[SOLVED] no subtitle, lg ld840
xpto09
Post Wed Sep 21, 2011 9:21 pm
I have already tested everything here and another DLNAs.
It is impossible to see subtitles.
However, Nero MediaHome and Mezzmo that are in windows works.
All servers works in linux streaming video, but subtitles no.
Is there a solution to this?
Post Wed Sep 21, 2011 10:36 pm
Re: no subtitle, lg ld840
did you select the LG profile?
xpto09
Post Thu Sep 22, 2011 12:31 am
"did you select the LG profile?"
Yes, I did.
The first time is:
192.168.0.12 Unrecognized device Generic DLNA profile
I changed do LG BD player (Unrecognized device again).
I put this too
http://forum.serviio.org/viewtopic.php?f=12&t=1711&start=30
Post Thu Sep 22, 2011 9:03 am
post detailed log of when you play the file
xpto09
Post Thu Sep 22, 2011 9:40 pm
I have downloaded the new version.
Now I can read in Device Name: LG TV/player and in Profile LG TV /player.
However, no subtitles.
Follow the log file:
    2011-09-22 18:28:22,050 INFO [MediaServer] ------------------------------------------------------------------------
    2011-09-22 18:28:22,059 INFO [MediaServer] Serviio DLNA media streaming server v 0.6 (rev. a369baa35bfe)
    2011-09-22 18:28:22,059 INFO [MediaServer] Petr Nejedly 2009-2011
    2011-09-22 18:28:22,059 INFO [MediaServer] http://www.serviio.org
    2011-09-22 18:28:22,059 INFO [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
    2011-09-22 18:28:22,059 INFO [MediaServer] OS Linux i386 2.6.38-11-generic
    2011-09-22 18:28:22,060 INFO [MediaServer] File encoding: UTF-8
    2011-09-22 18:28:22,060 INFO [MediaServer] Headless mode enabled: true
    2011-09-22 18:28:22,060 INFO [MediaServer] ------------------------------------------------------------------------
    2011-09-22 18:28:22,304 INFO [RestletServer] Starting Restlet server exposed on port 23423
    2011-09-22 18:28:22,417 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
    2011-09-22 18:28:28,461 INFO [ServiioConsole] Starting Serviio Console
    2011-09-22 18:28:31,860 INFO [DBSchemaUpdateExecutor] Updating DB schema
    2011-09-22 18:28:39,240 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
    2011-09-22 18:28:42,748 INFO [Messages] Loaded console message bundle for locale: en
    2011-09-22 18:28:47,562 INFO [ProfilesDefinitionParser] Parsing Profiles definition
    2011-09-22 18:28:48,101 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
    2011-09-22 18:28:48,301 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
    2011-09-22 18:28:48,424 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
    2011-09-22 18:28:48,530 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
    2011-09-22 18:28:48,633 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
    2011-09-22 18:28:48,748 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
    2011-09-22 18:28:48,962 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
    2011-09-22 18:28:48,994 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
    2011-09-22 18:28:49,288 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
    2011-09-22 18:28:49,816 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
    2011-09-22 18:28:50,021 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
    2011-09-22 18:28:50,212 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
    2011-09-22 18:28:50,266 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
    2011-09-22 18:28:50,295 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
    2011-09-22 18:28:50,387 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
    2011-09-22 18:28:50,432 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
    2011-09-22 18:28:50,532 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
    2011-09-22 18:28:50,901 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
    2011-09-22 18:28:51,219 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
    2011-09-22 18:28:51,242 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
    2011-09-22 18:28:51,249 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
    2011-09-22 18:28:51,252 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
    2011-09-22 18:28:51,253 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
    2011-09-22 18:28:51,254 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
    2011-09-22 18:28:51,254 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
    2011-09-22 18:28:51,255 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316726931255, LastAccessTime = 1316726931255, getTimeToLiveSeconds() = -1, createTime = 1316726931255 ]
    2011-09-22 18:28:51,286 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
    2011-09-22 18:28:51,286 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
    2011-09-22 18:28:51,286 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
    2011-09-22 18:28:51,286 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
    2011-09-22 18:28:51,287 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
    2011-09-22 18:28:51,287 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
    2011-09-22 18:28:51,287 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
    2011-09-22 18:28:51,287 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
    2011-09-22 18:28:51,287 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
    2011-09-22 18:28:51,287 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
    2011-09-22 18:28:51,287 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
    2011-09-22 18:28:51,287 INFO [CompositeCacheConfigurator] Finished configuration in 36 ms.
    2011-09-22 18:28:51,344 INFO [WebServer] Socket buffer set to 65535 bytes
    2011-09-22 18:28:51,344 INFO [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
    2011-09-22 18:28:51,368 INFO [PluginCompilerThread] Looking for plugins at /home/mrc/pms/serviio-0.6/plugins
    2011-09-22 18:28:51,368 INFO [PluginCompilerThread] Started looking for plugins
    2011-09-22 18:28:51,783 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
    2011-09-22 18:28:51,837 INFO [WebServer] WebServer starting on port 8895
    2011-09-22 18:28:51,844 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.10, timeout = 0
    2011-09-22 18:28:51,845 INFO [EventDispatcher] Starting EventDispatcher
    2011-09-22 18:28:51,853 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
    2011-09-22 18:28:51,854 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
    2011-09-22 18:28:51,855 INFO [RendererSearchSender] Searching for Renderer devices
    2011-09-22 18:28:51,857 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
    2011-09-22 18:28:52,606 INFO [RendererManager] Stored a new renderer: uuid='bf8f267c-421c-43d6-ab09-5e881c097f83', name = 'LG TV / player', ipAddress='192.168.0.12', profile = '8'
    2011-09-22 18:28:59,604 INFO [Messages] Loaded console message bundle for locale: en
    2011-09-22 18:28:59,728 INFO [UpdateChecker] Checking if a new version is available
    2011-09-22 18:29:07,137 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
    2011-09-22 18:29:07,738 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
    2011-09-22 18:29:17,896 INFO [FeedUpdaterThread] Started looking for information about online feeds
    2011-09-22 18:29:17,901 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
    2011-09-22 18:29:17,902 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
    2011-09-22 18:29:59,007 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
    2011-09-22 18:29:59,107 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
    2011-09-22 18:29:59,222 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
    2011-09-22 18:29:59,228 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
    2011-09-22 18:30:02,676 INFO [LibraryAdditionsCheckerThread] Added file 'inside_job.avi' (title: Inside Job) to Library
    2011-09-22 18:30:53,896 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
    org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for single item: For input string: "73/Inside Job"
    at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItem(AbstractCommand.java:136)
    at org.serviio.upnp.service.contentdirectory.definition.ActionNode.executeRetrieveItemAction(ActionNode.java:175)
    at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveDirectoryObject(ActionNode.java:80)
    at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:199)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at java.lang.reflect.Method.invoke(Method.java:616)
    at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
    at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
    at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:74)
    Caused by: java.lang.NumberFormatException: For input string: "73/Inside Job"
    at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
    at java.lang.Integer.parseInt(Integer.java:481)
    at java.lang.Integer.parseInt(Integer.java:514)
    at org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand.getInitialFromId(ListVideosForInitialCommand.java:58)
    at org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand.retrieveItemCount(ListVideosForInitialCommand.java:49)
    at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeCountAction(ContainerNode.java:214)
    at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItemsCount(ContainerNode.java:114)
    at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItemsCount(ActionNode.java:155)
    at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.instantiateValuesForContainer(ObjectValuesBuilder.java:127)
    at org.serviio.upnp.service.contentdirectory.command.AbstractListInitialsCommand.retrieveSingleItem(AbstractListInitialsCommand.java:71)
    at org.serviio.upnp.service.contentdirectory.command.AbstractListInitialsCommand.retrieveSingleItem(AbstractListInitialsCommand.java:29)
    at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItem(AbstractCommand.java:131)
    ... 15 more
    2011-09-22 18:30:53,921 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
    ... 15 more
Post Thu Sep 22, 2011 10:56 pm
I'll need the detailed log
xpto09
Post Fri Sep 23, 2011 12:20 am
I got to increase the log stopping and running again the movie.
Is it correct?
2011-09-22 21:02:52,789 INFO  [MediaServer] ------------------------------------------------------------------------
2011-09-22 21:02:52,825 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6 (rev. a369baa35bfe)
2011-09-22 21:02:52,825 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-09-22 21:02:52,825 INFO  [MediaServer] http://www.serviio.org
2011-09-22 21:02:52,825 INFO  [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2011-09-22 21:02:52,826 INFO  [MediaServer] OS Linux i386 2.6.38-11-generic
2011-09-22 21:02:52,826 INFO  [MediaServer] File encoding: UTF-8
2011-09-22 21:02:52,839 INFO  [MediaServer] Headless mode enabled: true
2011-09-22 21:02:52,839 INFO  [MediaServer] ------------------------------------------------------------------------
2011-09-22 21:02:53,469 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-09-22 21:02:53,686 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-22 21:02:56,265 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-22 21:02:56,800 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-22 21:02:57,016 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-22 21:02:57,130 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-22 21:02:57,263 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-22 21:02:57,359 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-22 21:02:57,464 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-22 21:02:57,657 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-22 21:02:57,690 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-09-22 21:02:57,959 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-22 21:02:58,476 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-22 21:02:58,636 INFO  [ServiioConsole] Starting Serviio Console
2011-09-22 21:02:58,654 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-22 21:02:58,813 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-09-22 21:02:58,862 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-09-22 21:02:58,887 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-09-22 21:02:58,965 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-09-22 21:02:59,015 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-09-22 21:02:59,133 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-09-22 21:02:59,458 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-09-22 21:02:59,736 INFO  [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-09-22 21:02:59,805 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-22 21:02:59,839 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-09-22 21:02:59,843 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-22 21:02:59,843 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-09-22 21:02:59,844 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,844 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-09-22 21:02:59,845 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316736179844, LastAccessTime = 1316736179844, getTimeToLiveSeconds() = -1, createTime = 1316736179844 ]
2011-09-22 21:02:59,887 INFO  [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-09-22 21:02:59,887 INFO  [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,887 INFO  [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-09-22 21:02:59,887 INFO  [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,887 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-09-22 21:02:59,887 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-22 21:02:59,887 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,888 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-09-22 21:02:59,888 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-22 21:02:59,888 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,888 INFO  [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-09-22 21:02:59,888 INFO  [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-09-22 21:03:00,026 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-09-22 21:03:00,026 INFO  [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
2011-09-22 21:03:00,272 INFO  [PluginCompilerThread] Looking for plugins at /home/marcos/pms/serviio-0.6/plugins
2011-09-22 21:03:00,272 INFO  [PluginCompilerThread] Started looking for plugins
2011-09-22 21:03:02,060 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-22 21:03:02,162 INFO  [WebServer] WebServer starting on port 8895
2011-09-22 21:03:02,169 INFO  [EventDispatcher] Starting EventDispatcher
2011-09-22 21:03:02,170 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-22 21:03:02,170 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-22 21:03:02,319 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.10, timeout = 0
2011-09-22 21:03:02,321 INFO  [RendererSearchSender] Searching for Renderer devices
2011-09-22 21:03:02,322 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-22 21:03:02,910 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-22 21:03:04,421 INFO  [Messages] Loaded console message bundle for locale: en
2011-09-22 21:03:09,286 INFO  [Messages] Loaded console message bundle for locale: en
2011-09-22 21:03:09,402 INFO  [UpdateChecker] Checking if a new version is available
2011-09-22 21:03:17,543 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-09-22 21:03:18,114 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-09-22 21:03:28,361 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2011-09-22 21:03:28,362 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-09-22 21:03:28,369 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-09-22 21:04:29,979 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
   ... 15 more
2011-09-22 21:04:30,005 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
   ... 15 more
2011-09-22 21:15:01,680 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
   at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
   ... 14 more
2011-09-22 21:15:01,716 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
   ... 14 more
2011-09-22 21:17:22,937 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
   ... 14 more
2011-09-22 21:17:22,955 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
   ... 14 more
xpto09
Post Fri Sep 23, 2011 2:04 am
I changed from "INFO" to "DEBUG".
Follow the log.
log file
(121.55 KiB) Downloaded 1113 times
Post Fri Sep 23, 2011 10:43 am
Weird, the TV does not ask for the subtitle file. You could capture packets of Mezzmo in Wireshark when you browse to the file and start playing in
xpto09
Post Fri Sep 23, 2011 10:28 pm
How can I post here the wireshark file because it is more than 2Mb?
It was the first time that I capture a file.
Post Fri Sep 23, 2011 10:35 pm
upload it to http://www.mediafire.com/ and post the link here
xpto09
Post Fri Sep 23, 2011 11:00 pm
Post Sat Sep 24, 2011 6:50 pm
I'm looking at the file (thanks) and it should work the same way in Serviio. Did you try with this Green zone file as well?
xpto09
Post Sat Sep 24, 2011 7:27 pm
Yes, I did.
What I can' t understand is the reason that all dlna servers to linux don't show the subtitles.
The dlna servers to windows, Nero and Mezzmo, works.
xpto09
Post Sun Sep 25, 2011 10:25 pm
Today I downloaded a movie with extension .mkv (burnt by the sun).
Only to test it, I played it and "I COULD SEE SUBTITLES"!
Then I changed green_zone.avi to green_zone.mkv and inside_job.avi to inside_job.mkv.
I could see subtitles.
Now, I wiill test all my movies to make sure that this procedure will always work.
Post Sun Sep 25, 2011 10:33 pm
xpto09 wrote:Today I downloaded a movie with extension .mkv (burnt by the sun).
ahh i found this alot for some reason the maker of the file renames the extension to AVI even though the files are actualy MKV or MP4 you can detect this in window by either looking to find file were thumbnails dont work or by hovering the mouse over the files and check what video profile it says.
Post Sun Sep 25, 2011 11:16 pm
that's weird as Serviio doesn't care about extensions and doesn't add them to the URL resources either.
can you post ffmpeg -i of the avi file?
It might be that the file itself is not correctly identified in the profile and then the player doesn't ask for the subtile file
xpto09
Post Sun Sep 25, 2011 11:40 pm
mrcs@natty-P35-DS3:~/Downloads/midia/filmes/Green Zone$ ffmpeg -i GreenZone.avi
FFmpeg version 0.6.2-4:0.6.2-1ubuntu1.1, Copyright (c) 2000-2010 the Libav developers
  built on Sep 16 2011 16:57:46 with gcc 4.5.2
  configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  WARNING: library configuration mismatch
  libavutil   configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavcodec  configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavformat configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libswscale  configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[mpeg4 @ 0x8d49e20]Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65534/2733) -> 23.98 (2997/125)
Input #0, avi, from 'GreenZone.avi':
    ISFT            : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 01:54:46.46, start: 0.000000, bitrate: 852 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 648x256 [PAR 1:1 DAR 81:32], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 112 kb/s
Post Mon Sep 26, 2011 9:21 am
Ok, thanks.
Can you add this line to your LG profile, restart Serviio and try to play the avi?
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
xpto09
Post Tue Sep 27, 2011 12:53 am
Until now, all movies works.
But suddenly, nothing works.
I will make more tests.
Now I understood the reason.
If I click on green_zone inside the Folder Movies, the name is green_zone.avi
If i click on green_Zone inside the Folter Titles, the name is green_zone (without .avi).
So, only when the name of the movie has the extension .avi is possible to see subtitles.
<Profile id="8" name="LG TV / player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
         </HttpHeaders>
      </Detection>
         <Video targetContainer="mpegts" targetACodec="mp3">
            <Matches container="matroska" aCodec="ac3" />
Congratulations, Petr!
"During a lunch at the Group of 20 summit in London, Obama shook hands with President Luiz Inacio Lula da Silva and said: "This is my man, right here. I love this guy."
In Brazil we say: "Esse é o cara!".
I was worried about using Nero or Mezzmo in virtualbox.
This is the first linux dlna server that works in my TV LG LD840!
(sorry, I deleted this post when I was editing it. I noted now. I put again the message above).
Return to LG
Users browsing this forum: Baidu [Spider] and 1 guest
