LG BX580 seek problem
load.runner
Post Thu Jun 23, 2011 10:48 pm
I am a new user of serviio and I love it, but I have a problem.
For some of my mkv's, the seeking doesn't work on my LG BX580.
The weird part is that, if I play the files on LG player through samba, I can seek without problems (on the same files),
and if I play the files on my laptop (with Totem with Coherence DLNA Client) also, the seeking works.
This is without transcoding.
Is there anything I can do?
Post Fri Jun 24, 2011 7:15 am
Re: LG BX580 seek problem
load.runner wrote:This is without transcoding.
Could you confirm that on Serviio and on Totem this mkv are not transcoded but delivered in native format?
For serviio you could enable detailed logging (see signature) and check if this file is delivered in native format.For totem I don't know.
You could also provide information about this mkv file (see signature links too).
load.runner
Post Fri Jun 24, 2011 11:08 am
this is a request from totem
2011-06-24 13:53:01,320 DEBUG [WebServer] I/O error: Connection reset
2011-06-24 13:53:01,322 DEBUG [WebServer] Incoming connection from /192.168.0.111:37041
2011-06-24 13:53:01,322 DEBUG [ResourceTransportRequestHandler] GET /resource/11101/MEDIA_ITEM/MATROSKA$0 HTTP/1.1, headers = [Host: 192.168.0.1:8895,Connection: close,icy-metadata: 1,transferMode.dlna.org: Streaming,Range: bytes=709152238-]]
2011-06-24 13:53:01,322 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.111
2011-06-24 13:53:01,322 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.111, Profile=Generic DLNA profile'
2011-06-24 13:53:01,322 DEBUG [ResourceTransportRequestHandler] Request for resource 11101 and type 'MEDIA_ITEM' received
2011-06-24 13:53:01,322 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 11101)
2011-06-24 13:53:01,323 DEBUG [VideoDAOImpl] Reading a Video (id = 11101)
2011-06-24 13:53:01,323 DEBUG [VideoDeliveryEngine] Delivering item '11101' for client 'IPAddress=/192.168.0.111, Profile=Generic DLNA profile'
2011-06-24 13:53:01,323 DEBUG [VideoDeliveryEngine] Delivering file 'Community S02E01 Anthropology 101 720p WEB-DL DD5.1 H.264 - HoodBag.mkv' in native format
2011-06-24 13:53:01,323 DEBUG [MediaItemDAOImpl] Getting file of media item 11101
2011-06-24 13:53:01,324 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9997
2011-06-24 13:53:01,324 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-06-24 13:53:01,324 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Range: bytes 709152238-709162234/709162235,Content-Length: 9997,Date: Fri, 24 Jun 2011 10:53:01 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
this is a request from LG player
2011-06-24 13:56:27,862 DEBUG [ResourceTransportRequestHandler] GET /resource/11101/MEDIA_ITEM/MATROSKA$0 HTTP/1.1, headers = [Range: bytes=19310720-21310719,Host: 192.168.0.1:8895,Accept: */*,transferMode.dlna.org: Streaming]]
2011-06-24 13:56:27,863 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.117
2011-06-24 13:56:27,863 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.117, Profile=Generic DLNA profile'
2011-06-24 13:56:27,863 DEBUG [ResourceTransportRequestHandler] Request for resource 11101 and type 'MEDIA_ITEM' received
2011-06-24 13:56:27,863 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 11101)
2011-06-24 13:56:27,864 DEBUG [VideoDAOImpl] Reading a Video (id = 11101)
2011-06-24 13:56:27,864 DEBUG [VideoDeliveryEngine] Delivering item '11101' for client 'IPAddress=/192.168.0.117, Profile=Generic DLNA profile'
2011-06-24 13:56:27,864 DEBUG [VideoDeliveryEngine] Delivering file 'Community S02E01 Anthropology 101 720p WEB-DL DD5.1 H.264 - HoodBag.mkv' in native format
2011-06-24 13:56:27,864 DEBUG [MediaItemDAOImpl] Getting file of media item 11101
2011-06-24 13:56:27,865 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 2000000
2011-06-24 13:56:27,865 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-06-24 13:56:27,868 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-matroska,Content-Range: bytes 19310720-21310719/709162235,Content-Length: 2000000,Date: Fri, 24 Jun 2011 10:56:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
ffmpeg output
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/125) -> 23.98 (24000/1001)
Input #0, matroska, from 'Community.S02.720p.WEB-DL/Community S02E01 Anthropology 101 720p WEB-DL DD5.1 H.264 - HoodBag.mkv':
    doctype         : matroska
  Duration: 00:21:08.96, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
mkvinfo output:
+ EBML head
|+ EBML version: 1
|+ EBML read version: 1
|+ EBML maximum ID length: 4
|+ EBML maximum size length: 8
|+ Doc type: matroska
|+ Doc type version: 2
|+ Doc type read version: 2
+ Segment, size 709162183
|+ Seek head (subentries will be skipped)
|+ EbmlVoid (size: 4044)
|+ Segment information
| + Timecode scale: 1000000
| + Muxing application: libebml v1.0.0 + libmatroska v1.0.0
| + Writing application: mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
| + Duration: 1268.960s (00:21:08.960)
| + Date: Fri Sep 24 14:31:26 2010 UTC
| + Segment UID: 0x8d 0x0d 0x60 0x1d 0x92 0x03 0xb4 0x7e 0x98 0xce 0x1a 0xf1 0x62 0xb9 0xbc 0x55
|+ Segment tracks
| + A track
|  + Track number: 1
|  + Track UID: 1236533646
|  + Track type: video
|  + Lacing flag: 0
|  + MinCache: 1
|  + Codec ID: V_MPEG4/ISO/AVC
|  + CodecPrivate, length 92 (h.264 profile: High @L3.1)
|  + Default duration: 41.708ms (23.976 fps for a video track)
|  + Video track
|   + Pixel width: 1280
|   + Pixel height: 720
|   + Display width: 1280
|   + Display height: 720
| + A track
|  + Track number: 2
|  + Track UID: 2594355124
|  + Track type: audio
|  + Codec ID: A_AC3
|  + Default duration: 32.000ms (31.250 fps for a video track)
|  + Audio track
|   + Sampling frequency: 48000
|   + Channels: 6
|+ EbmlVoid (size: 1098)
|+ Cluster
Post Fri Jun 24, 2011 1:12 pm
load.runner wrote:...if I play the files on LG player through samba, I can seek without problems (on the same files),
What is the LG player through samba?
It seems that seeking is not supported over DLNA for mkv container with LG renderer. (supported by your Totem renderer)
load.runner
Post Fri Jun 24, 2011 8:47 pm
Illico wrote:What is the LG player through samba?
The BX580 supports CIFS, so I can play files over network using a windows share or samba server.
Illico wrote:It seems that seeking is not supported over DLNA for mkv container with LG renderer. (supported by your Totem renderer)
Not true. Seeking works for most of my mkv's over DLNA and for all my mkv's over samba.
I know, if it works over samba, I can just use samba.
But serviio has some advantages over a simple file system sharing.
Post Mon Jun 27, 2011 11:56 am
The requests are there, partial content delivered. If it's not working it's down to the player.
Return to LG
Users browsing this forum: Baidu [Spider] and 3 guests
