problems browsing with LG BH5320F
poltrona
Post Wed May 07, 2014 8:04 pm
i've been using Serviio without problems for about 3 months, but a couple of days ago I stopped working.... I'm able to see SERVIIO SERVER, but when I select it, instead showing the shared folder as it used to, now hungs and stays "looking" forever....
i've only been able to see this, don't know if it helps....
Wed May 07 21:45:29 CEST 2014:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.10.1.1 - (1458268): instance a816c00e-0145-d838-2308-ffff8366333d
on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@12360be0
Loaded from file:/C:/Program%20Files/Serviio/lib/derby.jar
java.vendor=Sun Microsystems Inc.
java.runtime.version=1.6.0_27-b07
user.dir=C:\Program Files\Serviio\bin
os.name=Windows 7
os.arch=amd64
os.version=6.1
derby.system.home=C:\Program Files\Serviio\bin\\..\library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Wed May 07 21:46:01 CEST 2014 Thread[LibraryUpdatesCheckerThread,1,main] (XID = 2719042), (SESSIONID = 3), (DATABASE = db), (DRDAID = null), Cleanup action starting
Wed May 07 21:46:01 CEST 2014 Thread[LibraryUpdatesCheckerThread,1,main] (XID = 2719042), (SESSIONID = 3), (DATABASE = db), (DRDAID = null), Failed Statement is: DELETE FROM person_role WHERE media_item_id = ? with 1 parameters begin parameter #1: 35 :end parameter
ERROR 08000: Connection closed by unknown interrupt.
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DeleteResultSet.collectAffectedRows(Unknown Source)
at org.apache.derby.impl.sql.execute.DeleteResultSet.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeLargeUpdate(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.PersonDAOImpl.removeAllPersonsFromMedia(PersonDAOImpl.java:208)
at org.serviio.library.local.service.VideoService.removeVideoFromLibrary(VideoService.java:167)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.searchForRemovedAndUpdatedFiles(LibraryUpdatesCheckerThread.java:175)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:99)
Cleanup action completed
thanks on advance!!
Post Tue May 13, 2014 6:19 pm
Re: problems browsing with LG BH5320F
perhaps the DB got corrupted, try to reinstall (clean install)
Return to LG
Users browsing this forum: Baidu [Spider] and 13 guests
