LG app for serviio?
Johan1974
Post Sun Aug 31, 2014 10:56 am
LG app for serviio?
For plex i am having an lg app (installed on a usb stick)to use on my tv. Now i like to compare serviio so i was wondering if there is an app available that i can use on my lg tv?
Is there such an app for serviio too?
Thanks!
Johan
DS413 DSM 5.0-4493 Update 3
1 x WD30EFRX-68AX9N0
1 x WD60EFRX-68MYMN0
Iveky
Post Mon Sep 01, 2014 4:17 am
Re: LG app for serviio?
not needed, read wiki
Johan1974
Post Tue Sep 02, 2014 9:09 am
Not sure where to look on the wiki as i do not see anything about the LG TV.
I you are referring to the DLNA connection i get the same boring labels what i normally also have with my normal DLNA connection to my LG tv.
Could you be more specific to what part of the wiki you are referring?
Thanks!
Johan
Return to LG
