Subtitle doesn't show with Generic DLNA Profile.
verahert
Post Sat Feb 05, 2011 3:57 pm
Hi All,
Well i have a LG 42LD650, When i'm using the Generic DLNA Profile, with this profile can't show subtitles, the files are .mkv with DTS and ac3 dolby. On the other hand if i select the profile LG BD Player the subs are showed but the problem is the audio, the tv cannot support DTS but if i transcode to AC3 the file can't be opened.
In Conslusion:
Generic DLNA Profile + MKV + DTS + AC3 + SRT = NO SUBS
LG BD Player + MKV + DTS + SRT = Show subs but NO AUDIO
If i transcode the audio:
LG BD Player + MKV + DTS + AC3 + SRT = can not open
Regards,
Nicolás.
Post Sun Feb 06, 2011 11:43 am
Re: Subtitle doesn't show with Generic DLNA Profile.
So we have to create a new profile for the TV. Start with a really simple one (just extends from Generic) and add the subtitle bit. Like:
<Profile id="14" name="LG TV" extendsProfileId="1">
Other possibility is to use LG BD profile and disable transcoding in the console.
verahert
Post Mon Feb 07, 2011 1:35 pm
Finally works =) many thanks! another question is it possible to trancode DTS to AC3? because i have to transcode with "MKV Audioconverter" all my DTS mkv files to play in my LG TV, is another way to play DTS in LG TV?
Regards, Nicolás.
Post Mon Feb 07, 2011 1:50 pm
try asdding this into your new profile
  <Video targetContainer="mpegts" targetACodec="mp3">
verahert
Post Mon Feb 07, 2011 2:38 pm
sorry but why is targetACodec="mp3" instead of targetACodec="ac3" or "acc" =/
verahert
Post Mon Feb 07, 2011 3:04 pm
It doesn't work "this file is not valid" =/
Post Mon Feb 07, 2011 3:14 pm
could be either of the codecs, you can try....
can you post detailed log of trying to play the file?
verahert
Post Mon Feb 07, 2011 3:33 pm
sorry i'm a newbie in this, How I look at the log?
verahert
Post Mon Feb 07, 2011 3:56 pm
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "F:\Cars\Cars.mkv"
configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0128bb10] max_analyze_duration reached
[matroska,webm @ 0128bb10] Estimating duration from bitrate, this may be inaccurate Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (5000000/208542)
Input #0, matroska,webm, from 'F:\Cars\Cars.mkv':
Duration: 01:56:36.00, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : x264 - crf encode
Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
title : DTS - 1536 kbit/sec
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
Stream #0.3(dut): Subtitle: [0][0][0][0] / 0x0000
Post Mon Feb 07, 2011 5:57 pm
verahert
Post Mon Feb 07, 2011 6:36 pm
Here is the detailed log:
2011-02-07 15:03:05,824 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-07 15:03:05,824 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-07 15:03:05,824 DEBUG [VideoDeliveryEngine] Delivering item '109' for client 'IPAddress=/192.168.1.35, Profile=LG TV'
2011-02-07 15:03:05,824 DEBUG [VideoDeliveryEngine] Delivering file 'Cars.mkv' using transcoding
2011-02-07 15:03:05,824 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.35, Profile=LG TV'
2011-02-07 15:03:05,824 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-07 15:03:05,840 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: F:\Cars\Cars.mkv
2011-02-07 15:03:05,840 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Cars\Cars.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec libmp3lame -ab 192k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-109-MPEG2TS.stf
2011-02-07 15:03:05,949 WARN  [ProcessExecutor] Process C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe has a return code of 1! This is a possible error.
2011-02-07 15:03:05,949 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-02-07 15:03:13,562 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveTranscodedResource(VideoDeliveryEngine.java:160)
   at org.serviio.delivery.resource.VideoDeliveryEngine.retrieveTranscodedResource(VideoDeliveryEngine.java:54)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:90)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:116)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:126)
   at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:52)
2011-02-07 15:03:13,562 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.35, Profile=LG TV'
2011-02-07 15:03:15,824 DEBUG [WebServer] Incoming connection from /192.168.1.35:50661
2011-02-07 15:03:15,824 DEBUG [ResourceTransportRequestHandler] GET /resource/109/MEDIA_ITEM/AVC_TS_MP_HD_MPEG1_L3_ISO HTTP/1.1, headers = [Host: 192.168.1.33:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,User-Agent: Mozilla/5.0 (compatible; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast-2010)]]
2011-02-07 15:03:15,824 DEBUG [WebServer] Incoming connection from /192.168.1.35:50662
2011-02-07 15:03:15,824 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-07 15:03:15,824 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.35, Profile=LG TV'
2011-02-07 15:03:15,824 DEBUG [ResourceTransportRequestHandler] Request for resource 109 and type 'MEDIA_ITEM' received
2011-02-07 15:03:15,824 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-07 15:03:15,840 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-07 15:03:15,840 DEBUG [VideoDeliveryEngine] Delivering item '109' for client 'IPAddress=/192.168.1.35, Profile=LG TV'
2011-02-07 15:03:15,840 DEBUG [VideoDeliveryEngine] Delivering file 'Cars.mkv' using transcoding
2011-02-07 15:03:15,840 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.35, Profile=LG TV'
2011-02-07 15:03:15,840 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Post Mon Feb 07, 2011 7:33 pm
Could you execute locally this command line and check the result?
ffmpeg.exe -i "F:\Cars\Cars.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec libmp3lame -ab 192k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts Output.ts
verahert
Post Mon Feb 07, 2011 8:08 pm
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "F:\Cars\Cars.mkv" -y -vcodec c
686-mingw32-
[matroska,webm @ 02af1b40] max_analyze_duration reached
[matroska,webm @ 02af1b40] Estimating duration from bitrate, this may be inaccur
ate
Output #0, mpegts, to 'Output.ts':
Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1920x800 [PAR 1:1 D
AR 12:5], q=2-31, 90k tbn, 23.98 tbc
Stream #0.1(eng): Audio: libmp3lame, 48000 Hz, 5.1, s16, 192 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening encoder for output stream #0.1 - maybe incorrect parameters
such as bit_rate, rate, width or height
C:\Program Files (x86)\Serviio\lib>dir
Post Mon Feb 07, 2011 8:16 pm
Could you try this:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "F:\Cars\Cars.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec libmp3lame -ab 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts Output.ts
or this
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "F:\Cars\Cars.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts Output.ts
Thks
verahert
Post Mon Feb 07, 2011 8:26 pm
let me check
verahert
Post Mon Feb 07, 2011 8:41 pm
i don't know why but the ffmpeg.exe has 0kB and when i run this commands appear an error window: is not a valid win32 applications :S
verahert
Post Mon Feb 07, 2011 8:50 pm
686-mingw32-
[matroska,webm @ 02931b40] max_analyze_duration reached
[matroska,webm @ 02931b40] Estimating duration from bitrate, this may be inaccur
ate
[mpegts @ 04090050] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
40 pkts
encoder : Lavf52.92.0
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, flt, 384 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 2605 fps=743 q=-1.0 size= 80782kB time=108.57 bitrate=6095.5kbits/s
frame= 2844 fps=710 q=-1.0 size= 106902kB time=118.54 bitrate=7388.0kbits/s
frame= 3050 fps=579 q=-1.0 size= 126263kB time=127.13 bitrate=8136.4kbits/s
frame= 3292 fps=571 q=-1.0 size= 150593kB time=137.22 bitrate=8990.3kbits/s
frame= 3527 fps=563 q=-1.0 size= 174993kB time=147.02 bitrate=9750.5kbits/s
frame= 3764 fps=556 q=-1.0 size= 200015kB time=156.91 bitrate=10442.6kbits/s
frame= 4002 fps=550 q=-1.0 size= 224229kB time=166.83 bitrate=11010.3kbits/s
frame= 4261 fps=548 q=-1.0 size= 245066kB time=177.64 bitrate=11301.7kbits/s
frame= 4541 fps=549 q=-1.0 size= 265011kB time=189.31 bitrate=11467.5kbits/s
frame= 4785 fps=545 q=-1.0 size= 289283kB time=199.49 bitrate=11879.2kbits/s
frame= 5070 fps=547 q=-1.0 size= 307286kB time=211.38 bitrate=11909.0kbits/s
frame= 5346 fps=547 q=-1.0 size= 325692kB time=222.89 bitrate=11970.3kbits/s
frame= 5366 fps=546 q=-1.0 Lsize= 326582kB time=223.72 bitrate=11958.3kbits/s
video:291016kB audio:10494kB global headers:0kB muxing overhead 8.315410%
Received signal 2: terminating.
Finally I think its working :)
verahert
Post Mon Feb 07, 2011 9:49 pm
how can i implement this in Serviio?
Post Tue Feb 08, 2011 7:58 am
Check "keep original" audio channels on Transcoding console Tab
verahert
Post Tue Feb 08, 2011 4:02 pm
It doesn't work "this file is not valid" here the log:
2011-02-08 12:18:42,691 DEBUG [VideoDeliveryEngine] Delivering item '109' for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:42,691 DEBUG [VideoDeliveryEngine] Delivering file 'Cars.mkv' using transcoding
2011-02-08 12:18:42,692 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:42,692 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:42,694 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: F:\Cars\Cars.mkv
2011-02-08 12:18:42,694 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Cars\Cars.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-109-MPEG2TS.stf
2011-02-08 12:18:43,194 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,195 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:43,195 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2011-02-08 12:18:43,195 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 109) as read
2011-02-08 12:18:43,203 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:43,203 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2011-02-08 12:18:43,203 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 109) as read
2011-02-08 12:18:43,205 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-02-08 12:18:43,207 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Tue, 08 Feb 2011 15:18:43 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-02-08 12:18:43,237 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-02-08 12:18:43,238 DEBUG [WebServer] Incoming connection from /192.168.1.35:48693
2011-02-08 12:18:43,239 DEBUG [ResourceTransportRequestHandler] GET /resource/109/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [Host: 192.168.1.33:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=4611686018427371520-,User-Agent: Mozilla/5.0 (compatible; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast-2010)]]
2011-02-08 12:18:43,239 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:43,239 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,240 DEBUG [ResourceTransportRequestHandler] Request for resource 109 and type 'MEDIA_ITEM' received
2011-02-08 12:18:43,240 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:43,240 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-08 12:18:43,241 DEBUG [VideoDeliveryEngine] Delivering item '109' for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,241 DEBUG [VideoDeliveryEngine] Delivering file 'Cars.mkv' using transcoding
2011-02-08 12:18:43,242 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,242 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:43,242 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -4611686009427371520
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 4611686018427371520-8999999999/9000000000,Date: Tue, 08 Feb 2011 15:18:43 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-02-08 12:18:46,098 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-02-08 12:19:10,502 DEBUG [WebServer] Incoming connection from /192.168.1.35:48696
2011-02-08 12:19:10,503 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ContentDirectory and subscription uuid:0044bb63-5371-4b71-9f24-82b2e6d9bcae
2011-02-08 12:19:10,503 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription (uuid=0044bb63-5371-4b71-9f24-82b2e6d9bcae) removed for service urn:upnp-org:serviceId:ContentDirectory
2011-02-08 12:19:10,506 DEBUG [WebServer] Incoming connection from /192.168.1.35:48697
2011-02-08 12:19:10,506 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ConnectionManager and subscription uuid:edf46638-0449-416a-95e2-0502d3545638
2011-02-08 12:19:10,506 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription (uuid=edf46638-0449-416a-95e2-0502d3545638) removed for service urn:upnp-org:serviceId:ConnectionManager
2011-02-08 12:19:20,061 INFO  [ServiioConsole] Leaving Serviio Console
2011-02-08 12:19:20,073 DEBUG [ActionsServerResource] Action with name 'exitServiio' was requested
2011-02-08 12:19:20,077 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-02-08 12:19:20,275 DEBUG [DiscoveryManager] UPNP device 7c244fb3-0b22-3d10-94e6-71e4e0006f49 (192.168.1.33) is unavailable
2011-02-08 12:19:20,275 INFO  [EventDispatcher] Leaving EventDispatcher
2011-02-08 12:19:20,282 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-02-08 12:19:20,282 DEBUG [WebServer] Socket closed
2011-02-08 12:19:20,282 INFO  [WebServer] WebServer shutting down
2011-02-08 12:19:20,282 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-02-08 12:19:20,535 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Atheros L1 Gigabit Ethernet 10/100/1000Base-T Controller) and address PC-Nico, timeout = 0
2011-02-08 12:19:20,536 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-02-08 12:19:20,537 INFO  [DatabaseManager] Shutting down database
Return to LG
