scaled image). By default it doesn't change to 16:9, I guess like the linked post explains, because the T.V isn't detecting the transcoding mpeg2 stream correctly. I wonder if there is an answer for this, a FFMPEG command or something.... for when transcoding is needed. Perhaps its due to the unusual resolution of the ripped videos, perhaps if the resolution was at a T.V standard it would detect fine with mpeg2?
Also, it appears my ST60 does support the files I'm trying to play. The codec in the mediainfo says XvID, but my ST60 reports the file type as DiVX. It plays flawlessly without transcoding and with subtitles too. Sadly though, the subtitles are so small and difficult to read.
Is there a way to change the size of the subtitles? Or is this a Panasonic problem?
bsod
Post Sat Aug 16, 2014 4:36 pm
Well it seems from searching that there is no way to increase the subtitle size. Bizarrely with MKV format the subtitles are bigger when you contain them within the .mkv file itself, or even use an external SRT file when there is already one integrated.
So Panasonic have really tiny subtitles, but only when seperate .srt files are used alone, which are uncontrollable in size. What a shame.
Return to Panasonic
