LG 47LW6500
mina
Post Mon May 30, 2011 1:01 am
LG 47LW6500
Hello! I bought this monster of a TV and am trying to get this working for my husband before he gets home from work.
I am running Mac OS X 10.6.3 and Java 6.
After installing Serviio, the "DLNA Network" icon is no longer grayed out. The Status tab shows Device Name as "MediaRenderer" and Profile as "Generic DLNA Profile". I tried to add some local folders using the Serviio console interface, but the only thing the TV sees is a folder called "Audio". When I open that folder, it has an empty folder inside labeled "Artists".
I've searched my Mac and don't have any folders that match what the TV is seeing. Plus, I cannot seem to get any of my other folders recognized - not even the desktop. I've made sure to click all the icons, as well, for movie/audio/etc. What am I doing wrong?
p.s. Thanks in advance for the help. :)
Post Mon May 30, 2011 1:17 am
Re: LG 47LW6500
ok so the basics about browsing media from your TV.
ok so you have 3 sections on the TV (audio, video, images) when you want to view a movie you select the video section, if you want to say play the latest evanesance album, you would select the music section. Only the files relevent to the section you select will be displayed sio if your in the audio section you wont be able to see you favorite love film.
ok now for the abit of information about how serviio runs.
ok basicly when u add the files location to serviio in the console, it start to create a database of all the files so taht serviio knows were to fine them when the TV requests them. It can take up to 24hours for this prrocess to finish sometimes more if u have 1000s of files, once this has finished you should see all your files on your tv.
hopefully that clears up some of your questions and keep your hubby happy. :) if you have anymore questions please dont hesitate to ask.
mina
Post Mon May 30, 2011 1:28 am
Re: LG 47LW6500
Phil,
Thank you for your reply! :)
The only thing I see is an Audio folder - no Video or Images folders. Also, I have tried adding only one folder just to see if the TV would see it. The folder has three pictures inside and is located on the desktop, yet the TV is still being stubborn and only shows the empty Audio folder.
I'm sure hubby will be pleasantly surprised to have a new TV but I would be thrilled if I can get this working for him, as well.
Post Mon May 30, 2011 1:43 am
Re: LG 47LW6500
hmm ok maybe its a setup issue, have you got the LG profile selected for your tv in serviios console ?
mina
Post Mon May 30, 2011 1:48 am
Re: LG 47LW6500
The only profile that shows up is "Generic DLNA Profile".
Post Mon May 30, 2011 1:59 am
Re: LG 47LW6500
mina wrote:The only profile that shows up is "Generic DLNA Profile".
Click the little down arrow next to that and select the LG tv profile :)
mina
Post Mon May 30, 2011 2:09 am
Re: LG 47LW6500
OMG I did not realize that was a pull down menu! I feel so silly now. :D
But... the only LG item is "LG BD player". It's obviously not a blu-ray player but it is LG. Should I select that one? :D
Post Mon May 30, 2011 2:12 am
Re: LG 47LW6500
mina wrote:OMG I did not realize that was a pull down menu! I feel so silly now. :D
oh really thoguht we had a TV one in there too my bad :( yer try the LG BD-player one for now and will se if i can find you a TV one here on the forums. :)
mina
Post Mon May 30, 2011 2:16 am
Re: LG 47LW6500
You are so helpful. Thank you so very very much. :)
I tried the LG BD profile and no luck - still showing that phantom empty Audio folder. But I feel like I am getting somewhere, at least!
Post Mon May 30, 2011 2:18 am
Re: LG 47LW6500
mina wrote:You are so helpful. Thank you so very very much. :)
ok i guess we are still not doing something, are you sure there isnt a menu on the tv were you can select one of the 3 catagories i mentioned in my first post (audio, video, images ) ?
mina
Post Mon May 30, 2011 2:20 am
Re: LG 47LW6500
Yeap, the only folder available is "Audio".
When I click on "Audio", it opens a subfolder called "Artists".
When I click on "Artists", it says "Folder is empty."
Post Mon May 30, 2011 2:26 am
Re: LG 47LW6500
mina wrote:Yeap, the only folder available is "Audio".
hmm very strange well along as the folders you add to console have the file in your want to share then we should be fine with serviio part of things and we have covered evry stage of that, only thing i can say now is check in the LG manual and make sure u are accessing serviio correctly from the tv menus :(
mina
Post Mon May 30, 2011 2:30 am
Re: LG 47LW6500
Thanks, Phil. It does appear to be showing Serviio correctly, since DLNA does not light up unless I run the Serviio app. I just don't understand why it won't show the folder I've added, especially since they are simple jpg files that shouldn't take THAT long to register, right?
Either way, thank you again for trying to help me out. I hope I get it figured out soon! :)
mina
Post Mon May 30, 2011 7:48 am
Re: LG 47LW6500
Well, I don't know what the problem is, although I did notice one weird thing. When I right-click on the application in the dock, it shows "Application Not Responding" but greyed out. Is this normal?
I downloaded a random DLNA server called iSedora, installed it, and was able to access the files on my laptop without any issues. I just don't know what I did wrong with Serviio. Should I post a log?
mina
Post Mon May 30, 2011 8:17 am
Re: LG 47LW6500
Well, here's the log... Please, somebody, tell me what I've stuffed up here! xD
2011-05-30 18:16:20,371 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-05-30 18:16:20,378 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-30 18:16:20,378 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-30 18:16:20,378 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-30 18:16:20,378 INFO [MediaServer] http://www.serviio.org
2011-05-30 18:16:20,378 INFO [MediaServer] Java 1.6.0_20-Apple Inc.
2011-05-30 18:16:20,378 INFO [MediaServer] OS Mac OS X x86_64 10.6.3
2011-05-30 18:16:20,378 INFO [MediaServer] File encoding: UTF-8
2011-05-30 18:16:20,530 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-30 18:16:20,590 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-30 18:16:20,598 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-05-30 18:16:21,486 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-05-30 18:16:21,487 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-05-30 18:16:21,488 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-05-30 18:16:21,488 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-05-30 18:16:21,489 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-05-30 18:16:21,490 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-05-30 18:16:21,490 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-05-30 18:16:21,491 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-05-30 18:16:22,009 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-30 18:16:22,037 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-05-30 18:16:22,473 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-30 18:16:22,474 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-05-30 18:16:22,622 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-30 18:16:22,623 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-05-30 18:16:22,706 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-30 18:16:22,707 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-05-30 18:16:22,772 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-30 18:16:22,773 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-05-30 18:16:22,867 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-30 18:16:22,868 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-05-30 18:16:22,919 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-30 18:16:22,921 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-05-30 18:16:23,055 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-30 18:16:23,056 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-05-30 18:16:23,091 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-30 18:16:23,092 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-05-30 18:16:23,327 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-30 18:16:23,328 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-05-30 18:16:23,693 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-30 18:16:23,694 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-05-30 18:16:23,783 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-30 18:16:23,785 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-05-30 18:16:23,890 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-30 18:16:23,893 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg
2011-05-30 18:16:23,895 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg
2011-05-30 18:16:23,940 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-30 18:16:23,943 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-05-30 18:16:23,968 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-30 18:16:24,001 INFO [WebServer] WebServer starting on port 8895
2011-05-30 18:16:24,016 INFO [Device] Created UPnP Device with UUID: 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8, bound address: 10.0.1.4
2011-05-30 18:16:24,037 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-30 18:16:24,054 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-30 18:16:24,057 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-30 18:16:24,057 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-30 18:16:24,059 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-30 18:16:24,059 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-30 18:16:24,059 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1306743384059, LastAccessTime = 1306743384059, getTimeToLiveSeconds() = -1, createTime = 1306743384059 ]
2011-05-30 18:16:24,061 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-30 18:16:24,075 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-30 18:16:24,075 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-30 18:16:24,075 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-30 18:16:24,075 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-30 18:16:24,075 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-30 18:16:24,076 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-30 18:16:24,076 INFO [CompositeCacheConfigurator] Finished configuration in 20 ms.
2011-05-30 18:16:24,077 DEBUG [DiscoveryManager] UPNP device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 (10.0.1.4) is available
2011-05-30 18:16:24,079 INFO [EventDispatcher] Starting EventDispatcher
2011-05-30 18:16:24,080 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-30 18:16:24,083 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 10.0.1.4, timeout = 0
2011-05-30 18:16:24,084 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-30 18:16:24,087 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-30 18:16:24,087 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-30 18:16:24,090 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface en1 (en1) and address 10.0.1.4, timeout = 0
2011-05-30 18:16:24,104 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-05-30 18:16:24,113 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.0.1.4:49705
2011-05-30 18:16:24,113 DEBUG [RendererSearchSender] Received search response: location: http://10.0.1.8:37904/MediaRenderer1.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-05-30 18:16:24,115 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 19eb700a-1dd2-11b2-bdbe-928b 0e3231c from address /10.0.1.8:1900
2011-05-30 18:16:24,117 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.0.1.4:49705
2011-05-30 18:16:24,119 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.0.1.4:49705
2011-05-30 18:16:24,120 DEBUG [RendererSearchSender] Received search response: location: http://10.0.1.8:37904/MediaRenderer1.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-05-30 18:16:24,120 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 19eb700a-1dd2-11b2-bdbe-928b 0e3231c from address /10.0.1.8:1900
2011-05-30 18:16:24,140 DEBUG [RendererManager] Adding renderer Renderer [uuid=19eb700a-1dd2-11b2-bdbe-928b 0e3231c, ipAddress=10.0.1.8, name=MediaRenderer, profileId=1, manuallyAdded=false] to list of active renderers
2011-05-30 18:16:24,154 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 10.0.1.4, timeout = 0
2011-05-30 18:16:24,155 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8
2011-05-30 18:16:24,783 DEBUG [WebServer] Incoming connection from /10.0.1.8:46707
2011-05-30 18:16:24,787 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 from 10.0.1.8 (headers = [HOST: 10.0.1.4:8895,DATE: Mon, 30 May 2011 08:16:23 GMT,USER-AGENT: Linux/2.6.28.9 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.5.0,friendlyName.dlna.org: LG DLNA DMC v0.1])
2011-05-30 18:16:24,787 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:24,797 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:24,997 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-05-30 18:16:25,029 DEBUG [WebServer] Incoming connection from /10.0.1.8:46708
2011-05-30 18:16:25,030 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-05-30 18:16:25,042 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-30 18:16:25,092 DEBUG [WebServer] Incoming connection from /10.0.1.8:46709
2011-05-30 18:16:25,093 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-05-30 18:16:25,133 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-05-30 18:16:25,965 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-05-30 18:16:26,111 DEBUG [RendererSearchSender] Received search response: location: http://10.0.1.8:37904/MediaRenderer1.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-05-30 18:16:26,111 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 19eb700a-1dd2-11b2-bdbe-928b 0e3231c from address /10.0.1.8:1900
2011-05-30 18:16:30,104 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-05-30 18:16:35,967 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 10.0.1.4, timeout = 0
2011-05-30 18:16:35,968 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8
2011-05-30 18:16:37,776 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-05-30 18:16:44,153 INFO [UpdateChecker] Checking if a new version is available
2011-05-30 18:16:45,614 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-05-30 18:16:46,176 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2011-05-30 18:16:47,777 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 10.0.1.4, timeout = 0
2011-05-30 18:16:47,777 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8
2011-05-30 18:16:48,259 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-05-30 18:16:48,280 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-05-30 18:16:49,589 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:08
2011-05-30 18:16:50,109 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-30 18:16:50,109 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-05-30 18:16:50,115 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/chocopaws/Desktop/Hamasaki Ayumi - Tokyo Myth PB
2011-05-30 18:16:50,116 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-30 18:16:50,116 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-05-30 18:16:50,117 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: /Users/chocopaws/Desktop/Hamasaki Ayumi - Tokyo Myth PB
2011-05-30 18:16:50,119 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 5)
2011-05-30 18:16:50,157 DEBUG [LibraryAdditionsCheckerThread] Found file 'Untitled1.jpg', checking if it's already in the Library
2011-05-30 18:16:50,157 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Untitled1.jpg
2011-05-30 18:16:50,254 DEBUG [MediaItemDAOImpl] Media item Untitled1.jpg already exists in DB
2011-05-30 18:16:50,275 DEBUG [LibraryAdditionsCheckerThread] Found file 'Untitled2.jpg', checking if it's already in the Library
2011-05-30 18:16:50,275 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Untitled2.jpg
2011-05-30 18:16:50,278 DEBUG [MediaItemDAOImpl] Media item Untitled2.jpg already exists in DB
2011-05-30 18:16:50,299 DEBUG [LibraryAdditionsCheckerThread] Found file 'Untitled3.jpg', checking if it's already in the Library
2011-05-30 18:16:50,299 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Untitled3.jpg
2011-05-30 18:16:50,302 DEBUG [MediaItemDAOImpl] Media item Untitled3.jpg already exists in DB
2011-05-30 18:16:50,302 DEBUG [RepositoryDAOImpl] Marking Repository 5 as scanned with current timestamp
2011-05-30 18:16:50,344 DEBUG [MediaItemDAOImpl] Getting file of media item 71
2011-05-30 18:16:50,395 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-05-30 18:16:50,397 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-05-30 18:16:50,398 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2011-05-30 18:16:50,400 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 71) and extractor EMBEDDED
2011-05-30 18:16:50,519 DEBUG [MediaItemDAOImpl] Getting file of media item 82
2011-05-30 18:16:50,522 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 82) and extractor EMBEDDED
2011-05-30 18:16:50,573 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-30 18:16:50,591 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = null
2011-05-30 18:16:50,613 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,618 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,624 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,627 DEBUG [MediaItemDAOImpl] Getting file of media item 93
2011-05-30 18:16:50,630 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 93) and extractor EMBEDDED
2011-05-30 18:16:50,630 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,631 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 5)
2011-05-30 18:16:50,647 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,652 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,658 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,662 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-05-30 18:16:50,667 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,676 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,681 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,687 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,692 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,702 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,710 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-05-30 18:16:50,716 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2011-05-30 18:16:50,724 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-05-30 18:16:50,729 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,736 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-05-30 18:16:50,744 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,749 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,749 DEBUG [RepositoryDAOImpl] Marking Repository 5 as scanned with current timestamp
2011-05-30 18:16:50,755 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-05-30 18:16:50,760 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,765 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,772 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,777 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,783 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,788 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,793 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,802 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-05-30 18:16:50,807 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,813 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,819 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,824 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,831 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,835 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,840 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,845 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-05-30 18:16:50,851 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,857 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,870 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,880 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,886 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,894 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,899 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,904 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2011-05-30 18:16:50,911 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2011-05-30 18:16:50,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-05-30 18:16:50,929 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,934 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-05-30 18:16:50,940 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2011-05-30 18:16:50,945 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-05-30 18:16:50,952 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,959 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,964 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,969 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,974 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,979 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:50,986 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,992 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-05-30 18:16:50,997 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,006 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:51,012 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,019 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,024 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,030 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-05-30 18:16:51,035 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,041 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,048 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-05-30 18:16:51,052 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-30 18:16:52,861 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-05-30 18:16:56,614 DEBUG [WebServer] Incoming connection from /10.0.1.8:46714
2011-05-30 18:16:56,615 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ConnectionManager
2011-05-30 18:16:56,615 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=f2589542-ff14-436d-99c3-0d16873ac810) for service urn:upnp-org:serviceId:ConnectionManager reporting to http://10.0.1.8:40430/
2011-05-30 18:16:56,626 DEBUG [WebServer] Incoming connection from /10.0.1.8:46715
2011-05-30 18:16:56,627 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2011-05-30 18:16:56,628 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=5ffc37c7-d020-4fee-919b-f5db61a826e8) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://10.0.1.8:40430/
2011-05-30 18:16:57,040 DEBUG [WebServer] Incoming connection from /10.0.1.8:46716
2011-05-30 18:16:57,043 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:57,043 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:57,110 DEBUG [EventDispatcher] Sending event notification #0 for subscription 5ffc37c7-d020-4fee-919b-f5db61a826e8 to endpoint http://10.0.1.8:40430/
2011-05-30 18:16:57,119 DEBUG [RequestExecutor] Sending HTTP request to 10.0.1.8:40430
2011-05-30 18:16:57,135 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = 0, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 0, sortCriteria =
2011-05-30 18:16:57,137 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-05-30 18:16:57,137 DEBUG [EventDispatcher] Sending event notification #0 for subscription f2589542-ff14-436d-99c3-0d16873ac810 to endpoint http://10.0.1.8:40430/
2011-05-30 18:16:57,138 DEBUG [RequestExecutor] Sending HTTP request to 10.0.1.8:40430
2011-05-30 18:16:57,147 DEBUG [EventDispatcher] Event notification sent and received successfully
2011-05-30 18:16:57,156 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:57,173 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:57,188 DEBUG [WebServer] Incoming connection from /10.0.1.8:46717
2011-05-30 18:16:57,189 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:57,189 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:57,195 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:57,196 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:57,201 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:57,222 DEBUG [WebServer] Incoming connection from /10.0.1.8:46718
2011-05-30 18:16:57,223 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:57,223 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:57,228 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 1, sortCriteria =
2011-05-30 18:16:57,228 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:57,232 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:57,248 DEBUG [WebServer] Incoming connection from /10.0.1.8:46719
2011-05-30 18:16:57,248 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:57,248 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:57,253 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:57,253 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-05-30 18:16:57,258 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:58,370 DEBUG [WebServer] Incoming connection from /10.0.1.8:46720
2011-05-30 18:16:58,371 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:58,371 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:58,375 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:58,375 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-05-30 18:16:58,380 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:58,403 DEBUG [WebServer] Incoming connection from /10.0.1.8:46721
2011-05-30 18:16:58,404 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:58,404 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:58,411 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 0, sortCriteria =
2011-05-30 18:16:58,412 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:58,415 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:58,430 DEBUG [WebServer] Incoming connection from /10.0.1.8:46722
2011-05-30 18:16:58,431 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:58,431 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:58,435 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:58,441 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2011-05-30 18:16:58,474 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2011-05-30 18:16:58,489 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2011-05-30 18:16:58,526 DEBUG [MusicTrackDAOImpl] Retrieving number of music track initials
2011-05-30 18:16:58,546 DEBUG [MusicTrackDAOImpl] Retrieving number of random music tracks
2011-05-30 18:16:58,559 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:58,566 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:58,593 DEBUG [WebServer] Incoming connection from /10.0.1.8:46723
2011-05-30 18:16:58,594 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:58,594 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:58,600 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 1, sortCriteria =
2011-05-30 18:16:58,600 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2011-05-30 18:16:58,601 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:58,605 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:58,621 DEBUG [WebServer] Incoming connection from /10.0.1.8:46724
2011-05-30 18:16:58,622 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:58,622 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:58,627 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:58,627 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-05-30 18:16:58,637 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:59,670 DEBUG [WebServer] Incoming connection from /10.0.1.8:46725
2011-05-30 18:16:59,670 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:59,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:59,675 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:59,675 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-05-30 18:16:59,680 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:59,709 DEBUG [WebServer] Incoming connection from /10.0.1.8:46726
2011-05-30 18:16:59,710 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:59,710 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:59,716 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A_A, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 0, sortCriteria =
2011-05-30 18:16:59,717 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2011-05-30 18:16:59,718 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:59,722 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:16:59,737 DEBUG [WebServer] Incoming connection from /10.0.1.8:46727
2011-05-30 18:16:59,738 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.0.1.8:
2011-05-30 18:16:59,738 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.1.8
2011-05-30 18:16:59,743 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 1) with parameters: objectID = A_A, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2011-05-30 18:16:59,743 DEBUG [PersonDAOImpl] Retrieving list of person initials (role = ARTIST, from=0, count=16)
2011-05-30 18:16:59,764 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2011-05-30 18:16:59,765 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-30 18:16:59,768 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-30 18:17:01,635 DEBUG [WebServer] Incoming connection from /10.0.1.8:46729
2011-05-30 18:17:11,636 DEBUG [WebServer] Incoming connection from /10.0.1.8:46730
Post Mon May 30, 2011 9:17 am
Re: LG 47LW6500
Could you post a screen copy of your serviio library tab, or detail all options you set?
The DLNA certification of LG 47LW6500
Audio / Video / Photo are supported over DLNA...
Do you have another computer on Windows for testing? if yes, could you try this tool to see supported format by your LG TV?
Post Mon May 30, 2011 11:16 am
Re: LG 47LW6500
You added some images but in the log you're browsing Audio/Artists category.
mina
Post Mon May 30, 2011 11:22 am
Re: LG 47LW6500
zip wrote:You added some images but in the log you're browsing Audio/Artists category.
Hi zip. :) Yeah, that's the problem - the ONLY folder that shows up is Audio. There is no Video or Image folder for me to choose. :(
mina
Post Mon May 30, 2011 11:29 am
Re: LG 47LW6500
Illico wrote:Could you post a screen copy of your serviio library tab, or detail all options you set?
Hi Illico :)
Here is the screen cap:
I only added that local path to a folder on my desktop for testing purposes. I figured if I could at least get an Image folder to show up, I'd have solved my problem and could add video files later.
Unfortunately, I do not have a Windows machine to use, so I cannot try out the tool you suggested. :(
Post Mon May 30, 2011 12:11 pm
Re: LG 47LW6500
According to your Library tab settings, you only add a folder path for "images" parsing.
So no audio, no video under the serviio library, only images.
With your TV, when you'll browse audio folders or video folders, you will have empty folders.
But if you select the images category under your TV menu, read the usermanual:
Home --> Smart Share --> Select Device (Serviio) --> Photo List --> Forder
You may have all "images" of the serviio library.
About LG DLNA:
- If there are too many folders and files in one folder, it may not operate properly.
- When playing a video in DLNA mode, the Multi Audio and Closed Caption features are not supported.
- When selecting Full Screen in DLNA mode, the ratio of the outputted screen may differ from the original.
- When more than one TV is connected to a single server in DLNA mode, a file may not play properly, depending on the server performance.
- If the play time information is not provided by the server, it is displayed as "- -."
Return to LG
Users browsing this forum: Baidu [Spider] and 1 guest
