Subtitle doesn't show with Generic DLNA Profile.
Post Tue Feb 08, 2011 4:04 pm
Re: Subtitle doesn't show with Generic DLNA Profile.
Yeah, the TV doesn't like transcoded files. It asks for nonexistent byte ranges - I think it's a bug in the TV's firmware.
Post Tue Feb 08, 2011 5:30 pm
verahert wrote:It doesn't work "this file is not valid"
In fact, I did not pay attention on this
Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], q=2-31, 90k tbn, 23.98 tbc
verahert
Post Tue Feb 08, 2011 5:45 pm
ok =( i will convert the DTS to AC3 with mkv audioconverter =/
Post Tue Feb 08, 2011 5:52 pm
Can you actually post your whole log, I need some lines that are above of what you posted before.
verahert
Post Tue Feb 08, 2011 6:01 pm
2011-02-08 12:18:29,313 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:29,332 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:29,338 DEBUG [MediaItemDAOImpl] Getting file of media item 86
2011-02-08 12:18:29,340 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 86) and extractor EMBEDDED
2011-02-08 12:18:29,440 DEBUG [MediaItemDAOImpl] Getting file of media item 87
2011-02-08 12:18:29,441 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 87) and extractor EMBEDDED
2011-02-08 12:18:29,473 DEBUG [WebServer] Incoming connection from /192.168.1.35:48666
2011-02-08 12:18:29,474 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:29,474 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:29,477 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 64, sortCriteria =
2011-02-08 12:18:29,478 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:29,497 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:29,542 DEBUG [MediaItemDAOImpl] Getting file of media item 88
2011-02-08 12:18:29,543 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 88) and extractor EMBEDDED
2011-02-08 12:18:29,644 DEBUG [MediaItemDAOImpl] Getting file of media item 89
2011-02-08 12:18:29,645 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 89) and extractor EMBEDDED
2011-02-08 12:18:29,746 DEBUG [MediaItemDAOImpl] Getting file of media item 90
2011-02-08 12:18:29,747 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 90) and extractor EMBEDDED
2011-02-08 12:18:29,848 DEBUG [MediaItemDAOImpl] Getting file of media item 91
2011-02-08 12:18:29,849 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 91) and extractor EMBEDDED
2011-02-08 12:18:29,950 DEBUG [MediaItemDAOImpl] Getting file of media item 93
2011-02-08 12:18:29,951 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 93) and extractor EMBEDDED
2011-02-08 12:18:29,956 DEBUG [WebServer] Incoming connection from /192.168.1.35:48667
2011-02-08 12:18:29,956 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:29,956 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:29,960 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 0, sortCriteria =
2011-02-08 12:18:29,960 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-08 12:18:29,961 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:29,963 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:29,974 DEBUG [WebServer] Incoming connection from /192.168.1.35:48668
2011-02-08 12:18:29,975 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:29,975 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:29,978 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 1, sortCriteria =
2011-02-08 12:18:29,978 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=1)
2011-02-08 12:18:29,984 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-02-08 12:18:29,997 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-08 12:18:29,997 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:30,000 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,018 DEBUG [WebServer] Incoming connection from /192.168.1.35:48669
2011-02-08 12:18:30,018 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,018 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,021 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V, browseFlag = BrowseMetadata, filter = upnp:class, startIndex = 0, count = 0, sortCriteria =
2011-02-08 12:18:30,022 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:30,024 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,035 DEBUG [WebServer] Incoming connection from /192.168.1.35:48670
2011-02-08 12:18:30,036 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,036 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,039 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = upnp:class, startIndex = 0, count = 100, sortCriteria =
2011-02-08 12:18:30,040 DEBUG [VideoDAOImpl] Retrieving number of video initials
2011-02-08 12:18:30,052 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-08 12:18:30,052 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:30,055 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,065 DEBUG [MediaItemDAOImpl] Getting file of media item 94
2011-02-08 12:18:30,066 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 94) and extractor EMBEDDED
2011-02-08 12:18:30,082 DEBUG [WebServer] Incoming connection from /192.168.1.35:48671
2011-02-08 12:18:30,083 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,083 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,087 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:30,087 DEBUG [VideoDAOImpl] Retrieving number of video initials
2011-02-08 12:18:30,091 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-02-08 12:18:30,092 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:30,095 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,111 DEBUG [WebServer] Incoming connection from /192.168.1.35:48672
2011-02-08 12:18:30,111 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,111 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,114 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:30,115 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:30,117 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,167 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2011-02-08 12:18:30,168 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 95) and extractor EMBEDDED
2011-02-08 12:18:30,269 DEBUG [MediaItemDAOImpl] Getting file of media item 167
2011-02-08 12:18:30,270 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 167) and extractor EMBEDDED
2011-02-08 12:18:30,371 DEBUG [MediaItemDAOImpl] Getting file of media item 96
2011-02-08 12:18:30,372 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 96) and extractor EMBEDDED
2011-02-08 12:18:30,473 DEBUG [MediaItemDAOImpl] Getting file of media item 97
2011-02-08 12:18:30,474 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 97) and extractor EMBEDDED
2011-02-08 12:18:30,538 DEBUG [WebServer] Incoming connection from /192.168.1.35:48673
2011-02-08 12:18:30,539 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,539 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,542 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 0, sortCriteria =
2011-02-08 12:18:30,542 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:30,544 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,556 DEBUG [WebServer] Incoming connection from /192.168.1.35:48674
2011-02-08 12:18:30,556 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,556 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,560 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:30,560 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:30,563 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,576 DEBUG [MediaItemDAOImpl] Getting file of media item 98
2011-02-08 12:18:30,577 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 98) and extractor EMBEDDED
2011-02-08 12:18:30,581 DEBUG [WebServer] Incoming connection from /192.168.1.35:48675
2011-02-08 12:18:30,581 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:30,581 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:30,584 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:30,584 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:30,587 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:30,678 DEBUG [MediaItemDAOImpl] Getting file of media item 99
2011-02-08 12:18:30,679 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 99) and extractor EMBEDDED
2011-02-08 12:18:30,780 DEBUG [MediaItemDAOImpl] Getting file of media item 100
2011-02-08 12:18:30,781 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 100) and extractor EMBEDDED
2011-02-08 12:18:30,882 DEBUG [MediaItemDAOImpl] Getting file of media item 101
2011-02-08 12:18:30,883 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 101) and extractor EMBEDDED
2011-02-08 12:18:30,984 DEBUG [MediaItemDAOImpl] Getting file of media item 102
2011-02-08 12:18:30,985 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 102) and extractor EMBEDDED
2011-02-08 12:18:30,986 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: F:\
2011-02-08 12:18:30,986 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 7)
2011-02-08 12:18:31,093 DEBUG [MediaItemDAOImpl] Getting file of media item 103
2011-02-08 12:18:31,094 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 103) and extractor EMBEDDED
2011-02-08 12:18:31,195 DEBUG [MediaItemDAOImpl] Getting file of media item 104
2011-02-08 12:18:31,196 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 104) and extractor EMBEDDED
2011-02-08 12:18:31,297 DEBUG [MediaItemDAOImpl] Getting file of media item 105
2011-02-08 12:18:31,298 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 105) and extractor EMBEDDED
2011-02-08 12:18:31,399 DEBUG [MediaItemDAOImpl] Getting file of media item 106
2011-02-08 12:18:31,400 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 106) and extractor EMBEDDED
2011-02-08 12:18:31,501 DEBUG [MediaItemDAOImpl] Getting file of media item 107
2011-02-08 12:18:31,502 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 107) and extractor EMBEDDED
2011-02-08 12:18:31,603 DEBUG [MediaItemDAOImpl] Getting file of media item 108
2011-02-08 12:18:31,604 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 108) and extractor EMBEDDED
2011-02-08 12:18:31,705 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:31,706 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 109) and extractor EMBEDDED
2011-02-08 12:18:31,806 DEBUG [MediaItemDAOImpl] Getting file of media item 110
2011-02-08 12:18:31,807 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 110) and extractor EMBEDDED
2011-02-08 12:18:31,908 DEBUG [MediaItemDAOImpl] Getting file of media item 111
2011-02-08 12:18:31,909 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 111) and extractor EMBEDDED
2011-02-08 12:18:32,010 DEBUG [MediaItemDAOImpl] Getting file of media item 112
2011-02-08 12:18:32,011 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 112) and extractor EMBEDDED
2011-02-08 12:18:32,112 DEBUG [MediaItemDAOImpl] Getting file of media item 113
2011-02-08 12:18:32,113 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 113) and extractor EMBEDDED
2011-02-08 12:18:32,214 DEBUG [MediaItemDAOImpl] Getting file of media item 114
2011-02-08 12:18:32,215 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 114) and extractor EMBEDDED
2011-02-08 12:18:32,316 DEBUG [MediaItemDAOImpl] Getting file of media item 115
2011-02-08 12:18:32,317 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 115) and extractor EMBEDDED
2011-02-08 12:18:32,418 DEBUG [MediaItemDAOImpl] Getting file of media item 116
2011-02-08 12:18:32,419 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 116) and extractor EMBEDDED
2011-02-08 12:18:32,520 DEBUG [MediaItemDAOImpl] Getting file of media item 117
2011-02-08 12:18:32,521 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 117) and extractor EMBEDDED
2011-02-08 12:18:32,622 DEBUG [MediaItemDAOImpl] Getting file of media item 118
2011-02-08 12:18:32,623 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 118) and extractor EMBEDDED
2011-02-08 12:18:32,724 DEBUG [MediaItemDAOImpl] Getting file of media item 119
2011-02-08 12:18:32,725 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 119) and extractor EMBEDDED
2011-02-08 12:18:32,826 DEBUG [MediaItemDAOImpl] Getting file of media item 120
2011-02-08 12:18:32,827 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 120) and extractor EMBEDDED
2011-02-08 12:18:32,928 DEBUG [MediaItemDAOImpl] Getting file of media item 121
2011-02-08 12:18:32,929 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 121) and extractor EMBEDDED
2011-02-08 12:18:33,030 DEBUG [MediaItemDAOImpl] Getting file of media item 122
2011-02-08 12:18:33,031 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 122) and extractor EMBEDDED
2011-02-08 12:18:33,132 DEBUG [MediaItemDAOImpl] Getting file of media item 123
2011-02-08 12:18:33,133 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 123) and extractor EMBEDDED
2011-02-08 12:18:33,234 DEBUG [MediaItemDAOImpl] Getting file of media item 124
2011-02-08 12:18:33,235 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 124) and extractor EMBEDDED
2011-02-08 12:18:33,336 DEBUG [MediaItemDAOImpl] Getting file of media item 125
2011-02-08 12:18:33,337 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 125) and extractor EMBEDDED
2011-02-08 12:18:33,438 DEBUG [MediaItemDAOImpl] Getting file of media item 126
2011-02-08 12:18:33,439 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 126) and extractor EMBEDDED
2011-02-08 12:18:33,540 DEBUG [MediaItemDAOImpl] Getting file of media item 127
2011-02-08 12:18:33,541 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 127) and extractor EMBEDDED
2011-02-08 12:18:33,642 DEBUG [MediaItemDAOImpl] Getting file of media item 128
2011-02-08 12:18:33,643 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 128) and extractor EMBEDDED
2011-02-08 12:18:33,744 DEBUG [MediaItemDAOImpl] Getting file of media item 129
2011-02-08 12:18:33,745 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 129) and extractor EMBEDDED
2011-02-08 12:18:33,846 DEBUG [MediaItemDAOImpl] Getting file of media item 130
2011-02-08 12:18:33,847 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 130) and extractor EMBEDDED
2011-02-08 12:18:33,948 DEBUG [MediaItemDAOImpl] Getting file of media item 131
2011-02-08 12:18:33,949 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 131) and extractor EMBEDDED
2011-02-08 12:18:34,050 DEBUG [MediaItemDAOImpl] Getting file of media item 132
2011-02-08 12:18:34,051 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 132) and extractor EMBEDDED
2011-02-08 12:18:34,152 DEBUG [MediaItemDAOImpl] Getting file of media item 133
2011-02-08 12:18:34,153 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 133) and extractor EMBEDDED
2011-02-08 12:18:34,254 DEBUG [MediaItemDAOImpl] Getting file of media item 134
2011-02-08 12:18:34,255 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 134) and extractor EMBEDDED
2011-02-08 12:18:34,349 DEBUG [WebServer] Incoming connection from /192.168.1.35:48676
2011-02-08 12:18:34,349 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:34,349 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:34,352 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:34,352 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:34,355 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:34,357 DEBUG [MediaItemDAOImpl] Getting file of media item 135
2011-02-08 12:18:34,358 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 135) and extractor EMBEDDED
2011-02-08 12:18:34,373 DEBUG [WebServer] Incoming connection from /192.168.1.35:48677
2011-02-08 12:18:34,374 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:34,374 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:34,377 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:34,377 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:34,380 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:34,398 DEBUG [WebServer] Incoming connection from /192.168.1.35:48678
2011-02-08 12:18:34,398 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:34,398 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:34,401 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:34,402 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:34,404 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:34,427 DEBUG [WebServer] Incoming connection from /192.168.1.35:48679
2011-02-08 12:18:34,428 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:34,428 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:34,431 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 0, sortCriteria =
2011-02-08 12:18:34,431 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 7)
2011-02-08 12:18:34,438 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-02-08 12:18:34,439 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:34,442 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:34,453 DEBUG [WebServer] Incoming connection from /192.168.1.35:48680
2011-02-08 12:18:34,454 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:34,454 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:34,457 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 64, sortCriteria =
2011-02-08 12:18:34,457 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:34,459 DEBUG [MediaItemDAOImpl] Getting file of media item 136
2011-02-08 12:18:34,463 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 136) and extractor EMBEDDED
2011-02-08 12:18:34,470 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:34,564 DEBUG [MediaItemDAOImpl] Getting file of media item 137
2011-02-08 12:18:34,565 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 137) and extractor EMBEDDED
2011-02-08 12:18:34,613 DEBUG [WebServer] Incoming connection from /192.168.1.35:48681
2011-02-08 12:18:34,613 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:34,613 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:34,616 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 64, sortCriteria =
2011-02-08 12:18:34,617 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:34,631 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:34,665 DEBUG [MediaItemDAOImpl] Getting file of media item 138
2011-02-08 12:18:34,666 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 138) and extractor EMBEDDED
2011-02-08 12:18:34,767 DEBUG [MediaItemDAOImpl] Getting file of media item 139
2011-02-08 12:18:34,768 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 139) and extractor EMBEDDED
2011-02-08 12:18:34,868 DEBUG [MediaItemDAOImpl] Getting file of media item 140
2011-02-08 12:18:34,869 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 140) and extractor EMBEDDED
2011-02-08 12:18:34,969 DEBUG [MediaItemDAOImpl] Getting file of media item 141
2011-02-08 12:18:34,970 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 141) and extractor EMBEDDED
2011-02-08 12:18:35,071 DEBUG [MediaItemDAOImpl] Getting file of media item 142
2011-02-08 12:18:35,072 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 142) and extractor EMBEDDED
2011-02-08 12:18:35,173 DEBUG [MediaItemDAOImpl] Getting file of media item 143
2011-02-08 12:18:35,174 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 143) and extractor EMBEDDED
2011-02-08 12:18:35,274 DEBUG [MediaItemDAOImpl] Getting file of media item 144
2011-02-08 12:18:35,275 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 144) and extractor EMBEDDED
2011-02-08 12:18:35,375 DEBUG [MediaItemDAOImpl] Getting file of media item 145
2011-02-08 12:18:35,376 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 145) and extractor EMBEDDED
2011-02-08 12:18:35,476 DEBUG [MediaItemDAOImpl] Getting file of media item 146
2011-02-08 12:18:35,477 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 146) and extractor EMBEDDED
2011-02-08 12:18:35,578 DEBUG [MediaItemDAOImpl] Getting file of media item 147
2011-02-08 12:18:35,579 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 147) and extractor EMBEDDED
2011-02-08 12:18:35,679 DEBUG [MediaItemDAOImpl] Getting file of media item 148
2011-02-08 12:18:35,680 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 148) and extractor EMBEDDED
2011-02-08 12:18:35,780 DEBUG [MediaItemDAOImpl] Getting file of media item 149
2011-02-08 12:18:35,781 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 149) and extractor EMBEDDED
2011-02-08 12:18:35,881 DEBUG [MediaItemDAOImpl] Getting file of media item 150
2011-02-08 12:18:35,882 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 150) and extractor EMBEDDED
2011-02-08 12:18:35,982 DEBUG [MediaItemDAOImpl] Getting file of media item 151
2011-02-08 12:18:35,983 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 151) and extractor EMBEDDED
2011-02-08 12:18:36,083 DEBUG [MediaItemDAOImpl] Getting file of media item 152
2011-02-08 12:18:36,084 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 152) and extractor EMBEDDED
2011-02-08 12:18:36,185 DEBUG [MediaItemDAOImpl] Getting file of media item 153
2011-02-08 12:18:36,186 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 153) and extractor EMBEDDED
2011-02-08 12:18:36,286 DEBUG [MediaItemDAOImpl] Getting file of media item 154
2011-02-08 12:18:36,287 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 154) and extractor EMBEDDED
2011-02-08 12:18:36,387 DEBUG [MediaItemDAOImpl] Getting file of media item 155
2011-02-08 12:18:36,388 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 155) and extractor EMBEDDED
2011-02-08 12:18:36,489 DEBUG [MediaItemDAOImpl] Getting file of media item 156
2011-02-08 12:18:36,490 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 156) and extractor EMBEDDED
2011-02-08 12:18:36,590 DEBUG [MediaItemDAOImpl] Getting file of media item 157
2011-02-08 12:18:36,591 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 157) and extractor EMBEDDED
2011-02-08 12:18:36,692 DEBUG [MediaItemDAOImpl] Getting file of media item 158
2011-02-08 12:18:36,693 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 158) and extractor EMBEDDED
2011-02-08 12:18:36,793 DEBUG [MediaItemDAOImpl] Getting file of media item 159
2011-02-08 12:18:36,794 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 159) and extractor EMBEDDED
2011-02-08 12:18:36,895 DEBUG [MediaItemDAOImpl] Getting file of media item 160
2011-02-08 12:18:36,896 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 160) and extractor EMBEDDED
2011-02-08 12:18:36,996 DEBUG [MediaItemDAOImpl] Getting file of media item 161
2011-02-08 12:18:36,997 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 161) and extractor EMBEDDED
2011-02-08 12:18:37,097 DEBUG [MediaItemDAOImpl] Getting file of media item 162
2011-02-08 12:18:37,098 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 162) and extractor EMBEDDED
2011-02-08 12:18:37,198 DEBUG [MediaItemDAOImpl] Getting file of media item 163
2011-02-08 12:18:37,199 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 163) and extractor EMBEDDED
2011-02-08 12:18:37,300 DEBUG [MediaItemDAOImpl] Getting file of media item 164
2011-02-08 12:18:37,301 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 164) and extractor EMBEDDED
2011-02-08 12:18:37,401 DEBUG [MediaItemDAOImpl] Getting file of media item 165
2011-02-08 12:18:37,402 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 165) and extractor EMBEDDED
2011-02-08 12:18:37,502 DEBUG [MediaItemDAOImpl] Getting file of media item 166
2011-02-08 12:18:37,503 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 166) and extractor EMBEDDED
2011-02-08 12:18:37,504 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: C:\Users\Nicolás\Desktop
2011-02-08 12:18:37,504 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 9)
2011-02-08 12:18:37,605 DEBUG [MediaItemDAOImpl] Getting file of media item 168
2011-02-08 12:18:37,606 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 168) and extractor EMBEDDED
2011-02-08 12:18:37,706 DEBUG [MediaItemDAOImpl] Getting file of media item 169
2011-02-08 12:18:37,707 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 169) and extractor EMBEDDED
2011-02-08 12:18:37,708 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 6)
2011-02-08 12:18:37,725 DEBUG [RepositoryDAOImpl] Marking Repository 6 as scanned with current timestamp
2011-02-08 12:18:37,727 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 7)
2011-02-08 12:18:37,729 DEBUG [RepositoryDAOImpl] Marking Repository 7 as scanned with current timestamp
2011-02-08 12:18:37,731 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 9)
2011-02-08 12:18:37,732 DEBUG [RepositoryDAOImpl] Marking Repository 9 as scanned with current timestamp
2011-02-08 12:18:38,069 DEBUG [WebServer] Incoming connection from /192.168.1.35:48682
2011-02-08 12:18:38,069 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,069 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,072 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 64, sortCriteria =
2011-02-08 12:18:38,073 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:38,085 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:38,240 DEBUG [WebServer] Incoming connection from /192.168.1.35:48683
2011-02-08 12:18:38,240 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,240 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,243 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 64, sortCriteria =
2011-02-08 12:18:38,243 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:38,258 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:38,397 DEBUG [WebServer] Incoming connection from /192.168.1.35:48684
2011-02-08 12:18:38,398 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,398 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,401 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 64, sortCriteria =
2011-02-08 12:18:38,401 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:38,414 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:38,580 DEBUG [WebServer] Incoming connection from /192.168.1.35:48685
2011-02-08 12:18:38,581 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,581 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,584 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7$F90, browseFlag = BrowseMetadata, filter = upnp:class, startIndex = 0, count = 0, sortCriteria =
2011-02-08 12:18:38,584 DEBUG [FolderDAOImpl] Reading a Folder (id = 90)
2011-02-08 12:18:38,585 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 90
2011-02-08 12:18:38,586 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:38,588 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:38,599 DEBUG [WebServer] Incoming connection from /192.168.1.35:48686
2011-02-08 12:18:38,599 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,602 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7$F90, browseFlag = BrowseDirectChildren, filter = upnp:class, startIndex = 0, count = 100, sortCriteria =
2011-02-08 12:18:38,603 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 90
2011-02-08 12:18:38,619 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 90 (from=0, count=100)
2011-02-08 12:18:38,621 DEBUG [GenreDAOImpl] Reading a Genre (id = 9)
2011-02-08 12:18:38,625 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:38,631 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:38,632 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-08 12:18:38,639 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 109 and profile LG 42LD650 TV
2011-02-08 12:18:38,640 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:38,640 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:38,640 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:38,641 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 90
2011-02-08 12:18:38,642 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:38,644 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:38,659 DEBUG [WebServer] Incoming connection from /192.168.1.35:48687
2011-02-08 12:18:38,660 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,660 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,663 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7$F90, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:38,663 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 90
2011-02-08 12:18:38,664 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 90 (from=0, count=54)
2011-02-08 12:18:38,665 DEBUG [GenreDAOImpl] Reading a Genre (id = 9)
2011-02-08 12:18:38,665 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:38,666 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:38,667 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-08 12:18:38,667 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 109 and profile LG 42LD650 TV
2011-02-08 12:18:38,668 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:38,668 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:38,668 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:38,669 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 90
2011-02-08 12:18:38,670 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-02-08 12:18:38,672 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:38,690 DEBUG [WebServer] Incoming connection from /192.168.1.35:48688
2011-02-08 12:18:38,691 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:38,691 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:38,694 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7$F90, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:38,694 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:38,696 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:39,630 DEBUG [WebServer] Incoming connection from /192.168.1.35:48689
2011-02-08 12:18:39,630 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:39,630 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:39,633 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7$F90, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:39,633 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:39,636 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:42,664 DEBUG [WebServer] Incoming connection from /192.168.1.35:48690
2011-02-08 12:18:42,664 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.35:
2011-02-08 12:18:42,664 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:42,667 DEBUG [ContentDirectory] Browse() called for profile LG 42LD650 TV with parameters: objectID = V_F#FOL_R7$F90, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency, startIndex = 0, count = 54, sortCriteria =
2011-02-08 12:18:42,667 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2011-02-08 12:18:42,670 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-02-08 12:18:42,686 DEBUG [WebServer] Incoming connection from /192.168.1.35:48691
2011-02-08 12:18:42,687 DEBUG [ResourceTransportRequestHandler] GET /resource/109/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [Host: 192.168.1.33:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,User-Agent: Mozilla/5.0 (compatible; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast-2010)]]
2011-02-08 12:18:42,687 DEBUG [WebServer] Incoming connection from /192.168.1.35:48692
2011-02-08 12:18:42,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:42,688 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:42,689 DEBUG [ResourceTransportRequestHandler] Request for resource 109 and type 'MEDIA_ITEM' received
2011-02-08 12:18:42,689 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:42,690 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:42,690 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-08 12:18:42,691 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-08 12:18:42,691 DEBUG [VideoDeliveryEngine] Delivering item '109' for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:42,691 DEBUG [VideoDeliveryEngine] Delivering file 'Cars.mkv' using transcoding
2011-02-08 12:18:42,692 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:42,692 DEBUG [MediaItemDAOImpl] Getting file of media item 109
2011-02-08 12:18:42,694 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: F:\Cars\Cars.mkv
2011-02-08 12:18:42,694 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Cars\Cars.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-109-MPEG2TS.stf
2011-02-08 12:18:43,194 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,195 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:43,195 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2011-02-08 12:18:43,195 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 109) as read
2011-02-08 12:18:43,203 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:43,203 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2011-02-08 12:18:43,203 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 109) as read
2011-02-08 12:18:43,205 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-02-08 12:18:43,207 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-08 12:18:43,208 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Tue, 08 Feb 2011 15:18:43 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-02-08 12:18:43,237 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-02-08 12:18:43,238 DEBUG [WebServer] Incoming connection from /192.168.1.35:48693
2011-02-08 12:18:43,239 DEBUG [ResourceTransportRequestHandler] GET /resource/109/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [Host: 192.168.1.33:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=4611686018427371520-,User-Agent: Mozilla/5.0 (compatible; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast-2010)]]
2011-02-08 12:18:43,239 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2011-02-08 12:18:43,239 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,240 DEBUG [ResourceTransportRequestHandler] Request for resource 109 and type 'MEDIA_ITEM' received
2011-02-08 12:18:43,240 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109)
2011-02-08 12:18:43,240 DEBUG [VideoDAOImpl] Reading a Video (id = 109)
2011-02-08 12:18:43,241 DEBUG [VideoDeliveryEngine] Delivering item '109' for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,241 DEBUG [VideoDeliveryEngine] Delivering file 'Cars.mkv' using transcoding
2011-02-08 12:18:43,242 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.35, Profile=LG 42LD650 TV'
2011-02-08 12:18:43,242 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Cars.mkv: AVC_TS_MP_HD_AC3_ISO
2011-02-08 12:18:43,242 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -4611686009427371520
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-02-08 12:18:43,242 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 4611686018427371520-8999999999/9000000000,Date: Tue, 08 Feb 2011 15:18:43 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2011-02-08 12:18:46,098 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-02-08 12:19:10,502 DEBUG [WebServer] Incoming connection from /192.168.1.35:48696
2011-02-08 12:19:10,503 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ContentDirectory and subscription uuid:0044bb63-5371-4b71-9f24-82b2e6d9bcae
2011-02-08 12:19:10,503 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription (uuid=0044bb63-5371-4b71-9f24-82b2e6d9bcae) removed for service urn:upnp-org:serviceId:ContentDirectory
2011-02-08 12:19:10,506 DEBUG [WebServer] Incoming connection from /192.168.1.35:48697
2011-02-08 12:19:10,506 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent unsubscription request received for service ConnectionManager and subscription uuid:edf46638-0449-416a-95e2-0502d3545638
2011-02-08 12:19:10,506 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription (uuid=edf46638-0449-416a-95e2-0502d3545638) removed for service urn:upnp-org:serviceId:ConnectionManager
2011-02-08 12:19:20,061 INFO  [ServiioConsole] Leaving Serviio Console
2011-02-08 12:19:20,073 DEBUG [ActionsServerResource] Action with name 'exitServiio' was requested
2011-02-08 12:19:20,077 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-02-08 12:19:20,275 DEBUG [DiscoveryManager] UPNP device 7c244fb3-0b22-3d10-94e6-71e4e0006f49 (192.168.1.33) is unavailable
2011-02-08 12:19:20,275 INFO  [EventDispatcher] Leaving EventDispatcher
2011-02-08 12:19:20,282 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-02-08 12:19:20,282 DEBUG [WebServer] Socket closed
2011-02-08 12:19:20,282 INFO  [WebServer] WebServer shutting down
2011-02-08 12:19:20,282 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-02-08 12:19:20,535 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Atheros L1 Gigabit Ethernet 10/100/1000Base-T Controller) and address PC-Nico, timeout = 0
2011-02-08 12:19:20,536 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-02-08 12:19:20,537 INFO  [DatabaseManager] Shutting down database
2011-02-08 12:19:20,537 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2011-02-08 12:19:20,583 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2011-02-08 12:19:20,583 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-02-08 12:19:20,583 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-100,5,main]
2011-02-08 12:19:20,584 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-02-08 12:19:24,032 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-02-08 12:20:06,849 DEBUG [VideoDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2011-02-08 12:20:06,937 DEBUG [VideoDeliveryEngine] Deleted file C:\Windows\TEMP\Serviio\transcoding-temp-109-MPEG2TS.stf: true
2011-02-08 12:30:05,754 DEBUG [ApplicationInstanceManager] Liste
Post Tue Feb 08, 2011 6:08 pm
Well, firstly the TV sends 2 requests for the video (why 2? weird), Serviio responds. Then it asks for a (nonexistent) byte range even though Serviio tells it byte range is not supported for transcoded files. So it's definitely a problem with the TV.
If somebody can get transcoding working with another server with this TV then packet capture log (HTTP headers) would be welcome.
vloemans
Post Sun Feb 13, 2011 3:25 pm
zip wrote:So we have to create a new profile for the TV. Start with a really simple one (just extends from Generic) and add the subtitle bit. Like:
<Profile id="14" name="LG TV" extendsProfileId="1">
Other possibility is to use LG BD profile and disable transcoding in the console.
How can I create a new profile?
Wout
Post Sun Feb 13, 2011 3:54 pm
vloemans
Post Sun Feb 13, 2011 5:15 pm
It works! Thanks.
Post Sun Feb 13, 2011 5:43 pm
Now we should try to work out auto-detection settings for the TV. Can you remove the TV from the list of renderers, enable detailed log and restart Serviio. Then post the log (or at least first 100 lines or so after the server starts)
AMSlider
Post Tue Feb 22, 2011 3:00 am
Hey zip, nice work. Serviio is the best DLNA server I've tried thus far on my LG LD550 LCD TV. Thanks for everything!
Here's the log from a clean/original profiles.xml:
2011-02-21 19:50:29,156 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-02-21 19:50:29,206 INFO  [MediaServer] ------------------------------------------------------------------------
2011-02-21 19:50:29,206 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5 (rev. 975aa458693c)
2011-02-21 19:50:29,206 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-02-21 19:50:29,206 INFO  [MediaServer] http://www.serviio.org
2011-02-21 19:50:29,206 INFO  [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2011-02-21 19:50:29,206 INFO  [MediaServer] OS Linux amd64 2.6.35-25-generic
2011-02-21 19:50:29,206 INFO  [MediaServer] File encoding: UTF-8
2011-02-21 19:50:29,403 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-02-21 19:50:29,478 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-02-21 19:50:29,507 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-02-21 19:50:30,830 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-02-21 19:50:30,831 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-02-21 19:50:30,831 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-02-21 19:50:30,832 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-02-21 19:50:30,832 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-02-21 19:50:30,833 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-02-21 19:50:30,833 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-02-21 19:50:31,202 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-02-21 19:50:31,227 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-02-21 19:50:31,519 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-02-21 19:50:31,520 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-02-21 19:50:31,630 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-02-21 19:50:31,631 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-02-21 19:50:31,668 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-02-21 19:50:31,669 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-02-21 19:50:31,692 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-02-21 19:50:31,693 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-02-21 19:50:31,725 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-02-21 19:50:31,726 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-02-21 19:50:31,750 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-02-21 19:50:31,751 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-02-21 19:50:31,788 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-02-21 19:50:31,789 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-02-21 19:50:31,807 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-02-21 19:50:31,808 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-02-21 19:50:31,898 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-02-21 19:50:31,899 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-02-21 19:50:32,105 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player (EU)' (id=10)
2011-02-21 19:50:32,106 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 11
2011-02-21 19:50:32,347 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player (US)' (id=11)
2011-02-21 19:50:32,348 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-02-21 19:50:32,387 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-02-21 19:50:32,389 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-02-21 19:50:32,465 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-02-21 19:50:32,467 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2011-02-21 19:50:32,468 DEBUG [ProcessExecutor] Starting ffmpeg
2011-02-21 19:50:32,565 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-02-21 19:50:32,567 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-02-21 19:50:32,602 DEBUG [VideoDeliveryEngine] Deleting temporary transcoded files from: /tmp/Serviio
2011-02-21 19:50:32,602 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-02-21 19:50:32,658 INFO  [WebServer] WebServer starting on port 8895
2011-02-21 19:50:32,676 INFO  [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-02-21 19:50:32,708 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-02-21 19:50:32,713 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-02-21 19:50:32,716 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-02-21 19:50:32,716 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-02-21 19:50:32,717 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-21 19:50:32,717 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-02-21 19:50:32,717 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1298343032717, LastAccessTime = 1298343032717, getTimeToLiveSeconds() = -1, createTime = 1298343032717 ]
2011-02-21 19:50:32,719 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-02-21 19:50:32,727 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-02-21 19:50:32,727 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-21 19:50:32,727 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-02-21 19:50:32,727 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-02-21 19:50:32,727 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-02-21 19:50:32,727 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-02-21 19:50:32,727 INFO  [CompositeCacheConfigurator] Finished configuration in 13 ms.
2011-02-21 19:50:32,728 DEBUG [DiscoveryManager] UPNP device b8788ec1-4308-32fc-a48f-2532c9b147a9 (192.168.2.4) is available
2011-02-21 19:50:32,729 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-02-21 19:50:32,730 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.2.4, timeout = 0
2011-02-21 19:50:32,730 INFO  [EventDispatcher] Starting EventDispatcher
2011-02-21 19:50:32,733 INFO  [RendererSearchSender] Searching for Renderer devices
2011-02-21 19:50:32,733 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-02-21 19:50:32,733 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-02-21 19:50:32,734 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.2.4, timeout = 0
2011-02-21 19:50:32,737 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.4, timeout = 0
2011-02-21 19:50:32,744 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-02-21 19:50:32,744 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b8788ec1-4308-32fc-a48f-2532c9b147a9
2011-02-21 19:50:32,749 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.4:39176
2011-02-21 19:50:32,751 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.4:39176
2011-02-21 19:50:34,548 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-21 19:50:35,962 DEBUG [WebServer] Incoming connection from /192.168.2.211:57421
2011-02-21 19:50:35,965 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b8788ec1-4308-32fc-a48f-2532c9b147a9 from 192.168.2.211 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.2.4:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50])
2011-02-21 19:50:35,965 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.211
2011-02-21 19:50:35,997 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.211
2011-02-21 19:50:36,155 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2011-02-21 19:50:36,249 DEBUG [WebServer] Incoming connection from /192.168.2.211:57422
2011-02-21 19:50:36,249 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2011-02-21 19:50:38,754 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-02-21 19:50:44,549 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.4, timeout = 0
2011-02-21 19:50:44,550 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b8788ec1-4308-32fc-a48f-2532c9b147a9
2011-02-21 19:50:46,353 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-02-21 19:50:56,353 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.2.4, timeout = 0
2011-02-21 19:50:56,354 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b8788ec1-4308-32fc-a48f-2532c9b147a9
2011-02-21 19:50:58,157 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:13:06
2011-02-21 19:51:11,701 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.56:60195
2011-02-21 19:51:11,702 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.56:60195
2011-02-21 19:51:12,203 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.56:60195
2011-02-21 19:51:12,203 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.56:60195
2011-02-21 19:51:16,715 DEBUG [WebServer] Incoming connection from /192.168.2.56:40704
2011-02-21 19:51:16,717 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b8788ec1-4308-32fc-a48f-2532c9b147a9 from 192.168.2.56 (headers = [HOST: 192.168.2.4:8895,DATE: Tue, 22 Feb 2011 02:48:21 GMT,USER-AGENT: Linux/2.6.31-1.0 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.5.0,friendlyName.dlna.org: LG DLNA DMP DEVICE])
2011-02-21 19:51:16,718 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.56
2011-02-21 19:51:16,719 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.56
Here's my config profile I've pieced together:
   <Profile id="14" name="LG LD550 LCD TV" extendsProfileId="1">
      <Detection>
                        headers = [HOST: 192.168.2.4:8895, DATE: Thu, 01 Jan 1970 00:00:16 GMT,USER-AGENT: Linux/2.6.31-1.0 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.5.0,friendlyName.dlna.org: LG DLNA DMP DEVICE])
                        headers = [Host: 192.168.2.4:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,User-Agent: Mozilla/5.0 (compatible; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2010)]]
         <HttpHeaders>
            <User-Agent>*LG NetCast\.TV\-2010*</User-Agent>
         </HttpHeaders>
         <UPnPSearch>
            <FriendlyName>LG DLNA DMP DEVICE</FriendlyName>
         </UPnPSearch>
      </Detection>
                From: http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6460#formats
                Video Codecs: DivX, Xvid, H.264, AVC, MPEG2
                Audio Codecs: AC3, ACC, WMA, MP3, DD
                File Extensions: MP4, MKV, DIVX, AVI, MPEG, MPG, VOB
                Music
                Audio Codecs: WMA, MP3 (8-320 kbps)
                File Extensions: WMA, MP3
                Photos
                Codecs: JPEG, PNG
                File Extensions: JPG, JPEG, PNG
         <!-- remux to mpeg-ts and transcode audio -->
         <Video targetContainer="mpeg" targetACodec="mp3">
         <!-- <Video targetContainer="mpegts" targetACodec="ac3"> -->
               remove all matroska transcoding matches if you stream over a wired connection and want mkv subtitle support and alt audio
               tracks
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
         <!-- <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="mp3"> -->
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
                                <!-- Valid vCodec - [vc1, mpeg4, msmpeg4, mpeg2video, mpeg1video, h264, wmv2, mjpeg, flv, vp6] -->
            <Matches container="asf" />
            <Matches container="flv" />
            <!-- digital camera video formats -->
      <LimitImageResolution>true</LimitImageResolution>
FWIW,
I have the same issue with transcoding as mentioned in the post http://forum.serviio.org/viewtopic.php?f=12&t=546&start=40
Thanks!
Post Tue Feb 22, 2011 9:45 am
Re: Subtitle doesn't show with Generic DLNA Profile.
The detection in your profile is not correct. It should be:
<HttpHeaders>
  <friendlyName.dlna.org>LG DLNA DMP DEVICE</friendlyName.dlna.org>
</HttpHeaders>
Does the TV show in DeviceSpy?
AMSlider
Post Wed Feb 23, 2011 12:03 am
Thanks for the tip, I've just changed my profile.
The TV does not display in Device Spy :cry:
Previous
Return to LG
